TSinclair
Everything posted by TSinclair
  1. When you set up your condition in HA, try selecting "numeric state" instead of "state". You should be able to trigger on that. If your thermostat is in HA, I would likely use the HA app to trigger location. I have found it very reliable. I think you will find the "climate" call service in HA to easy enough to set up to change the thermostat to what I want.
  2. I haven't tinkered with external antennas, so I can't say. Logically it seems it might be worth a try.
  3. I've used a ZEN17 to control the garage door(s) in my detached garage for the last couple months. It has been 98% reliable. The 2% failures are from not opening or closing upon a z-wave button push from the house. I haven't had any random opens. With that said, I would not trust Z-wave at your 100' distance. I have a switch in a shed at about that distance and the success rate is ~80%.
  4. I would add that after my migration to eisy I began using Telegram within the notification node server. It's been a couple months now and has worked very well. Not sure if you use iOS, but a bonus feature that I now probably couldn't live without is how well it integrates with carplay, it's nice to have the notification present and then siri read it to me.
  5. Just for fun, I tried to create a new program as well as program folder using UDMobile. Now I've never used UD Mobile to do that before, so I don't even know if it should work, but received the error "Could not get programs data".
  6. I am getting the same thing, "bad request" when saving a program on Eisy this morning. Other than clearing java cache, I have not tried to diagnose yet, but certainly odd.
  7. I'm not familiar with the Jasco switches. You would assign the scene node generated during the z-wave pairing/interview to your program. Here is a simple example I am using: Garage Door Right - [ID 0206][Parent 0204] If 'Z-Wave Extra Nodes / ZY 043 Scene Button 2' is switched Fast On Then Set 'Garage / GA ZEN17 / ZY 093.2 Binary Switch' On Else - No Actions - (To add one, press 'Action')
  8. I understand now. It is annoying that these switches do not function as elegant as insteon! A couple ideas would be to assign another variable that captures if the switch was activated by a motion sensor/program or check if the switch has any scene nodes. My zooz swiches do have scene nodes so I am at least able to use those for fast on's to operate programs (versus just status).
  9. My workaround in this situation is to change the program to monitor status instead of control of the switch.
  10. To keep it simple, I would use a second program for the reason stated above. Program Front Door Lights if from sunset to sunrise (next day) and 'front door motion-sensor' status is on then set front porch lights on run program front door lights off (THEN) else (blank) ________________________________________________________ Program Front Door Lights Off if (blank) then Wait 5 minutes set front porch lights off else (blank)
  11. I'm surprised noone has responded to your question yet, so I'll take a stab. If I understand correctly you want alexa to announce if someone presses the doorbell, and you want to use the yolink app. If you have an existing doorbell, I see two possibilities. If you want to keep the chime, an automotive relay could be wired in with the chime/doorbell transformer and used to trigger a hacked yolink contact sensor, or if you don't want the chime you could simply wire the hacked yolink contact sensor with the doorbell wires. With that said, for the price of a yolink contact sensor and a relay, you could come pretty close to the cost of a ~$35 video doorbell that "works with Alexa".
  12. As an Orchestrated MobiLinc user for MANY years I will concede the learning curve of UD Mobile was pretty steep. However after using it exclusively for 2+ months, I find its power and flexibility wonderful. Yeah remembering the hex colors and minimal icons was/is annoying, but the flexibility and ability to configure what works for my situation(s) is invaluable. The WAF is also high.
  13. I only had only one of those messages overnight. I looked at my router log at the time of the offline/online notice and see the following: dnsmasq[7479]: Maximum number of concurrent DNS queries reached I'm not at all sure what that means or what is causing it, but it's the only occurrence of that message in my log.
  14. I have experienced all Z-Wave devices going unresponsive. No doubt it was more frequent prior to 5.5.9, but has occurred once a few weeks ago (since 5.5.9). At least for me, a reboot doesn't solve, I have to go to each device and perform a Z-Wave>Synchronize>Update.
  15. Please see screenshot. The description is not helpful so I poked around a bit to see if I could get identifiable information about the device but couldn't figure it out. Is there some way that I am missing, or should I send test messages to figure out which device is which? Thank you.
  16. So chalk this up too random reboot that just happened to coincide with the maintenance window. good grief.
  17. You are correct. I wish I had a dang screen print so ya'll don't think I'm crazy! I was logged into AC from the office for the last ~hour. Just this moment I was disconnected and when I reconnect all the state variables now show the system restarted at 7:21:49am.
  18. I had that thought, but based on timestamps of my state variables, eisy did not reboot. Here is the eisy error log during the window. Anything concerning? It seems strange that some of the timestamps are out of order. Is it possible something caused eisy to go into a busy state?Fri 20230324 060713.txt
  19. Thanks, this is what I assumed related to the Envisalink/DSC node server. To clarify, the Hue lights are controlled through ISY Network Resources using programs. I never figured there would be a portal dependency, but according the the wife, they did not work from ~7:15am to 7:23 am CDT. I also got a notice from Telegram, through the Notification Node Server, that the service started up at 7:21 CDT. I can't look at Node server logs right now, but it now seems something caused some of them to restart. I am here on this forum to learn, I'm not casting blame, I just want to understand.
  20. Please educate me. One of the reasons I have been loyal to ISY (and now eisy) all these years has been to maintain local control. To me this means that everything within the walls of my home works, even if the internet is down. I was very surprised to get that angry call from the wife this morning that "I can't turn on the damn lights". What this translates to is lights using motion or contact sensors through the DSC Node Server, and Hue lights using Network Resourses did not function during the outage this morning. I don't understand how that can be. I apparently mistakenly assumed the portal maintenance this morning would only impact UD Mobile, and Alexa routines. Please educate me on the dependencies on the portal.
  21. I went through this nightmare just last night with a ZSE40. After the 4th attempt the "interview" dialog box quit appearing and all z-wave devices quit responding. I ultimately had to reset/restore the Z-Matter dongle and re-synchronize every z-wave device to get them back. I then went back to the ZSE40 and what ultimately worked was pressing the sensor's z-wave button with a paperclip before starting the interview and then every 10 seconds until it completed.
  22. I too have noticed eisy occasionally becomes VERY slow to respond. I have also learned to be patient after power-cycle; but on more than one occasion, I have ultimately had to right mouse on each Z-Wave device and Z-Wave>Synchronize>Update to get the devices to report status and come back to life.
  23. Update seemed to go fine. Oddly, my backup timed out prior to starting the update. I searched on here and found I needed to adjust Java a Parameter and that solved it. I do now get this error:
  24. I've experienced programs running too fast as well. I've had to insert wait 1 second in some programs, otherwise there were presumably some z-wave collisions with commands not executing. The wait 1 second solved the issue, but it would be great to have some fraction of a second options.
  25. I'll be curious as well as I get several hundred "-170001" errors a day.
