Everything posted by renatohtpc
An existing connection was forcibly closed by the remote host. [hwalrm1]
I am currently running NodeLink Server v0.11.3 on a windows 10 desktop. Here are the .net details: dotnet --info .NET SDK (reflecting any global.json): Version: 5.0.402 Commit: e9d3381880 Runtime Environment: OS Name: Windows OS Version: 10.0.19044 OS Platform: Windows RID: win10-x64 Base Path: C:\Program Files\dotnet\sdk\5.0.402\ Host (useful for support): Version: 5.0.11 Commit: f431858f8b .NET SDKs installed: 5.0.402 [C:\Program Files\dotnet\sdk] .NET runtimes installed: Microsoft.AspNetCore.App 5.0.11 [C:\Program Files\dotnet\shared\Microsoft.AspNetCore.App] Microsoft.NETCore.App 3.1.6 [C:\Program Files\dotnet\shared\Microsoft.NETCore.App] Microsoft.NETCore.App 5.0.11 [C:\Program Files\dotnet\shared\Microsoft.NETCore.App] Microsoft.WindowsDesktop.App 3.1.6 [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App] Microsoft.WindowsDesktop.App 5.0.11 [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App] To install additional .NET runtimes or SDKs: https://aka.ms/dotnet-download I have configured NodeLink to use with a Honeywell Alarm Panel. Yesterday, I noticed that the application was generating large volume of the following (error) messages. 2022-03-15 08:41:49 - ISY NodeLink Server v0.11.3 started 2022-03-15 08:41:49 - OS: Microsoft Windows NT 10.0.19044.0 2022-03-15 08:41:49 - Installed .NET Runtime Version: 5.0.11 [5] 2022-03-15 08:41:49 - Web config server started (http://192.168.1.70:8090) 2022-03-15 08:41:50 - ISY resolved to 192.168.1.60 (5.3.4) 2022-03-15 08:41:50 - ISY Node Server config detected (profile 1) 2022-03-15 08:41:52 - Hon TCP Error: Data Arrival Init - An existing connection was forcibly closed by the remote host. [hwalrm1] 2022-03-15 08:41:52 - Relay Server: Started on port 2405 2022-03-15 08:42:22 - Hon TCP: Reconnecting To Server [hwalrm1] 2022-03-15 08:42:22 - Hon TCP Error: Data Arrival Init - An existing connection was forcibly closed by the remote host. [hwalrm1] 2022-03-15 08:42:52 - Hon TCP: Reconnecting To Server [hwalrm1] 2022-03-15 08:42:52 - Hon TCP Error: Data Arrival Init - An existing connection was forcibly closed by the remote host. [hwalrm1] 2022-03-15 08:43:22 - Hon TCP: Reconnecting To Server [hwalrm1] 2022-03-15 08:43:22 - Hon TCP Error: Data Arrival Init - An existing connection was forcibly closed by the remote host. [hwalrm1] Any suggestions on how to address this? Thanks Renato
Constantly losing connectivity
I believe I have resolved the issue. Posting the answer so that other could benefit..... As it turned out, the micro SD card was the culprit. Replaced it with a new 32GB one (that's all I had available) and now I am off to the races! Renato
