STIM141
Everything posted by STIM141
  1. Issue resolved. Tech at UD was VERY helpful and had me update my SSD to the lastest version - now have V3 and it finds it.
  2. Last owner's password now works. Can access via browser. Have to go through configuration to get it to work with IOX start etc. Seems to be running old version of firmware/software. At least it boots and I can access the system now. The reset button procedure still does not work - don't know if it is the physical button or the firmware. Going to be a project.
  3. Yes, using IP address from router I tried entering admin as password and it won't login. Tried a password supplied by the orig owner - didn't work. Unit has booted and its communicating but password is a problem. Tried doing FULL reset with the front button but the instructions of holding the button until three lights blink didn't work. Button works because once the thing eventually boots up with a single led I pressed the front button - it displays 2nd LED lit and the third beeps twice or three times then only 1st stays lit. Pressed and held for a LONG time no three lights on and blinking. Tried a few times.
  4. Yes tried last night admin/admin won't work. Spoke to 1st owner forgot password. Tried doing complete reset with front button. Cannot get all three LEDs to blink. Can get 1 2 solid and 3rd tool either blink 2x or 3x. Beeps when pressing or releasing. I submitted a ticket Fri night. Don't think button is bad but something doesn't seem right.
  5. Well... I got somewhere. Entered the IP address and got to the Polyglot 2 login screen but cannot login with ADMIN/ADMIN - previous owner must have changed password. Tried the reset button as indicated in the manual but it will not reset. Press and hold the button. You get the first light (SOLID) Second light then third (that blinks twice). Held it for almost a minute - no change.
  6. Received a pre-owned Polisy Pro but cannot access it in IOX Start. Boots fine (beeps - three lights, then two then one solid green) and it is showing up on my Netgear Router. Tried doing a hard reset with the front button but it doesn't seem to work. Press the button at the front and hold the button but it does not produce three lights as indicated in the instructions. IOX finds my ISY994i no problem Any idea to get access or is something wrong with the box? Rear ethernet port shows activity.
  7. Purchased a Wayne Dalton Wireless Gateway WDHA-12R. Basically want to use my car's HomeLink to activate a scene or module from within my car. Currently using an X10 remote as the programmer and a PAT01 or PAt03 X10 module as a trigger. They work - their range isn't that great and I want to get rid of X10 and Insteon from my network. Does anyone know how to program this module. In the manual its says you have to copy Scenes and Network from the primary controller (ISY994) to the gateway. This is the part that doesn't make sense. When I try to add a Zwave module with the gateway plugged in it does find it. But thats all. Any help would be appreciated.
  8. Have a few ZWAVE Ge/Jasco Toggle/Paddle Relay (ON/OFF) only switches that link in ISY994 and work via the console and show ON and Off in the status area. When you switch ON or OFF at the switch the status never changes? Insteon and other ZWave + switches do this. If you QUERY it will then show as ON or OFF. It just doesn't refresh when it is switched ON or OFF at the switch. Is this normal or am I missing something? Thanks - fairly new to Insteon and the ISY994
  9. Thanks - I'm running v4.9.0. Does the light on the 300 board do anything - aside from lighting up and turning off once the ISY is booted? Mine lights up then flashes then turns out. Is this normal? Thanks.
  10. First ISY-994 ZW/IR Pro. Successfully connected some of my INSTEON switches/dimmers without a problem. What is the blue led light on the back of the unit? When first powering on it lights up then blinks a couple of times then goes out. I'm now trying to connect a Zwave device which is about 30 feet away - the light stays off and can't find it - think its too far away. Will purchase a plug in and try that next with repeater built in. My question - is the light supposed to turn on and stay on at some point. Manual doesn't really say anything. Thanks.
