ratgdo discovery with EISY Plugin
Yes, tried that bu cannot discover. Even tried Homelink plugin, but only open/close work. My 25i board works well, so I will just stick with that until the plugin is changed. Maybe the 32 disco is different
Have tried multiple firmware versions with my new 32 disco, but nothing works. No response from Weiland or Goose66
Introducing eisy-ai !!!
Done. Can I assume that if I have 2 different easy's at 2 different locations, that each eisy ai plugin requires a different api for the configuration?
My tickets site not responding right now, but want to let you know that the new anthropic api works. Pretty amazing so far.
Yes, I am using the latest version of the plugin and latest eisy firmware
I still get the same "sorry, something went wrong processing that" error and have not used any of my allowed $20.00.
I am just starting with the ai plugin. It is configured and working. However, just trying to get it to design a simple program adding days of rain over a week it says"sorry, something went wrong processing that".
UDM future
I watched the Webinar last night. Pretty amazing stuff coming, but what happens to geofencing/Occupancy if UDM goes to browser-based in iOS? Can it still connect to the phone's location? Also, would the new UDM format still be able to assign values variables to 2 separate eisy's?
Garage Door Mock Data.
I have used ratgdo board with the ratgdo plugin and it gives open/close, light, door status and others. Works very well. I also have the Yolink garage door sensor that gives open/close status as a backup. Yolink products seem better for longer distances.
Temp/Humidity sensor temp units wrong in programming
Thanks again
So I loaded the new plugin version in PG3 (AC side) and configured. Re-started the new version, then rebooted the AC and voila. It works. The beta version shows up as node 5 in the pics. Thanks!!
So install in PG3 (legacy) and test a program in AC?
ok
Absolutely!
Firewall in Mac OS
So using the portal to connect to remote easy should still work? I should set easy to accept incoming connections? Is that a security risk?
SHM
Joined
Last visited
