JBlake01
Everything posted by JBlake01
  1. Go to Purchases -> Re-Install -> Update
  2. I see 1.0.5 in Prod store, I just deleted 1.0.4 and installed (not re-install) into same node slot and it ran perfectly at 1.0.5 I didn't see Update option either but above process worked great
  3. @bmercier and @Michel Kohanim great work, thank you! URL worked for my setup and after running url and then clicking authenticate very happy to report everything is working perfectly. Thanks so much for the great support!
  4. Ty, running Prod node server
  5. Great catch and yes, polisy was separately upgraded to PG3x and is running 3.1.26
  6. Do have active portal license - use it to manage 2 devices (separate locations) 1 has eisy (not currently experiencing issue...although haven't tried Ring Node yet) Other (this location) has polisy Portal license is active and even refreshed status to make sure I wasn't missing anything, think it's valid for another 2 years or so. I reverted Ring Node server back to default github settings after install and now am patiently waiting - will surely post fix - envy (in a good sportsmanship kinda way!) those who have it working...seems like an amazing node server and looking forward to getting it working and updating programs to take full advantage of it. Thanks all for the help so far - will figure it out sooner or later!
  7. Thank you, ticket created Interestingly, all other nodes have my IP address in IoX under Node Servers -> Configure -> Choose Slot for Node Server...the Ring had a random IP...changed it in IoX but still no positive impact for Authenticate in PG3x
  8. Very helpful, thank you - I don't have any option to authenticate w/Ring...didn't notice any pop-up blocker in Safari or Chrome (tried Chrome on Windows and Mac). Didn't even realize that's what was supposed to happen, thanks for making it known. I even ran update packages on my Polisy just in case...feels like it might be support ticket time. When I try https://oauth.ring.com/oauth/users/sign_in it tells me: our session has expired. Please close the window and try again. Code: 000
  9. 2023-05-15 09:53:34,371 Thread-5 udi_interface INFO oauth:getAccessToken: Getting access token 2023-05-15 09:53:34,373 Thread-5 udi_interface INFO ring:configDoneHandler: Access token is not yet available. Please authenticate. 2023-05-15 09:53:34,100 MainThread udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2023-05-15 09:53:34,102 MainThread udi_interface INFO ringInterface:__init__: Ring interface initialized... 2023-05-15 09:53:34,103 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: controller not found in database. 2023-05-15 09:53:34,104 MainThread udi_interface.interface INFO interface:addNode: Adding node Ring(controller) [None] 2023-05-15 09:53:34,106 MainThread udi_interface.interface INFO interface:setController: Using node "controller", driver "ST" for connection status. 2023-05-15 09:53:34,108 MainThread udi_interface INFO controller:__init__: Controller Initialized... 2023-05-15 09:53:34,137 MQTT udi_interface.interface INFO interface:_message: custom data response {'customparamsdoc': '<h2>Configuration</h2>\n\n<p>shortPoll = The interval used to poll the battery level</p>\n\n<p>longPoll = The interval used to resubscribe to Ring events</p>\n'} 2023-05-15 09:53:34,147 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc 2023-05-15 09:53:34,368 Thread-5 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-05-15 09:53:34,371 Thread-5 udi_interface INFO oauth:getAccessToken: Getting access token 2023-05-15 09:53:34,373 Thread-5 udi_interface INFO ring:configDoneHandler: Access token is not yet available. Please authenticate. 2023-05-15 09:53:34,377 Thread-5 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-05-15 09:53:34,457 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-05-15 09:53:34,461 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-05-15 09:53:34,665 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
  10. When I click “Authenticate” nothing happens, any ideas?
  11. How do you authenticate in PG3x for Rachio? I have it installed on 5.6 and 3.26 PG3x on Polisy with PG3 remote connection enabled and $9 license purchased but no matter how many times I reboot/restart IoX, PG3x, Polisy, etc. I can’t get it to authenticate? What am I missing so it will pull in my Ring device? Thanks!
  12. @GeddyUpon clicking “ISYs”->”Auto-Discover ISYs” it produces the following: Everything seems to be working fine now for programs and any dependencies to node servers - just didn’t know if it’s a bug that will produce issues/errors in future?
  13. Curious why after seemingly successful upgrade package execution and power cycling EISY PG3 would show undefined for ISY even though it shows UUID and 3.22 in PG3 dashboard? PG3 nodes show as connected but even after restarting PG3 it seems node servers aren’t correctly aligned with ISY UUID. Thoughts or is this not an issue? Some programs I have triggered to run off node server events aren’t working. thanks!
  14. 5.5.5 worked great on Polisy Pro following standard "Upgrade Packages" execution through AC. Upgraded from 5.5.4 ->5.5.5 and PG3 upgraded from 3.1.16 to 3.1.17 without issue. Logged into My.ISY.IO to verify Polisy was at 5.5.5 then went into PG3 dashboard, refreshed then auto discovered ISY to re-detect mine and everything started up great. My Rachio Node Server had to be manually restarted but all others appear to be working perfectly. No changes needed to scenes either - well done UD Team!