I have been running running 5.3.3 for a few months without any problems. Today weird things started happening...... 1) I added a new Insteon outlet. Went to the Programs tab and noticed that ALL of them were gone!!!!! After trial and error, I shut down the ISY, power cycled the PLM and restarted the ISY. Voila, the programs automagically re-appeared. 2) Later in the day, I clicked on the ISY Admin Console. Got an error message. Cleared the java cache and started the admin.jnlp. It failed with the following error: The details show the following: com.sun.deploy.net.FailedDownloadException: Unable to load resource: http://192.168.111.60/admin.jnlp at com.sun.deploy.net.DownloadEngine.actionDownload(Unknown Source) at com.sun.deploy.net.DownloadEngine.downloadResource(Unknown Source) at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source) at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source) at com.sun.javaws.Launcher.updateFinalLaunchDesc(Unknown Source) at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source) at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source) at com.sun.javaws.Launcher.launch(Unknown Source) at com.sun.javaws.Main.launchApp(Unknown Source) at com.sun.javaws.Main.continueInSecureThread(Unknown Source) at com.sun.javaws.Main.access$000(Unknown Source) at com.sun.javaws.Main$1.run(Unknown Source) at java.lang.Thread.run(Unknown Source) If I try and ping the ISY, it is successful.... 3) Powered cycled again the ISY and I was then able to start the admin.jnlp 4) Went to Tools -> Diagnostics -> PLM Info/Status Next Tools -> Diagnostics -> Show PLM Link Table and I get a count of 68 Any suggestions/ideas as to why this is happening? Thanks Renato
Not all switches which are part of a scene respond
I would like to thank all of you for your help. Renato
Good morning everybody. Last night, (after sunset) I replaced 3 additional 2476 with 3 2477 (for a total of 4). This morning I checked the status of the Switch and can confirm that it did indeed turn off. I just finished replacing a fifth 2476 with a 2477. I then re-ran the same scene test and here are the results...... Wed 07/26/2017 09:16:51 AM : [GRP-RX ] 02 61 10 13 00 06 Wed 07/26/2017 09:16:51 AM : [INST-SRX ] 02 50 46.D6.30 41.E9.92 65 13 10 LTOFFRR(10) Wed 07/26/2017 09:16:51 AM : [Std-Cleanup Ack] 46.D6.30-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 Wed 07/26/2017 09:16:52 AM : [INST-SRX ] 02 50 13.4C.71 41.E9.92 66 13 10 LTOFFRR(10) Wed 07/26/2017 09:16:52 AM : [Std-Cleanup Ack] 13.4C.71-->ISY/PLM Group=0, Max Hops=2, Hops Left=1 Wed 07/26/2017 09:16:53 AM : [INST-SRX ] 02 50 14.6A.DF 41.E9.92 66 13 10 LTOFFRR(10) Wed 07/26/2017 09:16:53 AM : [Std-Cleanup Ack] 14.6A.DF-->ISY/PLM Group=0, Max Hops=2, Hops Left=1 Wed 07/26/2017 09:16:54 AM : [INST-SRX ] 02 50 14.AB.C0 41.E9.92 67 13 10 LTOFFRR(10) Wed 07/26/2017 09:16:54 AM : [Std-Cleanup Ack] 14.AB.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=1 Wed 07/26/2017 09:16:54 AM : [CLEAN-UP-RPT] 02 58 06 Wed 07/26/2017 09:16:54 AM : [INST-SRX ] 02 50 17.F0.61 41.E9.92 65 13 10 LTOFFRR(10) Wed 07/26/2017 09:16:54 AM : [Std-Cleanup Ack] 17.F0.61-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 <html><font color="red">----- Outside Lights Test Results -----</font></html> <html><font color="red">[Succeeded]</font> Outside Lights - Garage (P) (14 AB C0 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door R (14 6A DF 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door L (13 4C 71 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Front Door (46 D6 30 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Basemnt Door (17 F0 61 1)</html> <html><font color="red">----- Outside Lights Test Results -----</font></html>
