jdlugosh
  1. Thanks Techman! It's been a long time since I read that and pg.17 did the trick. Cheers
  2. Hi All, Had an old 6 port Insteon switch die and replaced it with a 2334-222 8 port that I had in attic stock. In the past there was a conversion process that could be applied to change an 8 port to function as a 6 or 4 port. I can't seem to find that capability anymore. Looking for suggestions if it's not available anymore. My thoughts are to just copy the button 1 and 2 to "On" function and 7-8 to "Off". Thanks in advance! Using Eisy -IoX v.5.7.0
  3. Bob, Thanks for the response. Corrected the geocode structure to include the missing = with the lon as you stated below and its working. Thank you! lat=38.66&lon=-120.88 not lat=38.66&lon-120.88
  4. Having the same issue with not displaying data although connected. My original issue was that I hadn't subscribed to "onecall". I did that, generated a new key, installed it and restarted all of the services. What am I doing wrong? You seem to be correct. I've deleted and recreated a new API key. I now see error code 400. 2023-08-20 13:00:55,840 Thread-23 udi_interface DEBUG query:_get_weather_data: {'cod': '400', 'message': 'Nothing to geocode'} 2023-08-20 13:00:55,840 Thread-23 udi_interface DEBUG query:_get_weather_data: {'cod': '400', 'message': 'Nothing to geocode'} 2023-08-20 13:00:55,840 Thread-23 udi_interface ERROR query:query_onecall: Onecall data query failed 2023-08-20 13:00:55,840 Thread-23 udi_interface ERROR query:query_onecall: Onecall data query failed
  5. Having the same issue with not displaying data although connected. My original issue was that I hadn't subscribed to "onecall". I did that, generated a new key, installed it and restarted all of the services. What am I doing wrong?
