AT&T to end email-to-text ×
mesange
  • Posts
    8
Everything posted by mesange
  1. mesange
    Devices Links
    Rand you have found the solution. Thank you very much. I was effectively on device reported instead of automatic. I would like also to thank everyone for their help. It is most appreciated. Thanks again! Mark
  2. mesange
    Devices Links
    For another test I Plugged the LampLinc directly onto the PLM. When I make Device link test, the led on PLM and on LampLinc lighted 2 times and I obtained the same error. Mark
  3. mesange
    Devices Links
    I removed (2456D3) LampLinc from My Lighting and I choosed the "Start linking" button and I can get status. I have always the same error messaage [-200000] on show device link. Mark
  4. mesange
    Devices Links
    I did it manually (type the address). Mark
  5. mesange
    Devices Links
    I have a #2440 RemoteLinc which control three switchLinc in a scene and the Show Device is OK on this RemoteLinc. Mark
  6. mesange
    Devices Links
    I can query and operate all modules. For all modules, I obtain the following : [-200000] Failed reading device link [11.xx.xx.1 Switch Kitchen]. Mark
  7. mesange
    Devices Links
    I have a ISY99IR Pro V 2.7.15. I have also 2 access point #2443 : one on each phase. I have different Insteon devices like SwitchLinc, ApplianceLinc, I/OLinc, etc. and it works very well. For all devices, if I go to : Tools/Diagnostics/Show PLM Links table and Show ISY Links table that is OK. For many devices, if I go to Tools/Diagnostics/Show Device Links table, I obtain the following message : [-20000] Failed reading devide link [12.xx.xx.1]. As mentioned in Errors and Error Messages -UDI Wiki : System Errors : - 20000 Driver. How do I proceed to solve those errors ? Many thanks in advance, Mark
  8. I use a ISY99IRPRO V. 2.7.6 with a TriggerLinc 2421 to control an ApplianceLinc 2456S3. I use a simple program like this : If Status '11.B8.1D-Opened' is ON Then Set '11.59.00.1 Buz Solar' ON Else No Action - This program works correctly. However, I would like that ApplianceLinc comes ON and, after, if I short the input of the TriggerLinc many times during approx 1 to 2 minutes, I want the ApplianceLinc stay OFF. After that delay, I want it to begin again this operation. Many thanks in advance for your help. Marc
  • Create New...
