EWhite
  1. ESPHome would prolly be WAY better....this tasmota thing was a bandaid to make it work under the "at the time" restraints of EISY and lack of support for ESPHome at the time. I would gladly change it over ESPHome if it was available. I changed all my RATGD over to the ESPHome side and love the results from it...works way better with less interaction needed "i.e. babysitting the damn things"
  2. I think that since this device uses MQTT you will never get an immediate response. for me it was not a big deal....i dont need to know the EXACT moment something happened...it just had to be close. im not sure what other devices are out there and if the offer the same detail you want, along with working along side EISY.
  3. post #2 of my writeup.... you can change this to whatever you want in seconds for reporting...not sure you will ever get "real time" reporting as i would think it would overwhelm the MQTT server with messages...
  4. let me look at whats going on better....
  5. EWhite replied to roho's topic in YoLink
    BOY HOWDY!!!! i cant wait! This will make me more likely to buy more yolink stuff
  6. mine upadated after waiting for 5.9.1, it would not update before that....
  7. upgraded wired polisy here..no problems.. alll working as advertised. it did go through all my plugins and re-install them all...so it took a while for all that to work again.
  8. EWhite replied to CoolToys's topic in eisy
    i just set DHCP to give ip addresses by mac address...static mappings....in my firewall. i dont use over the counter routers so im not sure they can handle that or not.
  9. that seemed to fix it so far...just gotta tweak on my side now. thanks much!
  10. hahaha.. no problem...sorry to be a PIA.. but glad you are around to do this stuff...
  11. am trying out the console version.. i like being "local" its not working.. so here is a debug log AmbientConsole_1-13-2025_91800_AM.zip
  12. im still not updating...several of my other plugins have updated with no problem. im just in wait mode until new firmware/os come out.
  13. EWhite replied to EWhite's topic in YoLink
    yes.. i think thats what i did... i actually set log to debug, then tried to upgrade, so it restarted on its own.
  14. EWhite replied to EWhite's topic in YoLink
    here it is..hope this is what you need YoLink_11-16-2024_23756_PM.zip
