Everything posted by PeteEaston
Polisy Offline after firmware upgrade
Putting in a ticket was my next step, it’s only been 100+ days since I was last in. I don’t remember the version I was on but I read the read me before I did it and remember checking to verify it was ok. Yes I can get that page and I also tried to reinstall from the Java app with again the same results Thanks for the info
rebooted several times
I haven't logged into my polisy in a couple of months, and when I did yesterday, I noticed that I had some updates to do... So, like the good user I am, I do them. Now my Polisy is offline, and I can't get the pg3 node server to start. It seems to be functioning manually, no Alexa. no automation. Current firmware version 6.0.5 Current PG3x Vsersion 3.4.18 And the portal says I'm offline Any pointers on where/how to start troubleshooting this? Thanks in advance for any assistance Pete Also, I've tried to force-reinstall the firmware, with the same result
Polisy with PG3x
FYI the new update seems to have resolved the issues PG3x Version 3.1.33 Status: Connected Frontend Version: 3.1.35 IoX Version: 5.6.2 Connected
Polisy with PG3x
@mbking thats good, i'm still seeing the connection for each node go down then back up usually two to three times a day. so glad it doesn't break anything
Polisy with PG3x
@mbkingDid they figure out the issue?
Polisy with PG3x
Just a quick question (i hope) I've upgrade my Polisy to following: PG3x Version 3.1.27 Frontend Version: 3.1.27 IoX Version: 5.6.0 and now i keep getting these notifications, I know i can turn them off but did i miss something in the upgrade? Pete 5/30/2023, 11:52:23 [pg3] info: IoX entry for Climacell::1 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Sun::2 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Timedata::3 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Holidays::4 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Push::5 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for HolidaysGoogle::6 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Ecobee::7 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Ring::8 OK 5/30/2023, 11:52:23 [pg3] info: IoX entry for Govee::9 OK 5/30/2023, 11:52:27 [pg3] info: [00:0d:b9:59:45:9c_9] controller reporting command DON 5/30/2023, 11:54:26 [pg3] info: [00:0d:b9:59:45:9c_7] controller reporting command DON 5/30/2023, 11:57:23 [pg3] info: Verifying node servers are installed on IoX correctly 5/30/2023, 11:57:23 [pg3] info: IoX entry for Climacell::1 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Sun::2 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Timedata::3 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Holidays::4 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Push::5 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for HolidaysGoogle::6 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Ecobee::7 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Ring::8 OK 5/30/2023, 11:57:23 [pg3] info: IoX entry for Govee::9 OK 5/30/2023, 11:57:26 [pg3] info: [00:0d:b9:59:45:9c_7] controller reporting command DOF 5/30/2023, 11:57:27 [pg3] info: [00:0d:b9:59:45:9c_9] controller reporting command DOF
Support thread for: PG3 v3.1.21 (May 22, 2023)
Up and running, thanks for the quick work! and i also got 5 beeps not the usual 4
Yeah, I'm getting the same. Looks like PG3 did come back online. Everything else works but no PG3
Install Polyglot v2 on a Raspberry pi 3b+
yeah, cant afford to spend $350-400 so my ISY knows what the weather is outside
I have the hardware and it was working great with polyglot cloud but with that removed I need to either rebuild it locally or find an alternative
I read the first one, but looking into the second. thanks
HI All, I've been attempting to install the polyglot server from UDI for a couple of days now with no luck. I've been following the instructions here: https://github.com/UniversalDevicesInc/polyglot-v2 i flashed a new SD (32g)card with Raspberry Pi OS Lite(legacy) Everything seems to install correctly but when i try to access it at 192.168.88.74:3000, nothing after some reading/googling if added a .env file to .polyglot dir and now i can reach it vis the web but get Not connected to server... Try refreshing the page. This will disappear once the connection is re-established. and if i remove the file it goes back to nothing. I don't see any errors in the logs either 4/11/2022, 08:27:20 [polyglot] debug: Created PID file: /home/pi/.polyglot/polyglot.pid 4/11/2022, 08:27:24 [polyglot] info: Starting Polyglot.... 4/11/2022, 08:27:25 [polyglot] debug: Created PID file: /home/pi/.polyglot/polyglot.pid 4/11/2022, 08:27:27 [polyglot] info: Starting Polyglot.... 4/11/2022, 08:27:28 [polyglot] info: Settings: Polyglot Version 2.2.11 4/11/2022, 08:27:28 [polyglot] info: Settings: Retrieved config from database 4/11/2022, 08:27:28 [polyglot] info: Settings: Retrieved config overrides from .env and updated database 4/11/2022, 08:27:28 [polyglot] debug: Checking for DB Maintenence needs... 4/11/2022, 08:27:28 [polyglot] debug: DB Version Found: 2 no maintenence necessary. 4/11/2022, 08:27:28 [polyglot] info: Aedes MQTT Broker Service: Started on port 1883 4/11/2022, 08:27:29 [polyglot] info: MQTT Client Service: Started 4/11/2022, 08:27:29 [polyglot] info: HTTP Interface Service: Started - Address: 192.168.88.74 Port: 3000 4/11/2022, 08:27:29 [polyglot] info: MQTTS: polyglot authenticated successfully. 4/11/2022, 08:27:29 [polyglot] info: MQTTS: Client Connected: 4/11/2022, 08:27:29 [polyglot] debug: Node server Ring [1] added to running config. 4/11/2022, 08:27:29 [polyglot] debug: Node server MyQ [2] added to running config. 4/11/2022, 08:27:29 [polyglot] debug: Node server TimedataPGC [4] added to running config. 4/11/2022, 08:27:29 [polyglot] debug: Node server Climacell [5] added to running config. 4/11/2022, 08:27:29 [polyglot] debug: MongoDB: 4 Node server(s) retrieved from database 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/connections/# QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/# QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/settings QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/node servers QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/frontend/log QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/ns/# QoS 0 4/11/2022, 08:27:29 [polyglot] debug: MQTTC: Subscribed to udi/polyglot/profile/# QoS 0 4/11/2022, 08:27:29 [polyglot] debug: ISY: 200 - http://192.168.88.62:80/rest/config/ 4/11/2022, 08:27:30 [polyglot] info: ISY: Got Version 5.3.0 4/11/2022, 08:27:30 [polyglot] debug: ISY: 200 - http://192.168.88.62:80/rest/profiles/ns/0/connection/ any ideas would be great Pete
Setup a new old isy99i
Thanks for all the info
Hi All, I received and er ISY product to play around with and try things i don't want to try on my main system but i'm running into some issues. here's the product info: Product: (1020) ISY 99i 256 App: Insteon_UD99 Platform: ISY-C-99 Version: 2.7.0 Build Date: 2009-02-13-16:08:25 Other Services: So far I can telnet to it, i can see it in the ISY Launcher but cant access the admin parts, i cant register it in my isy account Is it possible that the firmware is to out of date to connect in the launcher? I've reset it a few times but still cant seem to get access to upgrade the firmware (currently 2.0.7) Also when ever i telnet to it I get "--- Currently in SAFE MODE, some services are not running ---" Any ideas? thanks in advance Pete