Paul, sorry, I did not. Clearly I don't know what I am doing here..... So this is what I just finished doing...... As mentioned before: 1) I swapped the 2467 for a 2477 (i.e. deleted the 2467 from the Admin GUI and added the 2477). 2) I added the 2477 to the scene 3) Did a device restore on the 2477 4) Diagnostics -> Show device links table and compared to the ISY links table. results were 3 identical and 1 identical/ignore at the end. 5) Completed a scene test. Here are the results Tue 07/25/2017 11:07:32 PM : [GRP-RX ] 02 61 10 13 00 06 Tue 07/25/2017 11:07:32 PM : [INST-SRX ] 02 50 46.D6.30 41.E9.92 65 13 10 LTOFFRR(10) Tue 07/25/2017 11:07:32 PM : [Std-Cleanup Ack] 46.D6.30-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 Tue 07/25/2017 11:07:32 PM : [INST-SRX ] 02 50 46.D6.30 41.E9.92 61 13 10 LTOFFRR(10) Tue 07/25/2017 11:07:32 PM : [Std-Cleanup Ack] 46.D6.30-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Tue 07/25/2017 11:07:33 PM : [INST-SRX ] 02 50 13.4C.71 41.E9.92 66 13 10 LTOFFRR(10) Tue 07/25/2017 11:07:33 PM : [Std-Cleanup Ack] 13.4C.71-->ISY/PLM Group=0, Max Hops=2, Hops Left=1 Tue 07/25/2017 11:07:34 PM : [INST-SRX ] 02 50 14.6A.DF 41.E9.92 62 13 10 LTOFFRR(10) Tue 07/25/2017 11:07:34 PM : [Std-Cleanup Ack] 14.6A.DF-->ISY/PLM Group=0, Max Hops=2, Hops Left=0 Tue 07/25/2017 11:07:34 PM : [INST-SRX ] 02 50 14.6A.DF 41.E9.92 69 EC D0 (D0) Tue 07/25/2017 11:07:34 PM : [Std-Cleanup Ack] 14.6A.DF-->ISY/PLM Group=0, Max Hops=1, Hops Left=2 Tue 07/25/2017 11:07:34 PM : [INST-SRX ] 02 50 14.AB.C0 41.E9.92 61 13 10 LTOFFRR(10) Tue 07/25/2017 11:07:34 PM : [Std-Cleanup Ack] 14.AB.C0-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Tue 07/25/2017 11:07:34 PM : [CLEAN-UP-RPT] 02 58 06 Tue 07/25/2017 11:07:34 PM : [INST-SRX ] 02 50 17.F0.61 41.E9.92 65 13 10 LTOFFRR(10) Tue 07/25/2017 11:07:34 PM : [Std-Cleanup Ack] 17.F0.61-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 <html><font color="red">----- Outside Lights Test Results -----</font></html> <html><font color="red">[Succeeded]</font> Outside Lights - Garage (P) (14 AB C0 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door R (14 6A DF 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door L (13 4C 71 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Front Door (46 D6 30 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Basemnt Door (17 F0 61 1)</html> <html><font color="red">----- Outside Lights Test Results -----</font></html> Tue 07/25/2017 11:07:40 PM : [INST-ACK ] 02 62 00.00.10 CF 13 00 06 LTOFFRR(00)
