Everything posted by EGX
zwave devices lost after upgrading to 5.9.1
Thank you! It worked. I appreciate all the help.
I finally got the Z+ Smart Lock to be added to the Admin Console. Even though it was not showing on the Admin console I chose the delete option and pressed the discover button on the Z+ Smart Lock. The next time I tried the add procedure it added it to the Admin Console. The only problem now is it did not add it to the UD Mobile app. Should I just add it through the UD Mobile app or is there some other procedure to add it to UD Mobile?
I reconnected the Z+ Repeater and the Z+ Light Switch by trying the “Synchronize / New and Deleted” interview option under the Zwave menu. The Kwikset Z+ Smart Lock did not respond to the Synchronize option. After deleting the lock which even though deleted from Admin Console had to be deleted from UD Mobile separately. The problem now is when I run detect new device and press the sync button on the kwikset Z+ lock the Administrative Console Zwave menu says it’s detected but does not add it to the Network.
I was upgrading from firmware 5.8.4 The dongle I am using was purchased from UD Mobil which has two antennae. One is labeled Zwave and the other is labeled Zigbee/Matter.
Tried disconnecting for 1 minute. Did not work. Same error messages.
After upgrading to 5.9.1 when trying to access a ZWAVE device I got the following error messages. Could not open conf file to read - [./FILES/CONF/INSTENG>OPT] Could not open file - [./FILES/CONF/INSTENG.OPT] All my insteon devices were working after the upgrade but not the ZWAVE.
