south
Everything posted by south
  1. south replied to ErikN's topic in IoX Support
    I have been hoping for this for a long time. HCA has this and it is great!
  2. Thank you!! I now have a way to do the things that I wanted to do. Some people are so far ahead of me, that it isn't even funny. Thanks again.
  3. I was hoping that there was a way to get the temperature pushed to the ISY. Then I could use it in a program to do other things.
  4. Does anyone have any idea as to get the temperature from the motion sensor? I can not find any way to get the temperature to update.
  5. south replied to south's topic in ISY994
    Thanks, I was getting a little concerned about it. But as long as it is OK then it is good. Again thanks.
  6. I have been seeing dofferent things when looking at the about window: Firmware is v4.05 Ui is 4.0.11 Is this correct or have I done something wrong? I have cleared the java cash many times and restarted many times but still see the same. Thanks. Bob
  7. My lamplinc is (B2457D2) Lamplinc BiPhy v.41
  8. Thanks, tried your program, but no beep. It needs to be enabled some way. I do not know how to do that.
  9. How do you get this to beep? Smarthome says it software configable, does the ISY 994 support this?
  10. I have aApplianceLinc 2002SHL3 which has lost it's ID label. How do I find out what it is?
  11. I can not seem to get anything when trying to check out with google. Am I doing something wrong or is it not working?
  12. I too have been having trouble with programs running when they are not turned on or timed. It seem that in my case the Variable is not being read correctly. This morning I had over 1,000 e-mails from that program which should not have been running. Which caused my e-mail provider shutting down my account. Bob
  13. Wow !! You make it sound so simple ! Thanks for the 3rd Wed program you made a while back. It works GREAT ! When I do buy the board, I will post back here to let you know how it works. Thanks, Bob
  14. I do not have the Elk sys. I have looked at what you have suggested but I am not that good doing things like that with out help from someone who knows about such things. Thanks, Bob
  15. Hi Was wondering if onyone is able to get the inside temp of their house with out using a Vestar? I have been wanting to do this for a long time but without any luck. It would be nice to do this for heating with a portable heater or a fan in the cold months. And turn on the window AC or fan in the warm months. Thanks ! Bob
  16. With 3.1.12 I was having a lot of my motion sensors and KPLs not working correctly. Since the up grade Things are back to working again. THANKS !! UD is the BEST !!
  17. Thank you for posting this, it will be very helpful to me and others. This and the others are of great work. Thanks again !
  18. That's no problem. Do I need to rebuild the e-mails or are there some other solution?
  19. I access from here: http://www.universal-devices.com/99i/2.8.9/ This started when I upgraded from 2.7.15 I believe. I may have been after that, not sure.
  20. Hi, it seems that all my E-Mail has been "Migrated" and I do not know how to get them so that I am able to edit any of them. Does anyone have any ideas of how to get them back?
  21. I had to upgrade 7 times but the last time seems to have worked. I have logged on 3 times and all seems ok. If I had seen your post earilier I would hae been very happy to let you log on to my system. If I have any more trouble I will let you know and then you will beable to log on, OK?
  22. After updating, I do not get any status on any devices nor do I get any weatherbug information. I cleared java several times with the same results.
  23. south replied to south's topic in ISY994
    Does the last run time have to be precise or can it vary? Most people walk at a different pace so the time will be different. Is there a way to compensate for this? Thanks
  24. south replied to south's topic in ISY994
    This is what I have: From last run time for "Coming in" for 1 minute But does not seem to work, am I missing something? Or do I need to add something?? Thanks.