Ok, sunset came and guess what..... the front door light did not come on!!!!!! So, I swapped the 2476 for a 2477. Here are the results of the Scene Test: Log with 2476S Tue 07/25/2017 08:44:04 PM : [GRP-RX ] 02 61 10 13 00 06 Tue 07/25/2017 08:44:05 PM : [INST-SRX ] 02 50 13.49.FB 41.E9.92 E1 13 FF LTOFFRR(FF) Tue 07/25/2017 08:44:05 PM : [INST-SRX ] 02 50 13.4C.71 41.E9.92 62 13 10 LTOFFRR(10) Tue 07/25/2017 08:44:05 PM : [Std-Cleanup Ack] 13.4C.71-->ISY/PLM Group=0, Max Hops=2, Hops Left=0 Tue 07/25/2017 08:44:06 PM : [INST-SRX ] 02 50 14.6A.DF 41.E9.92 62 13 10 LTOFFRR(10) Tue 07/25/2017 08:44:06 PM : [Std-Cleanup Ack] 14.6A.DF-->ISY/PLM Group=0, Max Hops=2, Hops Left=0 Tue 07/25/2017 08:44:06 PM : [INST-SRX ] 02 50 14.AB.C0 41.E9.92 66 13 10 LTOFFRR(10) Tue 07/25/2017 08:44:06 PM : [Std-Cleanup Ack] 14.AB.C0-->ISY/PLM Group=0, Max Hops=2, Hops Left=1 Tue 07/25/2017 08:44:07 PM : [CLEAN-UP-RPT] 02 58 06 Tue 07/25/2017 08:44:07 PM : [INST-SRX ] 02 50 17.F0.61 41.E9.92 65 13 10 LTOFFRR(10) Tue 07/25/2017 08:44:07 PM : [Std-Cleanup Ack] 17.F0.61-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 Tue 07/25/2017 08:44:09 PM : [INST-SRX ] 02 50 14.08.C8 41.E9.92 0F 6E 4A (4A) <html><font color="red">----- Outside Lights Test Results -----</font></html> <html><font color="red">[Succeeded]</font> Outside Lights - Garage (P) (14 AB C0 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door R (14 6A DF 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door L (13 4C 71 1)</html> <html><font color="red">[Failed]</font> Outside Lights - Front Door (13 49 FB 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Basemnt Door (17 F0 61 1)</html> <html><font color="red">----- Outside Lights Test Results -----</font></html> Tue 07/25/2017 08:44:16 PM : [INST-TX-I1 ] 02 62 00 00 10 CF 13 00 Tue 07/25/2017 08:44:16 PM : [INST-ACK ] 02 62 00.00.10 CF 13 00 06 LTOFFRR(00) Tue 07/25/2017 08:44:27 PM : [INST-SRX ] 02 50 13.F4.A1 00.00.01 CB 11 01 LTONRR (01) Tue 07/25/2017 08:44:27 PM : [Std-Group ] 13.F4.A1-->Group=1, Max Hops=3, Hops Left=2 Tue 07/25/2017 08:44:27 PM : [D2D EVENT ] Event [13 F4 A1 1] [DON] [1] uom=0 prec=-1 Tue 07/25/2017 08:44:27 PM : [ 13 F4 A1 1] DON 1 Tue 07/25/2017 08:44:27 PM : [D2D-CMP 0009] CTL [13 F4 A1 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Tue 07/25/2017 08:44:27 PM : [D2D-CMP 0005] CTL [13 F4 A1 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Tue 07/25/2017 08:44:27 PM : [D2D EVENT ] Event [13 F4 A1 1] [ST] [255] uom=0 prec=-1 Tue 07/25/2017 08:44:27 PM : [ 13 F4 A1 1] ST 255 Tue 07/25/2017 08:44:27 PM : [D2D-CMP 0006] STS [13 F4 A1 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Tue 07/25/2017 08:44:27 PM : [INST-SRX ] 02 50 13.F4.A1 00.00.01 CB 11 01 LTONRR (01) Tue 07/25/2017 08:44:27 PM : [Std-Group ] 13.F4.A1-->Group=1, Max Hops=3, Hops Left=2 Tue 07/25/2017 08:44:27 PM : [INST-DUP ] Previous message ignored. Tue 07/25/2017 08:44:28 PM : [INST-SRX ] 02 50 13.F4.A1 41.E9.92 41 11 01 LTONRR (01) Tue 07/25/2017 08:44:28 PM : [Std-Cleanup ] 13.F4.A1-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Tue 07/25/2017 08:44:28 PM : [INST-DUP ] Previous message ignored. Tue 07/25/2017 08:45:15 PM : [INST-SRX ] 02 50 14.08.C8 41.E9.92 0F 6F 28 (28) Tue 07/25/2017 08:45:15 PM : [Std-Direct ] 14.08.C8-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Tue 