JBoettcher
  1. New issue noticed after upgrade: Seems my static IP on the Eisy is missing, and it is set for DHCP. All works fine, and the finder discovers the Eisy, but I cannot turn off DHCP and re-code it with the IP I prefer it to have. I added a reservation in the router, and while it gets the IP i want it to have, it does not show in the configuration... Just FYI - it is fully operational.
  2. Please be aware that 5.7.0 on Eisy - Following the Upgrade, all scheduled tasks were set to disabled. It was a simple matter to re-enable them after I discovered that they were all off. Jeff
  3. Upgrade to 5.1.1 was smooth and successful. Thanks for the update
  4. JBoettcher replied to JBoettcher's topic in IoX Support
    For anyone Looking - the 5.0.3 ISY for Polisy has solved the problem!! It appears that a new USB driver for the PLM has been added.
  5. JBoettcher replied to JBoettcher's topic in IoX Support
    FYI - USB PLM from Smarthome is 2413U Rev 2.5 3718
  6. JBoettcher replied to JBoettcher's topic in IoX Support
    Same situation here. Insteon Check is enabled. Just Tried 5.0.2 and same result.
  7. JBoettcher posted a topic in IoX Support
    I have the Polisy configured, and the 2413U PLM connected; but in the administrative console, Tools, Diagnostics, PLM Info/Status section, it reads 0.0.0 v0 Not connected and the Policy will not discover any Insteon devices. Have I missed something? (BTW - Insteon IS enabled in the configuration)
