auger66
  1. I just tried this, and it sort of works. Two devices were added: a ZM 002.1 On-Off Switch and a ZM 002.1 Thermostat. I don't have any sort of Google Hub, which I thought was required to link a Nest thermostat. The "switch" turns the heat pump off or back to its previously set mode. The thermostat seems to work, except for "fan only." Unfortunately, that's one option I need. "Fan only" returns an error code. I can change the temperature. Almost there. Just got back in town after being gone for several months. Upgraded last night to IoX 6.0.3 and PG3x 3.4.6 before adding the Nest to Matter today. Edit: There are several options that return an error code besides "fan only."
  2. auger66 replied to xKing's topic in Hue
    It will be a couple of months before I get home to check this out. I just wanted to say thanks for keeping this plugin alive. The old plugin has been great.
  3. Like the OP said, you could "delete all devices" in the web interface, but Amazon did away with web access a year or two ago. I used it to clean up my device list when adding services created duplicate devices. Then, "discover all." It was a handy function.
  4. A few years ago, I needed to replace several old Insteon leak sensors. I almost bought six but ended up transitioning to YoLink. I've been very happy with them, and the YoLink plugin for the eisy. YoLink operates fine separately without the plugin if you're still running an ISY. I got a couple of YoLink valve controllers and a temp sensor later. Everything works great.
  5. Maybe because it's not supported? Here's the list from their Polyglot page. Current list of devices supported is as follows: 'Switch', 'THSensor', 'MultiOutlet', 'DoorSensor','Manipulator', 'MotionSensor', 'Outlet', 'GarageDoor', 'LeakSensor', 'Hub', 'SpeakerHub', 'VibrationSensor', 'Finger', 'Lock', 'Dimmer', 'InfraredRemoter', 'PowerFailureAlarm', 'SmartRemoter'
  6. FWIW, webhooks and API update from Ubiquiti https://www.youtube.com/watch?v=O0kFYrADutI
  7. Probably/maybe. I think every software company claims "security" when they don't want to do it. Plus, Google has done almost nothing with Nest since they bought it. Funny how some companies can make APIs safely and some can't/won't. Regardless, the new thermostat has Matter, and that's probably going to be the easiest way to integrate Google into UDs ecosystem now.
  8. auger66 replied to GTench's topic in YoLink
    Yep, I forgot about this. Mine updated automatically.
  9. I saw that, but I still had to try. 🙂 Nest thermostats haven't had a working plugin in a long time. Since it's such a big gap in UDs integration, hopefully it will get a little Matter priority.
  10. IP via wifi
  11. I tried to add the new Nest thermostat (Matter) with the updated UD android app via QR code. It wouldn't add. I didn't think it would work through my non-border router, but I had to try.
  12. Followed the directions. After upgrade, my eisy was offline on the Portal, UD mobile, locally, etc. The eisy did show up on my network at the usual reserved DHCP address. Eisy also did not show up the ISY finder, even if I typed in the local IP address. I tried run ssh in windows and putty, but it wouldn't allow me to paste or type in a password. I repowered the eisy as felt I had no choice. My eisy showed up immediately in the ISY finder, and I was able to log in without issue.
  13. auger66 replied to EWhite's topic in YoLink
    I have the same issue.
  14. I just installed the new Nest thermostat and Nest plugin. I have the same problem as the OP.
  15. I can't try it until I get home in three months, but I definitely will. Thanks for your effort on this.
