MHB
  • Posts
    4
Everything posted by MHB
  1. I am really, really very sorry that I wasted your time helping me with my problem. I had to stop the loop that the linking calculation was in by unplugging the unit and powering it back up. I deleted the sunset scene and proceeded to put it back in using what is available in the UI and it now works completely. Previously I had added the switch to the rest of the scene using the UI and it wouldn’t turn on with the rest of the switches, but would turn off as I had entered it like that when I created the sunrise scene for in case I had manually turned the switch on. I singly had put the switch in and removed it multiple times trying to get it to work which it never did. Maybe it is a limitation/bug in the UI? Thanks for the help – Mike.
  2. Sorry that I didn’t get back to you. I apparently clicked on something wrong trying to copy what I have and the program has gone into a never ending linking calculation which is still running this morning. My statement didn’t look like yours at all. It simply made: If Sunset Then each switch that I chose as on was entered This has worked correctly for all the ones that I entered when I created it. The problem with this one switch occurred when I went back in after some time and entered it using the same method. All the rest still worked correctly except for this last entry. When I can recover the system I’ll try your method and see what happens. Thanks for the help – Mike.
  3. I'm sorry, I'm not sure what you are asking for. I programmed it with the Universal Devices Administrative Console. I copied the Sunset Event to here: <?xml version="1.0" ?><triggers><d2d><trigger><id>4</id><name>Sunset</name><parent>1</parent><if><and /><schedule><at><sunset>0</sunset></at></schedule></if><then><cmd id="DON" node="2C 7C D1 1"></cmd><cmd id="DON" node="30 C4 C9 1"></cmd><cmd id="DON" node="50 BF 6A 1"></cmd><cmd id="DON" node="9 FA E3 1"></cmd><cmd id="DON" node="1E ED FF 1"></cmd><cmd id="DON" node="1E ED CA 1"></cmd></then><else></else><comment></comment></trigger></d2d></triggers> The switch address in question is: 1E.ED.CA 1 Thanks
  4. I have an Insteon 2477S Dual Band SwitchLinc On/Off Switch v.42 that I originally setup to turn on manually, but if it was left overnight I had the Sunrise Event turn it off – which it does. I recently set the switch to be turned on with the Sunset event, but it won’t. I can access it from the Administrative Console and UD Mobile phone app and turn it on and off without any problem. I have tried deleting and restoring the program, but it still doesn’t work. The controller is an ISY994i with firmware is 5.3.3. Any thoughts – thanks Mike.
  • Create New...