07/25/2017 08:45:15 PM : [D2D EVENT ] Event [14 8 C8 1] [CLIHUM] [40] uom=0 prec=-1 Tue 07/25/2017 08:45:15 PM : [ 14 8 C8 1] CLIHUM 40 Log with 2477S Tue 07/25/2017 09:12:50 PM : [GRP-RX ] 02 61 10 13 00 06 Tue 07/25/2017 09:12:51 PM : [INST-SRX ] 02 50 46.D6.30 41.E9.92 65 13 10 LTOFFRR(10) Tue 07/25/2017 09:12:51 PM : [Std-Cleanup Ack] 46.D6.30-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 Tue 07/25/2017 09:12:52 PM : [INST-SRX ] 02 50 13.4C.71 41.E9.92 62 13 10 LTOFFRR(10) Tue 07/25/2017 09:12:52 PM : [Std-Cleanup Ack] 13.4C.71-->ISY/PLM Group=0, Max Hops=2, Hops Left=0 Tue 07/25/2017 09:12:52 PM : [INST-SRX ] 02 50 14.6A.DF 41.E9.92 66 13 10 LTOFFRR(10) Tue 07/25/2017 09:12:52 PM : [Std-Cleanup Ack] 14.6A.DF-->ISY/PLM Group=0, Max Hops=2, Hops Left=1 Tue 07/25/2017 09:12:53 PM : [INST-SRX ] 02 50 14.AB.C0 41.E9.92 63 13 10 LTOFFRR(10) Tue 07/25/2017 09:12:53 PM : [Std-Cleanup Ack] 14.AB.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Tue 07/25/2017 09:12:54 PM : [CLEAN-UP-RPT] 02 58 06 Tue 07/25/2017 09:12:54 PM : [INST-SRX ] 02 50 17.F0.61 41.E9.92 65 13 10 LTOFFRR(10) Tue 07/25/2017 09:12:54 PM : [Std-Cleanup Ack] 17.F0.61-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 <html><font color="red">----- Outside Lights Test Results -----</font></html> <html><font color="red">[Succeeded]</font> Outside Lights - Garage (P) (14 AB C0 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door R (14 6A DF 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door L (13 4C 71 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Front Door (46 D6 30 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Basemnt Door (17 F0 61 1)</html> <html><font color="red">----- Outside Lights Test Results -----</font></html> Tue 07/25/2017 09:12:59 PM : [INST-TX-I1 ] 02 62 00 00 10 CF 13 00 Tue 07/25/2017 09:12:59 PM : [INST-ACK ] 02 62 00.00.10 CF 13 00 06 LTOFFRR(00) Tue 07/25/2017 09:13:18 PM : [INST-SRX ] 02 50 14.08.C8 00.00.01 CF 13 00 LTOFFRR(00) Tue 07/25/2017 09:13:18 PM : [Std-Group ] 14.08.C8-->Group=1, Max Hops=3, Hops Left=3 Tue 07/25/2017 09:13:18 PM : [D2D EVENT ] Event [14 8 C8 2] [DOF] [0] uom=0 prec=-1 Tue 07/25/2017 09:13:18 PM : [ 14 8 C8 2] DOF 0 Tue 07/25/2017 09:13:18 PM : [D2D EVENT ] Event [14 8 C8 2] [ST] [0] uom=0 prec=-1 Tue 07/25/2017 09:13:18 PM : [ 14 8 C8 2] ST 0 Tue 07/25/2017 09:13:18 PM : [D2D EVENT ] Event [14 8 C8 1] [CLIHCS] [0] uom=0 prec=-1 Tue 07/25/2017 09:13:18 PM : [ 14 8 C8 1] CLIHCS 0 Tue 07/25/2017 09:14:00 PM : [INST-SRX ] 02 50 14.08.C8 41.E9.92 0F 6E 4A (4A) Tue 07/25/2017 09:14:00 PM : [Std-Direct ] 14.08.C8-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Tue 07/25/2017 09:14:00 PM : [D2D EVENT ] Event [14 8 C8 1] [ST] [148] uom=0 prec=-1 Tue 07/25/2017 09:14:00 PM : [ 14 8 C8 1] ST 148 Tue 07/25/2017 09:15:06 PM : [INST-SRX ] 02 50 14.08.C8 41.E9.92 0F 6E 4B (4B) Tue 07/25/2017 09:15:06 PM : [Std-Direct ] 14.08.C8-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Tue 07/25/2017 09:15:06 PM : [D2D EVENT ] Event [14 8 C8 1] [ST] [150] uom=0 prec=-1 Tue 07/25/2017 09:15:06 PM : [ 14 8 C8 1] ST 150 Tue 07/25/2017 09:15:21 PM : [INST-SRX ] 02 50 13.F4.A1 00.00.01 CB 11 01 LTONRR (01) Tue 07/25/2017 09:15:21 PM : [Std-Group ] 13.F4.A1-->Group=1, Max Hops=3, Hops Left=2 Tue 07/25/2017 09:15:21 PM : [D2D EVENT ] Event [13 F4 A1 1] [DON] [1] uom=0 prec=-1 Tue 07/25/2017 09:15:21 PM : [ 13 F4 A1 1] DON 1 Tue 07/25/2017 09:15:21 PM : [D2D-CMP 0009] CTL [13 F4 A1 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Tue 07/25/2017 09:15:21 PM : [D2D-CMP 0005] CTL [13 F4 A1 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Tue 07/25/2017 09:15:21 PM : [D2D EVENT ] Event [13 F4 A1 1] [ST] [255] uom=0 prec=-1 Tue 07/25/2017 09:15:21 PM : [ 13 F4 A1 1] ST 255 Tue 07/25/2017 09:15:21 PM : [D2D-CMP 0006] STS [13 F4 A1 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Tue 07/25/2017 09:15:22 PM : [INST-SRX ] 02 50 13.F4.A1 00.00.01 CB 11 01 LTONRR (01) Tue 07/25/2017 09:15:22 PM : [Std-Group ] 13.F4.A1-->Group=1, Max Hops=3, Hops Left=2 Tue 07/25/2017 09:15:22 PM : [INST-DUP ] Previous message ignored. Tue 07/25/2017 09:15:22 PM : [INST-SRX ] 02 50 13.F4.A1 41.E9.92 41 11 01 LTONRR (01) Tue 07/25/2017 09:15:22 PM : [Std-Cleanup ] 13.F4.A1-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Tue 07/25/2017 09:15:22 PM : [INST-DUP ] Previous message ignored. Thanks again for all of your help. Renato
Techman Here is the output of the scene test: Tue 07/25/2017 03:38:50 PM : [GRP-RX ] 02 61 10 13 00 06 Tue 07/25/2017 03:38:51 PM : [INST-SRX ] 02 50 13.49.FB 41.E9.92 61 13 10 LTOFFRR(10) Tue 07/25/2017 03:38:51 PM : [Std-Cleanup Ack] 13.49.FB-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Tue 07/25/2017 03:38:51 PM : [INST-SRX ] 02 50 13.4C.71 41.E9.92 62 13 10 LTOFFRR(10) Tue 07/25/2017 03:38:51 PM : [Std-Cleanup Ack] 13.4C.71-->ISY/PLM Group=0, Max Hops=2, Hops Left=0 Tue 07/25/2017 03:38:52 PM : [INST-SRX ] 02 50 14.6A.DF 41.E9.92 62 13 10 LTOFFRR(10) Tue 07/25/2017 03:38:52 PM : [Std-Cleanup Ack] 14.6A.DF-->ISY/PLM Group=0, Max Hops=2, Hops Left=0 Tue 07/25/2017 03:38:53 PM : [INST-SRX ] 02 50 14.AB.C0 41.E9.92 62 13 10 LTOFFRR(10) Tue 07/25/2017 03:38:53 PM : [Std-Cleanup Ack] 14.AB.C0-->ISY/PLM Group=0, Max Hops=2, Hops Left=0 Tue 07/25/2017 03:38:53 PM : [CLEAN-UP-RPT] 02 58 06 Tue 07/25/2017 03:38:53 PM : [INST-SRX ] 02 50 17.F0.61 41.E9.92 65 13 10 LTOFFRR(10) Tue 07/25/2017 03:38:53 PM : [Std-Cleanup Ack] 17.F0.61-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 <html><font color="red">----- Outside Lights Test Results -----</font></html> <html><font color="red">[Succeeded]</font> Outside Lights - Garage (P) (14 AB C0 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door R (14 6A DF 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Deck Door L (13 4C 71 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Front Door (13 49 FB 1)</html> <html><font color="red">[Succeeded]</font> Outside Lights - Basemnt Door (17 F0 61 1)</html> <html><font color="red">----- Outside Lights Test Results -----</font></html> Tue 07/25/2017 03:38:58 PM : [INST-ACK ] 02 62 00.00.10 CF 13 00 06 LTOFFRR(00) Tue 07/25/2017 