AT&T to end email-to-text ×
iceberg5xx
  • Posts
    15
Everything posted by iceberg5xx
  1. Looking at services like PaperTrailApp.com to centralize logs from my systems. Is there any way to configure syslog server on the ISY? thanks, Bobby
  2. Looking at services like PaperTrailApp.com to centralize logs from my systems. Is there any way to configure syslog server on the ISY? thanks, Bobby
  3. Thanks Michel, I upgraded last night to 2.7.12 and adjusted my Avast Web Shield settings on my Admin System. In avast Web Shield settings, select customize, select Basic tab, in the Ignored Addresses field enter: http://IP_OF_ISY substituting your IP address for your ISY-99. I also refreshed the Firmware (already updated had been updated to the latest, but did it again) of my ELK M1-XEP. Everything seems to be working better now... Will update, if problem returns. Bobby
  4. All, I have been experiencing a similar issue. Seems like it started when I tried to link with my ELK M1... Same issue ISY-99i becomes almost "unresponsive" Admin Console shows no status for devices, and "System Busy" can be seen at the bottom. Lots of the following messages in the logs... 0 uuid:00 Wed 03/03/2010 02:51:35 PM System -5011 0 uuid:00 Wed 03/03/2010 02:51:35 PM System -5011 0 uuid:00 Wed 03/03/2010 02:51:35 PM System -5011 0 uuid:00 Wed 03/03/2010 02:51:35 PM System -5011 0 uuid:00 Wed 03/03/2010 02:51:35 PM System -5011 0 uuid:00 Wed 03/03/2010 02:51:35 PM System -5011 0 uuid:00 Wed 03/03/2010 02:51:35 PM System -5011 0 uuid:00 Wed 03/03/2010 02:51:35 PM System -5011 If I leave it alone, just seems to sit, busy, Scheduled tasks and triggers seem unresponsive. Unplugging the ISY and plugging it back in generally fixes it, but I have also found if the Console with close (some times it won't) and I control any device in HTML interface, then open the Console again it seems to go to a "Ready" State and be happy again. I can do additional testing as it seems to be happening often now, 5 times last night, 2 times today. I cleared the Elk programing (IP/PORt, save) for a bit, and it didn't happen again, but would have to do it for longer to confirm. ISY99 Ver 2.7.7 Client System Windows XP no Firewall turned ON Anti-Virus Avast thanks, Bobby
  5. Sorry, I sent this very late an it may not have been very clear I started with this program: If X10 'O10/Off (11)' is Received Or Control 'DNR, Chandler (D)' is switched Fast Off Or Control 'RemoteLinc - 2' is switched Off Then Set Scene 'Scene - Theater OFF ' On Set 'KIT, Rope Lights (D/N8)' Off Set 'LVR, Tower Bookcase (R/L13)' Off Else - No Actions - (To add one, press 'Action') When it was not working from the RemoteLinc, I started removing actions and adding additional OR cases for the RemoteLinc in attempt to get it to trigger the action. After posting my message I noticed that I was not seeing status updated from the RemoteLinc in the "Main" panel, so before going to bed I decided to run FILE > Restore Devices. This morning when I tried the RemoteLinc again, it worked... So I'm not sure what caused my issue, be a "Restore/Rebuild" of my Insteon Network seemed to solve it. I reverted back to my original program posted above, and all is running smoothly. My Goal is to use each of the top three buttons w/State on the RemoteLinc as 6 "triggers" for Scenes I have created. Thanks, Bobby
  6. I'm trying to trigger a Scene based on a button push on the RemoteLinc. I previously used the top bank of buttons 1-3 to setup different scenes in the home. But I don't seem to be able to trigger a scene with my remote link here is the same program. (have been able to trigger it with other conditions like X10 A1 ON. If Status ‘Remotetinc - 2’ is off or control ‘RemoteLinc’ is switched on Or Status ‘RemoteLinc - 2’ is On or Control ‘RemoteLinc - 2’ is switched Off Or Control ‘RemoteLinc - 2’ is switched Fast On Or Control ‘RemoteLinc - 2’ is switched Fast Off or control ‘RemoteLinc - 2’ is switched Fade Up Or control ‘Remotelinc - 2’ is switched Fade Down Then Set Scene ‘scene - Theater OFF / Bedtime’ On Else - No Actions - (To add one, press ‘Action') Thoughts on what I'm missing, I want to do this in a program so I can leverage the trigger to do other task like send X10 messages. Thanks, Bobby
  • Create New...
