ddimit
Everything posted by ddimit
  1. ddimit replied to ddimit's topic in Geek Batch
    Thanks for the help. Michel jumped in and sent me the command
  2. Yes, as well as rebooting both ISY and Polisy.
  3. Heres the versions, polisy 2.2.1 ISY 5.3.1 Added several node servers all showing discoonected on Polisy On ISY they are showing on the drop down on the top menu bar but not in the left window pane. Reading all the help file i have hit a road block on whoa I am missing here. Any help is much apprecated pi Front
  4. ddimit posted a topic in Geek Batch
    Late start on having time to get this up and running. HTTP is refusing to ssh into and ran the upgrade commands. trying to restart UDX service after upragde and getting. [admin@polisy ~]$ sudo udx start sudo: udx: command not found
  5. Thanks for the Susgestions, I tried from a win7 ethernet connect machine. Fails at the same spot. alos pulled down the file from the web instead of using the same file from before. Must be something going on with my ISY
  6. Yes, but those would stop the upload before it begins not 83% through the upgrade. Im not sure if the ISY pulls down the whole zip and works on the extraction locally or grabs in chunks from the uploading PC.
  7. Nope, left zipped, it does its thing just seems to hang on the insteon.jar I will try rebooting ISY and try again. other than that I have no idea. I seems to progress normally to that point.
  8. Ran into an issue. 83% through upgrade on Insteon.jar file errors out with following error "Upgrade failed:Uploading file [reported written size is invalid]. Did this twice so far at the same place.
  9. Thanks looks like win 10 was flagging as questionable file the right click worked and i had to overide the security to download!
  10. Hi Currently on 4.8.0 and trying to upgrade to 5.0.16 clicking on the link on the first page does not get me to a download image. Also tried searching online and i get redirected to that specific forum page. Am I missing something? It shouldnt be dthis diffucult to find the download file
  11. Yes, here is the result. Polisy Ip is 192.168.5.191 Welcome to Polisy![admin@polisy ~]$ ping 192.168.5.103PING 192.168.5.103 (192.168.5.103): 56 data bytes64 bytes from 192.168.5.103: icmp_seq=0 ttl=60 time=0.405 ms64 bytes from 192.168.5.103: icmp_seq=1 ttl=60 time=0.291 ms64 bytes from 192.168.5.103: icmp_seq=2 ttl=60 time=0.356 ms64 bytes from 192.168.5.103: icmp_seq=3 ttl=60 time=0.291 ms64 bytes from 192.168.5.103: icmp_seq=4 ttl=60 time=0.353 ms64 bytes from 192.168.5.103: icmp_seq=5 ttl=60 time=0.315 ms64 bytes from 192.168.5.103: icmp_seq=6 ttl=60 time=0.306 ms64 bytes from 192.168.5.103: icmp_seq=7 ttl=60 time=0.293 ms64 bytes from 192.168.5.103: icmp_seq=8 ttl=60 time=0.292 ms^C--- 192.168.5.103 ping statistics ---9 packets transmitted, 9 packets received, 0.0% packet lossround-trip min/avg/max/stddev = 0.291/0.322/0.405/0.038 ms[admin@polisy ~]$
  12. Hi Michel, Yes UDP traffic is allowed, Since these devices are on the same subnet on the same switch its not up to the router to ever forward the traffic. The devices will see it on the same subnet/vlan.
  13. Yes, I turned on mDNS and uPNP, no change, is this depenedant on a particular verion on the ISY?
  14. Michel, That is correct both reside on the 192.168.5.x network, this is a Ubiquiti Unif network. Unif Switch and USG. A PC on a differrent subnet. 192.168.4.x can http just fine to the ISY.
  15. ran the update but its not finding the ISY even after hardcoding, Same subnet . Tried HTTP login to verify user id and pass, works ok Here's the error from the log 2019-11-18 19:52:17 [polyglot] error: ISY: connection failed. Retrying... Error: connect ENETUNREACH 192.168.5.103:80 - Local (0.0.0.0:40531) 2019-11-18 19:52:17 [polyglot] error: ISY: connection failed. Retrying... Error: connect ENETUNREACH 192.168.5.103:80 - Local (0.0.0.0:54384) 2019-11-18 19:52:18 [polyglot] error: ISY: connection exceeded max re-tries. Aborting. Error: connect ENETUNREACH 192.168.5.103:80 - Local (0.0.0.0:52562) 2019-11-18 19:52:18 [polyglot] error: Get Version HTTP Error: RequestError: Error: connect ENETUNREACH 192.168.5.103:80 - Local (0.0.0.0:52562)
