Virtual Device Nodeserver expose Integer Variable
Well, speaking of kWh, yea that too from my Rainforest whatever it it HAN device reading my meter. This instance here is I average lux from 3 Z-Wave nodes and use that to turn my outside lights on and off. I'd like to display that averaged integer value on the home page. Yes, I'd use a Set action in a program to update the value.
Yeah, I think I saw somewhere variables in eisy-ui are in the future. I tried hacking with like the minimum off/on time for a toggle and while I can set it to 900 but can't set that to display in the upper right of a tile plus can't change the units. Guess I'll just have to wait. BTW if we could get free-form on the tile alpha/num title, so it can be different from the node/device name that'd be cool too.
Thanks Guy. I'm actually looking for something (an integer) from 0 -900. While as you spoke of I didn't see a raw integer type but I did see mention of type val integer so I was trying to hack my way through to a type of integer. Yeah, I thought of using another object but then it's gonna create all the nodes I don't need for that object. I was hoping to find just a generic type integer. I haven't fooled with generic to see what comes along with that...
Newbe to Node Servers. I want to expose a raw Integer Variable value, no data type that I can include in my eisy-ui Home Page. I did this with a Temperature type and that worked fine. I just need to get the one integer value out of isy. I'm having troubles getting the correct syntax for the Custom Configuration Parameters, Value field. Can someone give me an example? Thanks.
GJ Software Products started following eisy-ui
GJ Software Products started following How do you determine if Zwave LR is actually LR
GJ Software Products started following ZMatter
GJ Software Products started following Let's discuss backup strategy , Matter for Dummies II ? and Matter for Dummies?
Kind of scary. Update to 14.3/IoX 6
I did the upgrade to 6 & 14.3 this morning, took maybe ~15 minutes, all appears to be good. Lot's of Z-Wave, bit of Zigbee, & two Inseton nodes & Elk. All looks to be working.
eISY MODBUS TCP Plugin Help needed
I've Never seen an Outback Inverter, now I gotta go looking! <lol>. Done a lot of Modbus with Square D (Schneider) PLCs, iON Electric Meters, UPSs by a couple manufacturers, ABB VFDs, Onicon Energy Meters, Caterpillar Generators, a few other off the wall integrations to Niagara but never seen an Outback Inverter. Is that used with pV(solar)?
I too would like to better understand the format of the JSON file, where it goes, and how it integrates. I.E. the format to define the registers, how to point to the address of the slave/RTU device, and how to access the nodes using isy. Some reference documentation would be great. I'd like to talk to my eisy with a SQD PLC using Modbus but without *any* documentation I really don't know where to begin on the eisy/pg3 side. Just need a bit to get me started without loading the node server and fighting my way through it.
Support Thread: IoX v5.9.1 (2/10/25)
Followed the instructions, all went well, it does take a bit to update & re-boot, I had to re-boot again. Clear Java cache so you get the updated admin console and that's about it. All seems well so far. -Grant
ZOOZ ZSE42 v1.0 w/ 700 Chip difficulties
So, I just found out that the child proof coating on Duracell CR batteries is known to cause connectivity issues. That was apparent there was a voltage problem, but I kept checking with a few different batteries and they all read ~3.0v but maybe the holder don't like 'em. Now I just gotta find something besides Duracell. Sounds like a trip to Home Depot tomorrow. I'll post if this works.
I've had 1/2 dozen or so if these devices for a couple years now, they all used to work fine, but now at 5.8.4 the behavior has gotten strange. The other day one triggered when it detected moisture, then testing the others they did not trigger, they wake up when they feel like it, I excluded and re-included, they came in as a wake device(maybe just saw the one property?), I continued to fool with them, one after I had the battery out for ~! hour, let me include it in as a leak detector, it worked for a bit, but then it stopped working after I ran it through a few wet/dry cycles. Has anyone else had recent difficulties with these ZOOZ LSE42s? Got any recommendations? Thanks.
Replace eisy and/or Matter dongle with new one
Digging deeper I found it needed a Firmware Update to get HDMI working. Updated the firmware and wahlah! Console output visible on HDMI port again. But I still should have a backup system to bring online in case of a failure.
@DennisC Thanks. You're right. I'm referring to the Z-Wave/Zigbee USB Dongle from UD. I figured that'd have to work but I'd read so much (or just enough) to make me uncertain if the full backup would maintain what I think is called the Home ID of the system or if I'd have to reinitialize every Z-Wave device because the original Home ID wouldn't persist. Thanks again for your input!
The HDMI port for the console output on my eisy stopped working. I've been thinking about this for a while, if I've got a complete backup, I.E. backup the dongle first then backup the eisy to a file on my HDD can that be restored to a new eisy and/or new dongle without having to discover and join each zwave and zigbee device over again? Let's say the eisy fails and I get a new one. What's the procedure to recover? Likewise for the Matter dongle?
Time change issues (end DST)
Same thing here...
Elk Failed Connection Notifications on Mobile App
I'm still intermittently getting this error as recent as 3/9/24. 5.8.0_1 , 3.2.19 , 3.10.15 .
