roberthleeii
  1. I have removed all of my Insteon devices from my house. Can I uncheck the insteion support in my ISY configuration? (Without causing any issues) ISY on Polisy Thanks in advanced, Robert
  2. thank you, I can do that but I am trying to see if UD can automtically replace the old device with the "new" one so i do not have to re do all of the program and naming of the nodes on each device.
  3. i don't know what update with interview means... i tried to replace one of the "broken" z-wave device by right clicking on the failed device and replace it in the z-wve menu but that did not work. It deleted the device and did not add the new one....
  4. How do you correctly replace a z-wave device? I had a little problem with my polisy and it was down for a couple of days. During that time I factory reset some of my zen32 switches so i could turn my lights on and off. Now that my polisy is working again is there a way to replace them so I don't have to start them as new devices
  5. @Michel Kohanim has already started messaging me through my UD support ticket. That is amazing customer service on a Sunday 😁😁
  6. 🤷‍♂️ nope. still seems like no services are actually running 🤔
  7. @DennisCThank you for your help, I did change cables. 😢 but not good... I opened a ticket earlier but am trying to get it sorted sooner rather than later incase it takes them a long time to reply. Thanks again.
  8. they don't work.... no services seems to be running.... i don't really know what i am looking for but this is what processes seem to be running on the polisy when I ssh in
  9. It is like the Polisy is running but the polygot i no error lights are on. Only the left most light is on and nothing is blinking. Just in case I reconnected the network cable to see if anyting was loose or bad. did not help 😢
  10. @TRI0N Thank you, That address does not work for me. (yes I did put my correct IP in there) Any other ideas?
  11. @DennisCThanks, yes, i did try all the steps from both wiki's, IP is the same, i can see it from my router and i can access it from ssh I don't not know how to check if the port has changed....
  12. @DennisC Thank you for your reply but it did not work. I followed all the directions above. I still cannot find the the ISY(Polisy). SSH still works so it is running.... one of the final steps in the above instructions is to reboot the polisy and when i did that i noticed that I never heard any beeps. any other suggestions to get things working?
  13. small update I was able to ssh in to the polisy and log in using the default admin username and password (not the password I usually use to log in to the dashboard). (first time ever doing that) so at least there is life in the polisy.....
  14. I think I have a problem. I logged into the admin console to look at something and noticed that there was an update available and with out giving much thought clicked the update automatically to 5.5.9.... button. I heard some beeping from the other room where my polisy was and thought all was good. I cleared my java cash, updated it. after a bit I realized that my lights were not working and went to log in and see what was the problem and the polisy is not showing up... there is nothing there. I have not been making any changes to my ISY for months and forget all the little nuances to get things working. Thanks in advance for anyone who can help me.
  15. When I get this board installed and my Polisy updated in November will I be able to add ZigBee devices or will that come with the Matter update at some point in the future? i am assuming this board comes with the antenna to make the radios work?
