PeteEaston
Everything posted by PeteEaston
  1. FYI the new update seems to have resolved the issues PG3x Version 3.1.33 Status: Connected Frontend Version: 3.1.35 IoX Version: 5.6.2 Connected
  2. @mbking thats good, i'm still seeing the connection for each node go down then back up usually two to three times a day. so glad it doesn't break anything
  3. @mbkingDid they figure out the issue?
  4. PeteEaston posted a topic in Polisy
    Just a quick question (i hope) I've upgrade my Polisy to following: PG3x Version 3.1.27 Frontend Version: 3.1.27 IoX Version: 5.6.0 and now i keep getting these notifications, I know i can turn them off but did i miss something in the upgrade? Pete 5/30/2023, 11:52:23 [pg3] info: IoX entry for Climacell::1 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Sun::2 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Timedata::3 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Holidays::4 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Push::5 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for HolidaysGoogle::6 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Ecobee::7 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Ring::8 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Govee::9 OK 5/30/2023, 11:52:27 [pg3] info: [00:0d:b9:59:45:9c_9] controller reporting command DON 5/30/2023, 11:54:26 [pg3] info: [00:0d:b9:59:45:9c_7] controller reporting command DON 5/30/2023, 11:57:23 [pg3] info: Verifying node servers are installed on IoX correctly 5/30/2023, 11:57:23 [pg3] info: IoX entry for Climacell::1 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Sun::2 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Timedata::3 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Holidays::4 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Push::5 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for HolidaysGoogle::6 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Ecobee::7 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Ring::8 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Govee::9 OK 5/30/2023, 11:57:26 [pg3] info: [00:0d:b9:59:45:9c_7] controller reporting command DOF 5/30/2023, 11:57:27 [pg3] info: [00:0d:b9:59:45:9c_9] controller reporting command DOF
  5. Up and running, thanks for the quick work! and i also got 5 beeps not the usual 4
  6. Yeah, I'm getting the same. Looks like PG3 did come back online. Everything else works but no PG3
  7. yeah, cant afford to spend $350-400 so my ISY knows what the weather is outside
  8. I have the hardware and it was working great with polyglot cloud but with that removed I need to either rebuild it locally or find an alternative
  9. I read the first one, but looking into the second. thanks
  10. HI All, I've been attempting to install the polyglot server from UDI for a couple of days now with no luck. I've been following the instructions here: https://github.com/UniversalDevicesInc/polyglot-v2 i flashed a new SD (32g)card with Raspberry Pi OS Lite(legacy) Everything seems to install correctly but when i try to access it at 192.168.88.74:3000, nothing after some reading/googling if added a .env file to .polyglot dir and now i can reach it vis the web but get Not connected to server... Try refreshing the page. This will disappear once the connection is re-established. and if i remove the file it goes back to nothing. I don't see any errors in the logs either 4/11/2022, 08:27:20 [polyglot] debug: Created PID file: /home/pi/.polyglot/polyglot.pid 4/11/2022, 08:27:24 [polyglot] info: Starting Polyglot.... 4/11/2022, 08:27:25 [polyglot] debug: Created PID file: /home/pi/.polyglot/polyglot.pid 4/11/2022, 08:27:27 [polyglot] info: Starting Polyglot.... 4/11/2022, 08:27:28 [polyglot] info: Settings: Polyglot Version 2.2.11 4/11/2022, 08:27:28 [polyglot] info: Settings: Retrieved config from database 4/11/2022, 08:27:28 [polyglot] info: Settings: Retrieved config overrides from .env and updated database 4/11/2022, 08:27:28 [polyglot] debug: Checking for DB Maintenence needs... 4/11/2022, 08:27:28 [polyglot] debug: DB Version Found: 2 no maintenence necessary. 4/11/2022, 08:27:28 [polyglot] info: Aedes MQTT Broker Service: Started on port 1883 4/11/2022, 08:27:29 [polyglot] info: MQTT Client Service: Started 4/11/2022, 08:27:29 [polyglot] info: HTTP Interface Service: Started - Address: 192.168.88.74 Port: 3000 4/11/2022, 08:27:29 [polyglot] info: MQTTS: polyglot authenticated successfully. 4/11/2022, 08:27:29 [polyglot] info: MQTTS: Client Connected: 4/11/2022, 08:27:29 [polyglot] debug: Node server Ring [1] added to running config. 4/11/2022, 08:27:29 [polyglot] debug: Node server MyQ [2] added to running config. 4/11/2022, 08:27:29 [polyglot] debug: Node server TimedataPGC [4] added to running config. 4/11/2022, 08:27:29 [polyglot] debug: Node server Climacell [5] added to running config. 4/11/2022, 08:27:29 [polyglot] debug: MongoDB: 4 Node server(s) retrieved from database 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/connections/# QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/# QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/settings QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/node servers QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/log QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/ns/# QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/profile/# QoS 0 4/11/2022, 08:27:29 [polyglot] debug: ISY: 200 - http://192.168.88.62:80/rest/config/ 4/11/2022, 08:27:30 [polyglot] info: ISY: Got Version 5.3.0 4/11/2022, 08:27:30 [polyglot] debug: ISY: 200 - http://192.168.88.62:80/rest/profiles/ns/0/connection/ any ideas would be great Pete
  11. Hi All, I received and er ISY product to play around with and try things i don't want to try on my main system but i'm running into some issues. here's the product info: Product: (1020) ISY 99i 256 App: Insteon_UD99 Platform: ISY-C-99 Version: 2.7.0 Build Date: 2009-02-13-16:08:25 Other Services: So far I can telnet to it, i can see it in the ISY Launcher but cant access the admin parts, i cant register it in my isy account Is it possible that the firmware is to out of date to connect in the launcher? I've reset it a few times but still cant seem to get access to upgrade the firmware (currently 2.0.7) Also when ever i telnet to it I get "--- Currently in SAFE MODE, some services are not running ---" Any ideas? thanks in advance Pete
