Prana electric
Everything posted by Prana electric
  1. Thank you for making changes on your end to get it working. I appreciate the great technical support and value the years of knowledge that the online forum offers. Cheers!
  2. Did all that and still get the same thing. Each texts identification number is completely different from the others. At least it’s working. A little annoying that it looks like I’m getting texts from a bunch of different devices/locations
  3. Hello again So text messages started working again but coming in with a different email address from universal devices and a huge line of digits before it. Each text is different The most recent is 0100018265e87e5d-d9fdc585-8fc1-4392-9b67-59fbfdf6f07e-000000@mail.universal-devices.com but comes in as a text message Every following message has a different numerical value
  4. I’m in Canada. Bell mobility Honestly I haven’t tried sending a simple email to text. All I did now was add my email address to the list and modified which notification I really need to get so I’m not completely stuck. So I’m just getting email notifications instead of texts.
  5. I've been talking to Michel and we are kinda stumped as too why its not working. He helped troubleshoot the problem by me sending my error log but could not find any problems. Sending email notifications works fine but not text.
  6. Is there an outage? I haven’t been receiving my text notifications all weekend. I checked all the settings on my Polisy and tried a test but no response…
  7. No. My Polisy has a Zooz stick connected to it for Zwave and a PLM connected to it for the Insteon devices. The Zwave devices are Leviton receptacles and switches. What’s strange about it is when I use the push button on the receptacle to turn it on and off the status changes on the app and on my UD computer interface page. It doesn’t how ever change status for the switch. I have to query the switch to see a change in status
  8. OK sorry to get off topic. So I figured out that if I turn the light switch on at the device, the status does not change on the ISY unless I query that device then the status shows on. So the insteon devices automatically show their changed state on the ISY without query 'ing them but the Zwave devices do not. That's why the program did not work with the Zwave devices. Is there a way to show the state or status of Zwave devices without have to query them to get their new state?
  9. Hello all I tried creating a count down timer using the example on the UD website from 10 years ago and it worked. The problem I am having is that it will not work with Z Wave connected switches and plugs. It works fine with all the Insteon devices I tried the program, but not with Zwave. Any insight would be appreciated. I also tried just creating a basic program to count down the device and no luck The device does work through the app and web portal so it's not the device.
  10. Hello all I am still learning as much as I possibly can on my own about the isy/polisy. It's a huge learning curve with alot of little variables to check/ unchecked, verify and pretty much play around with until I get it right. Unfortunately I am still waiting for my PLM serial cable so I have not been able to add any devices to my PLM yet. What would helpful is if any one had any sample programs I could have a look at in order to better understand the process of how to make one when I'm ready. I've tried simple ones like schedules, but I would really like to see what this POLISY can do. For example : I want to use a insteon On/Off switch as a count down timer. When the switch is turned on the timer immediately starts depending on what time I set it to count down from. Stuff like that would be cool to learn how to do. Help would be appreciated.
  11. LEVITON makes some pretty good stuff I may have to go to them when I run out of my insteon stock. Leviton DZ15S-1BZ Leviton DZ6HD-1BZ Levition DD00R-DLZ Leviton ZW15R-1BW
  12. Thanks for your help guys. Its the little bits of information that help me learn through this process.
  13. Thank you. I just ordered it. Does anyone know what the two extra ethernet ports are used for on the back of the polisy?
  14. Ok... I don't want to waste any one's time here and this problem has probably come up multiple times before but here goes. Just received my polisy and insteon plm 2413s. The initial setup up went relatively smoothly although I cannot change the ip address on the polisy by clicking on the dhcp settings in the configuration setup menu. Its just fixed @ 192.168.1.157 The other thing that I cant figure out it why the polisy is not seeing the insteon plm. Their is power to the plm. The green light is on. The ethernet cable is connected from the plm to the left ethernet port located on the back of the plm looking at it from the front. I'm not sure what the issue is. Do I need a DB9 to RJ45 serial cable to connect the polisy to the insteon plm? On the bright side my USB zwave plugin zooz stick is operational, but I do not have any zwave devices to test it with. All my devices in my house are insteon. I have over 85 devices and I thought I would give polisy a shot before I started removing everything insteon and starting from scratch. Any help would be appreciated
  15. Thanks for the reply and useful information. I am definitely sure that I will have many follow up questions but it seems as though I am in good hands here. It’s nice to be able to find interesting and knowledgeable people who are interested and care about the same thing. Thanks again Looking forward to learning
  16. Hello all. Just ordered a Polisy and Inseon PLM from AArtech canada. Hoping it will show up in a week or two. As a Newbie here I am not very familiar with the polisy or isy family of products, Is there any literature to read up on or possibly a demo to look at so that I may get familiar with this new " hub"? I would say I am pretty tech savy but not very good with code but I am eager to learn. Any documents links or relevant information would be appreciated to make my transition from insteon hub to polisy pro. Thank you
