Eisy just dead? After it was attempting an update??
LOL, neither have I. With all the interaction between the Eisy and other devices, it has been just running. I do updates on devices, etc and always gen a backup. When we lived with my dad caring for him for 11 months in another city, I was able to access Eisy and use it to make our house look lived in, and check on house heat/cooling, etc. I still find that pretty remarkable. A monitor mount is on its way from Amazon. It will stay there and there will be ready.
I should mention. I don't know why but in Home Assistant, all of the helpers that I created to convert switches to lights were gone. I had to recreate them.
Oberkc, Yeah my usual would be unplug and plug it back in. I did try that at first but nothing worked. The blue light was lit so the box was operational just not in a usable state. Michel had me connect up the monitor and keyboard and press the power off and then back on. That final screen gave him enough info to help me. The 994i and the eisy have been so reliable that I really don't mess with it at all. I use the java interface to code devices etc and backup, and UD Mobile to activate lights manually when I need to.
I wasn't able to get to eisy at all. No network connect. I created a ticket and Michel responded! I didn't expect that, it's Christmas Eve. I dug up a monitor and keyboard and he gave me the entries to complete what appeared to be an incomplete update. It's back up and running. Thank you Michel! I'm not sure why it was updating but it appeared to have started one. And it had gotten to a couple of hours so it wasn't a completed update. I first noticed it when I finished a brisket in the smoker at 5am and walked up to the back door with a hot brisket in my hands and the lights didn't turn on. There will now be a monitor, keyboard, and mouse mounted in my network/home automation area and with KVMs to systems.
Bladerunner started following Eisy just dead? After it was attempting an update??
I had not updated my Eisy yet. Yes, I am very late on that. Family things and house things needed fixing and Eisy was working just fine. So tonight, I noticed some things not working. They are through the Eisy. Usually, this is just the Eisy losing connection to HA and HA can't turn on a light when I attempt a voice command. As I checked the Eisy, it says it is updating. And that update never finishes. So it's no longer available, it still has a nice blue on/off button on the front though. I did just open a ticket. Any ideas how to proceed? A wiki that I haven't found or just wait for a ticket response? This kills a lot of stuff in my house. Eisy is integral.
Bladerunner started following bdraco
How to replace an old X10 module with a new Insteon module in Eisy?
i recently replaced an older X10 Pro inline device with a new Insteon inline device. So, the definition in Eisy is wrong for that device. It still sees it as an X10 device. Is there any way to replace a device in Eisy with its new configuration? I only see where you can set the device type as you enter a new device. If an Insteon device is set to issue an X10 command, does it not act or identify as an Insteon device? I have several Insteon devices that are set to issue X10 as that was the basis in my old Homeseer system. These all should be changed to the appropriate Insteon device.
Bladerunner started following Guy Lavoie
Motion Sensor not reporting violation in ELK plugin, but is violated in M1 Status.
After a session where I went into PG3 and looked at ELK where it reported no nodes (not sure why), I went ahead and shutdown Eisy and restarted. When all came back up, ELK reporting 38 nodes instead of the 39 I had seen earlier. The only thing Jim could conclude was that when I had switched the light setting to NONE, it reduced a node. My guess, my assumption, is that my incorrect setting caused issues. That exterior battery powered motion sensor was the highest number in my connected sensors. It is also possible, I am guessing, that my batteries could have been weak in that sensor. So after switching out the batteries and setting that variable in ELK correctly, the exterior motion sensor is reporting correctly. It even reports the opening of the sensor as OPEN and Violated vs SHRT and Violated. So, it's corrected now and Eisy will turn on the back porch light when it sees the motion sensor violated as it should. Small steps...... Happy to finally be off the ISY994i to get things moving. I hated to leave it as it was totally solid but having UD Mobile and more options is great in Eisy. Thanks, Jim, for your support!
I did just try my shed sensor. It is the same Elk Two Way wireless tech as the basis of the motion sensor. It however, does reflect the violation. The mystery deepens!
@kzboray There's communication. I can see other sensors go from normal to violated as expected. And quickly. Impressive. I can even set the alarm to stay mode through UD Mobile, and also set my RCS thermostat attached to my Elk. It seems there's something odd about this sensor state. It is the only wireless motion sensor I have. It is on the Elk two way wireless protocol.
Jim, log sent. There are references to zone_35 which is the zone in question.
I have just migrated to Eisy and loaded the ELK plugin. Working through issues so I can get to using Elk M1 sensors in statements in Eisy. The unit is the https://elk-datasheets.s3.amazonaws.com/ELK-6032-Data-+Sheet.pdf It worked well in my ISY994i where I used it to turn on my back patio light. In the M1 status window, it will show violated. It reports EOLR normally and then Shorted when violated. No voltage report. However, in the ELK plugin there is no reaction. The board in the Optex sensor is an Elk two way transmitter. This is the Elk two way wireless system. I tried setting the Send On to Short but that made no difference. Just a guess, I'm too new to Eisy and the plugin, Has anyone had a sensor not respond and corrected?
Bladerunner started following xKing
What low voltage switch plate to use with an Aotec Nano Dimmer?
I am considering using the Aotec Nano Dimmer and Switch. I primarily wanted to use them as in box controllers with no switches. However, they seem appropriate to use with wall switches as well. However, I have read some bad things on their swipe plate. Has anyone found a great slim double throw momentary that doesn't take up too much room in the box and leaves space for the Nano? Any input appreciated. I have googled but not found a home acceptable switch for this.
Keeping program execution in order
I'm brand new here. I have previously lived in the Homeseer world since it's start. I have mostly still X10. So my programs set several X10 lights off. I have some waits in between these X10 commands. At the end of the program, I have the Elk speak "Done". However, the Elk "Done" comes out quickly and the X10 commands are still executing. Is there a way to make the program wait until the X10 command is complete? Thanks.
Bladerunner
Joined
Last visited
