AERISWeather variabls no longer working correctly
Thanks Bob. No joy. I'll start a ticket.
I've just completed upgrading my Polisy firmware from v5.8.4 to v6.0.0. Now my emailed weather report of variables from my AERISWEather node server is giving incorrect returns for the "Day" and "Expected Conditions" variables. Before the fimware change, the currently misbehaving line of my emailed weather report output ... Looked like this: Monday's Expected Conditions: chance of Moderate thunderstoms Now it looks like this: 6's Expected Conditions: 16 0 30 The code I'm using is: ${sys.node.n001_forecast_1.GV19}'s Expected Conditions: ${sys.node.n001_forecast_1.GV11} ${sys.node.n001_forecast_1.GV12} Any ideas about whats going on, and how to get it fixed?
Polisy firmware update from 5.4.4 to 5.8.3 fails
I initiated the update from 5.4.4 to 5.8.3 and now my Polisy is no longer accessible via the IoX launcher and it's been knocked out, i.e. its not running any of its programs. I've cleared the Java cache, and reentered the URL into IoX in the correct format and no joy (the error message says "not found"). I know its on my network because I have a different locator app, which shows its correct name on the correct IP address, and it also shows up just fine my my router. I've also gone to my ISY portal, and it shows that my Polisy has been disconnected since I initiated the update. When I try to re-add it to the portal, it says its already there. I've also rebooted the Polisy several times with long waits, and still no joy. There are also no beebs when I do a cold boot - all three lights come on for a short time, and then the two on the right go off and the left-hand one stays on. There are also no beeps when I press the multi-function either, and no changes in the lights regardless of how many times I press the multi-function button. What am I doing wrong?
Default email service on my Polisy suddenly stopped working early thos morning
Neither issue is resolved at this point. I've put tickets in on both, but the response has been very slow - Michel says they are having an issue with their mail server, but he hasn't said when he will have it resolved. gmail is apparently not a solution either, and this thread shows several people also having ptoblems with gmail. My Polisy is supposed to be sending emails to my personal email domain. I'm especially concerned about havinig completely lost contact with my Polisy and knocked it out of service due to the firmware update attempt - I'm leaving town in a coupla of days, and my home automation has to be at 100% before then. Its very disconcerting to be having such slow responses from UD, and no announcement wither.
@Geddy: I've done several cold boots by pulling out the plug and waiting for several minutes before plugging back in. Checking the Wiki, there are no beeps when I press the multi-function either, and no changes in the lights regardless of how many times I press the multi-function button. When I do a cold boot, all three lights come on for a short time, and then the two on the right go off and the left-hand one stays on.
@Geddy: As I feared, I initiated the update to 5.8.3 and now my Polisy is no longer accessible via the IoX launcger. I've cleared the Java cache, and reentered the URL into IoX in the correct format and no joy (the message says not found). I know its on my network because I have a different locator app, which shits its correct name on the correct IP address. I've also gone to my ISY portal, and it shows that my Polisy has been disconnected since I initiated the update. When I try to re-add it, it says its already there. I've also rebooted the Polisy and still no joy.
See: [Ticket #24315] Default email service on my Polisy suddenly stopped working
I also got a bunch of delayed notifications last night, but this morning my expected notifications have not come in. I will start a support ticket.
Thanks Geddy: I'm on 5.4.4. Its been a too frequent occurance that when I've done firmware updates in the past, something gets changed in my Polisy that I don't know about, and I have to struggle through all my programs fo find out what went wrong and fix it. As a result, I'm reluctant to implement updates unless there's some speciflc benefit to me, that's worth the risk. In this case, an email was received successfully from one of my programs at 01:02 MDT today, but several that I should have received since then have not arrived. Including several tests. Here's what shows up in the error log when I send using the "Test" button in the Emails/Notifications Settings/Groups tab: Wed 2024/05/01 12:02:35 0 -170001 <s:Envelope><s:Body><u:SendTestEmail xmlns:u="urn:udi-com:service:X_Polisy_Service:1"><id>1</id></u:SendTestEmail></s:Body></s:Envelope> I've made no changes since 01:02 MDT, so I reason that something has changed external to my Polisy, to cause this problem. I've used a gmail account in the past instead of the default in Polisy, and I've found that its unreliable, often due to gmail's policy constraints. That's why I switched to the Polisy default, and its been relizble for years since then.
Email messages stopped beinbg sent out shortly after midnight MDT when requested by programs. I have rebooted, and syill no joy. Any ideas?
How to set an event to recurr annually without having to reset the calendar each time a new year rolls around?
I would like to program an event to occur on the same day and month every year. How do I do that without having to go into the calendar and reset the year each time a new year rolls around?
Cannot launch polisy Admin Console: Invalid URL
Thanks for the alternate URL format. It worked, but only after a rebot The URL fromn the ISY Portal was correct, but it still doesn't woprk. I've deleted it, as the alternate URL is working fine.
My Polisy has been accessible from my Admin Consule for the past 10 months with no problems. All of a sudden it went missing from the IoX finder. I added back its URL that I copied from my ISY portal, but now I get "Invalid URL" when I try to launch the Admin Console from that URL in IoX finder. I know my Polisy is working because the programs are running correctly, and I can also operate it just fine from UD Mobile on my iPhone. I can see it sitting at the correct IP address on my network using other locator apps.
Support thread for: ISY on Polisy (IoP) v5.4.4 (May 25, 2022)
That's exactly what I was looking for. Many thanks.
The top of the display frame of the IoP admin console on Polisy shows the date. Does anyone know how to get access to the date (i.e. the calendar) in IoP, so that actions can be triggered by date and time, and not just by time?
CoLong
Joined
Last visited
