CGohring
  • Posts
    8
Everything posted by CGohring
  1. Just a quick update. we are now 48hours in, and I've had no more errors. - I dont know what is different now, but I'm happy its working. - Thanks again.
  2. Seems to be working fine this morning also. I will mark this as closed. - Thanks again for your help.
  3. Bob, firstly thank you very much for trying to find the error here. I had reinstalled and re-paired on my previous attempt, but I figured if you got it to work, I should give it another try. So, I deleted the Caseta Plugin in Polygot, rebooted the Eisy, re-installed Caseta 1.0.9 (paid license version), configured the IP and re-paired the bridge and then did a final re-boot of Eisy just to be sure. - And it worked Initially... I figured I should test thoroughly and watch the log, and I did. I sent activate commands to the different scenes I had set up for my blinds, and they tilted back and forth nicely for 10 minutes without any issues... So, I felt comfortable starting to work on rebuilding the programs I had built to control them based on the sun's azimuth. And then it failed. The error log is a bit longer this time, so I've attached the zip file instead of pasting it here. I rebooted Eisy, and it works again... (20 minutes of testing and counting). I'm shutting down for today, but I will update tomorrow either way. - Thanks again for your efforts. Caseta_6-17-2024_54514_PM.zip
  4. Hi, Yes you are correct. I actually posted this in the "Support thread for: PG3x v3.2.27 (June 11th, 2024)", as I believe that the issue started when I upgraded the Polygot to 3.2.27 (I'm 99% certain). - I also had issues with my NOAA plugin at that time, but they released an update quickly to fix it.
  5. Im having the oddest issue with the Caseta plugin. - it works briefly after a restart of EISY, but then stops working after a couple of commands or minutes. - I did try to reinstall the plugin. - obviously that required a restart so it worked, but again only for a couple of minutes. There is an error message in the error log, but Im not savvy enough to interpret it. 2024-06-17 09:49:16.083 Command udi_interface.interface ERROR interface:_handleInput: _parseInput: failed scene12.runCmd(DON) Traceback (most recent call last): File "/var/polyglot/pg3/ns/0021b9026099_10/.local/lib/python3.11/site-packages/udi_interface/interface.py", line 967, in _handleInput self.nodes_internal[item['address']].runCmd(item) File "/var/polyglot/pg3/ns/0021b9026099_10/.local/lib/python3.11/site-packages/udi_interface/node.py", line 178, in runCmd fun(self, command) File "/var/polyglot/pg3/ns/0021b9026099_10/nodes/base.py", line 40, in activate asyncio.run(self.sb.activate_scene(address)) File "/usr/local/lib/python3.11/asyncio/runners.py", line 190, in run return runner.run(main) ^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.11/asyncio/runners.py", line 118, in run return self._loop.run_until_complete(task) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.11/asyncio/base_events.py", line 654, in run_until_complete return future.result() ^^^^^^^^^^^^^^^ File "/var/polyglot/pg3/ns/0021b9026099_10/pylutron_caseta/smartbridge.py", line 455, in activate_scene await self._request( File "/var/polyglot/pg3/ns/0021b9026099_10/pylutron_caseta/smartbridge.py", line 249, in _request raise BridgeDisconnectedError() pylutron_caseta.BridgeDisconnectedError
  6. Upgraded EISY - No issues once I remembered to delete and reinstall the Java admin panel.
  7. @keepersg Thank you very much, it was mostly a question of removing the devices first. - A couple of door locks had to be moved closer to the Isy for the "adding secure device" to work, but other than that it was patiently removing the device once or twice and then adding it back in.
  8. I have the same issue. - obviously I didnt read the instructions on 5.3 and went ahead and updated with the 300 dongle. - and thought I fried it as when I restored back to 5.15a I could not add my Z wave devices back. - I thought the solution was to buy a new ISY with a 500 board, but even with that (now upgraded to 5.3) I have been able to add only 1 Z wave device. - the rest simply don't register. - (and given that I was able to add 1, I know the board is working. - I tried the reset, the syncronize nodes, the restore PLM etc. - I even moved my ISY downstairs 5 ft from the next outlet I want to add (away far from the wifi router that I thought might be interfering), to see if it made a difference, but I hit the "add a z wave device" it says "listeninng for z-wave devices to add to the network", I hit the button on the switch and... nada... nothing happens. - Im going out of my mind here, any advice would be very much appreciated.
  • Create New...
