greensuit
  1. @SteveT, I reverted manually. I excluded everything, restored an IoX backup made prior to the jump to ZMatter, reset the USB stick to factory and then included everything from scratch. I only have ~10 ZW devices so it wasn't too painful.
  2. Hey All, Is anyone having issues with setting parameters with the Zmatter card? I have a Zooz ZSE40 700 4-in-1 sensor and I can't get any of the parameters to take. Are the parameters global or are they specific to to each node? The sensor device is in Celsius, which I could live with (even though the factory default is in F), but I want to adjust the sensitivity with some of the other parameters to have it report more frequently since I use this sensor as a thermostat. Everything was working fine on the Zooz 700 stick. I also have an August ZW lock. When I add it to zmatter, there is no node that is created even though the logs state it was added successfully. I'm about to revert back to the Zooz 700 stick. I was just wondering if anyone had successes to share. Thanks! -Alex