03:39:14 PM : [INST-SRX ] 02 50 14.08.C8 41.E9.92 0F 6E 4B (4B) Tue 07/25/2017 03:39:14 PM : [Std-Direct ] 14.08.C8-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Tue 07/25/2017 03:39:14 PM : [D2D EVENT ] Event [14 8 C8 1] [ST] [150] uom=0 prec=-1 Tue 07/25/2017 03:39:14 PM : [ 14 8 C8 1] ST 150 Tue 07/25/2017 03:39:43 PM : [INST-SRX ] 02 50 14.08.C8 00.00.01 CF 11 00 LTONRR (00) Tue 07/25/2017 03:39:43 PM : [Std-Group ] 14.08.C8-->Group=1, Max Hops=3, Hops Left=3 Tue 07/25/2017 03:39:43 PM : [D2D EVENT ] Event [14 8 C8 2] [DON] [0] uom=0 prec=-1 Tue 07/25/2017 03:39:43 PM : [ 14 8 C8 2] DON 0 Tue 07/25/2017 03:39:43 PM : [D2D EVENT ] Event [14 8 C8 2] [ST] [255] uom=0 prec=-1 Tue 07/25/2017 03:39:43 PM : [ 14 8 C8 2] ST 255 Tue 07/25/2017 03:39:43 PM : [D2D EVENT ] Event [14 8 C8 1] [CLIHCS] [2] uom=0 prec=-1 Tue 07/25/2017 03:39:43 PM : [ 14 8 C8 1] CLIHCS 2 Paul I have done a factory reset on the switch. I will see how the scene will behave over the next few days.
I realize that the 2476S are quite "antique" What would be the advantage of upgrading those 2476S switches to say the 2477S?. Also I am using the 2473 OutletLinc V.38 for my outlets (about 10 of them) As an aside, my config has the following access points/extenders: 2X - P2443 V2.0 0940 on main floor 1X - 2992-222 R3.7 2016 on main floor 1X - PLM on second floor 1X - 2443 V2.6 1212 on second floor Renato
One other thing.... I just got a new SD 16Gig Class 10 card. I am going to re-install the firmware and restore from backup. This hopefully will eliminate the possibility of a faulty SD card. Renato
Thank you both for your replies. Paul "The scene turns the light on, but the admin console shows it as off". It is actually the other way around. Two programs turns the scene on (on sunset) and off (on sunrise). When the sunrise program executes, is when I see the problem. "Also, did it always work correctly in the past and this is a new observed behavior?" This started about a month ago. I know, now you are going to ask me "what have I changed since?" well..... I have no clue Techman: They are LED E14 (candelabra) lights. Renato
This has been driving me up a wall...... Running Firmware 4.6.2. PLM Info: 41.E9.92 v9E / Connected Also, let me preface that I am using "older" Insteon switches (i.e. 2476S SwitchLinc Relay W/Sense v.37 & v.38)) I have a program which at Sunrise, turns off the "Outside Lights" Scene. "if Time is Sunrise Then Set Scene 'Outside Lights' Off Else - No Actions" I noticed that occasionally, the Admin GUI (after sunrise) reports one of the 4 switches which make up the scene (i.e. Outside Lights) as being off. If I query the same switch from the admin console, the status is actually On. If I turn on/off the SAME switch from the admin console or eKeypad, I get the expected behavior. Any idea what could be possibly be causing this erratic behavior? Thanks Renato
Disable Schlage lock after N failed attempts
I have successfully installed the FE469NX Z-Wave lock. Is it possible from ISY to disable the lock for say 2 mins after N number of failed codes? Thanks Renato
