Kemo
  1. The hub needs to be online and connect when using the app.
  2. To the thought of having separation, cameras/HA. I have just retired my Insteon hub after installing the ISY. I could bring it back just for the cameras. The app worked decent for camera control.
  3. I'm getting into adding devices and simple programming via the ISY. The cameras are a sticking point. In ISY you need a facet to control the position (Network Resources, Node Server) or Mobilinc $$$ to enjoy the features of automation via the phone... I'm not sure if Mobilinc X gives you full camera control. I appreciate the responses as I learn these systems... My ISY is working flawlessly so far.
  4. I would like to be able to control the camera from the ISY similar using Insteon interface. Don't know if that is possible.
  5. I have subscribed to UDI's portal just not familiar on how to begin to configure.
  6. Thank you apostolakisl.. Still learning to navigate isy. How do I use network resources? Where. would you find a blue Irus node server?
  7. Would like some direction on what I would need to control the foscam pan/tilt from within ISY. Is a nodeserver needed? If so which one?
