Our Gray House changed their profile photo
Zigbee - Confirmed Working Thread
@ShawnW, My bad for not coming back on this forum and updating you. I did open a ticket on this and one of the log files they requested from me led the developers to find the bug and include a fix in the 5.7.0 release. I've got the color nodes for all my Sengled bulbs now and am using them! Appreciate the follow-up! -Mark-
Hi @ShawnW, Did you ever get the color node to appear? I'm having the same issue where I only get the On-Off Switch. Same bulbs as you. Running IoX 5.6.3 on EISY.
ZOOZ ZEN31 RGBW Controller
pyrorobert, make sure that the color values are not 0,0,0 when you turn it on. I have two of these controlling LEDs in the eaves of our house. They always fall back to 0,0,0 on the color when I turn them on. I set all my programs to turn them on then set the color.
Won't Update to 2.0
Thanks for the updates. I think I'll just keep the version I have for now since it works and I have a lot of programs that use that node server. Hopefully it will resolve itself at some point.
Won't Update to 2.0
Logs sent. Followed your steps, to install from the node server store then click re-install. Messages show it re-installing but the node server still shows ver 1.0.4 after it starts.
Won't Update to 2.0
eisy, PG3x 3.1.25, IoX 5.59 PG3x tells me there's an update for Holidays Google. When I click the update button, it shows that it's updating and restarts but the version doesn't change from 1.0.4 and eventually the message comes back that there's an update available.
Ecolink Zwave Tilt sensor
That's the same one I have. I had to keep it awake by taking the cover off and do the Synchronize / Update with Interview a few times to get all the nodes. I also brought it in close proximity to the eisy to do that.
I have one that's a few years old that I got to work on the eisy. As with all my battery devices, I had to exclude it then include it to get it to work. These are the nodes that showed up in the AC: Here's the program I use to detect if the door is open. The "Access Control Alarm" only shows "Window/Door is open" or "Idle". I could only detect the former in a program so I used this program to send a Pushover message. I had to use the state variable to allow Alexa to detect if my garage door is open as I have Alexa make an announcement when the door is open. Maybe someone else has a better idea on how to accomplish this. I had similar results with Zooz Open/Close sensors on my gates. If 'Garage / Garage Door Sensor / ZY 157 Access Control Alarm' Access Control is Window/door is open Then Resource 'Pushover_Garage_Open' $Garage_Sensor_State = 1 Else Resource 'Pushover_Garage_Closed' $Garage_Sensor_State = 0
