Device Shows in Web, iOS, Java, but Not MacOS UD Mob
D'oh! Synchronizing took care of the problem.
The device ("Den") might not show up in the Mac list of available devices, but it DOES show up in Mac Notifications!
MacOS 26.5.1, MacBook Pro with M3 Pro processor, UD Mobile 1.4.23 (iOS and MacOS) UD Mobile is clearly designed to run under MacOS 26 as well as iOS, because there are settings for the Mac (screenshot 1). I have a device, variously named Den, which shows up in the Java, UD Mobile/iPhone, and web interfaces, but does not show up under UD Mobile/MacOS. It’s definitely in Java (screenshot 2), and in iOS (screenshot 3), and in web (both there, only one shown, screenshot 4) All other devices are shown in UD Mobile MacOS. So why isn’t in MacOS UD Mobile (screenshot 5; believe me, I've scrolled and scrolled)? What am I missing?!
GHenry started following Time does not reset after power failure or DST , Device Shows in Web, iOS, Java, but Not MacOS UD Mob , Has the Trend/Chart Facility Been Removed? and 1 other
Maybe in the new browser-based interface…
Eisy v.5.9.1, Aeotec TriSensors 5 and 8, MacOS 15.5 At some point in the past, I recall being able to get a graph of current temperatures from my Aeotec TriSensors; if I recall correctly, it was on my ISY-99i via a control-click on the device name in the Main window of the Admin Console. Now when I try, I get no relevant contextual menu items, but I can click the Trend (Chart) icon in the AC menubar. With a TriSensor selected, the Trend icon produces a window with only a menubar; choosing Categories/Current Temperature opens a chooser. When I choose a TriSensor, nothing happens; the window is blank. Am I missing something, or has this feature been removed? (Note that it has never worked for me in UD Mobile.)
Notifications suggest eisy reboots, log not clear
I should have posted this 48-line error log snippet. It clearly shows a restart 55 minutes after the previous entry, but doesn't show a reason. There must be one…? It also shows the switch between AM/PM and 24-hour time. ISY Error Log.v5.9.1__Mon 2025.05.05 02.19.58.txt
Maybe. But PG3 is usually restarting. The eisy's MAC address/notification server restarts. My question is: does that indicate that the eisy itself is restarting?
eisy 5.9.1, PG3x 3.3.18, UD Mobile 1.2.5, MacOS 15.4.1 Occasionally I get UD Mobile messages like “PG3 starting” and at the same time, scheduled battery and device reports that are blank (they later update to numbers). I assume that this means the eisy has rebooted (I was out of town at the time). However, I have an alarm system, a door lock, and a thermostat which are very quick to alert on a power blink or outage of even short duration, and they report no outage. The eisy log does not indicate any power failure or reboot at the time of the messages. In this example, I got 11 notifications in UD Mobile at 16.01 on 3 May; the log starts with 2 odd entries in AM/PM time (most entries are in 24-hour time): 0 null Sat 2025/05/03 03:59:53 PM System Unknown 0 null Sat 2025/05/03 03:59:53 PM System Unknown Then another 160 log entries within 40 seconds (I've attached a log snippet). Does this make sense to anyone? Is the eisy rebooting? If not, what's causing all these notifications (note phone time is +7h relative to eisy time)? Log Snippet 1552-1602.txt
Thanks! That's the bug, apparently limited to display; nonetheless, the programs run as expected, and the displayed times of sunrise and sunset appear to self-correct during the night after the time change.
…but two of my sunset rules just fired (correctly) at 18:50, even though the Java interface says sunset won't be until 19:50…?!
eisy v5.9.1 My eisy experienced an 8-hour power failure on Friday. When power returned, the time was off by 8 hours. I reset the location, and the time corrected itself, but today was the Spring time change to Daylight Saving time, and the times of sunrise and sunset are still one hour off. I thought I recalled an NTP service setting when I initially set up the predecessor ISY-994i, but now I can’t find it. How can I correct sunrise/sunset times (some rules use it)?
Release 5.9.1 discussion
You'll eventually have to reboot. Would a fixed LAN address assignment in the router solve the problem?
Support Thread: IoX v5.9.1 (2/10/25)
I think you're expecting too much, too soon. The release notes say "installs HomeKit plumbing," not HomeKit itself, similar to the way it says "installs eisyui plumbing," not eisyui (presumably the forthcoming browser-based UI).
Believe me, they want it worse than you do. And they're working hard on it. So let's give them some slack.
State Variable Disappears/Reappears in Favorites
Thanks, I would never have found that! 🤭
GHenry
Joined
Last visited
