bachguy40
Everything posted by bachguy40
  1. Upgraded to 3.1.3 with no issues. Thanks!
  2. Easy update from 2.8.16! No problems here.
  3. Not fixed until 2.8.0, but yes, it is now fixed.
  4. bachguy40 replied to denpri's topic in ISY994
    denpri, As you can see, I noticed the same thing back in February and received no replies. I will keep checking back to this thread for any positive results on your end. http://forum.universal-devices.com/viewtopic.php?t=4069
  5. Thank you for your answers, and please excuse my confusion. When in the admin console, if I select the motion sensor, click "Set Options", it asks me to press the SET button, which is of course INSIDE the sensor. I was under the impression that the advantage of setting Jumper 5 was that the settings were controlled by software, and you wouldn't need to open the sensor, where there were setting wheels anyway. Am I missing something? (probably)
  6. Does the setting of jumper 5 in the Insteon Motion Sensor have any effect when using the ISY?
  7. Is there a trick to scheduling a program to only run, say, during July through October? I'm not sure if this is possible, as the "If" portion only allows for SPECIFIC date ranges, not something that can be left to repeat every year. As always, any help would be appreciated. Frank
  8. I recently replaced my original SD Card with an 8GB card. I followed all of the procedures outlined in the user guide .pdf and all is working successfully. I even copied all of my web files and folders (I have the networking module) with no problems. I am using firmware 2.7.10 When I check Tools--> Diagnostics -->File System status, the total reads 3665 MB. I have checked the SD Card with my pc's card reader, and it is indeed an 8GB card. Have I done something wrong? How do I get the diagnostics to see all 8 gigs? Thanks in advance for any help you might provide! --Frank
