spage
  1. When I upgraded my 99 to 15 the upgrade went through OK. But afterwards I found that my night lighting program no longer worked. It turned out that the reason was that the On % was set to 0 for all my scenes that were converted. Moving the slider to 100% made the light come on but teh scene changes dod not seem to get saved. To resolve the issue I had to remove the scenes and add them again. I have also noticed that I can create a scene and be able to click and control each device seperately but when I turn on the scene the devices controlled by that scene do not respond- why would that be?
  2. OK understood the router is a Cisco 2801 which is a g=bear to configure. I will give Cisco a call and set up port forwarding. I guess I can choose any port I want using a telnet command - right?
  3. ISY-99i/IR Pro v2.7.0 When I select Enable Internet Access from the menu I get a "Failed Enabling Internet Access" message after a few seconds. I can't seem to find any diagnostic or configuration tips on this topic. Any assistance greatly appreciated.
