midrar
  1. Anytime we lose power, my EISY controller loses the ability to control my ELK M1 Alarm through the EISY node. What I've learned is I have to restart the node and then go into the UD user interface and actually set the state of the alarm in any mode and that seems to restore the communication between the two. While this isn't a common issue, it's still not ideal. Has anyone seen this similar issue and how reliable has the ELK node been for you guys?
  2. midrar replied to midrar's topic in Insteon
    Twice in 6-12 months. I’ll do that, thank you.
  3. midrar posted a topic in Insteon
    I recently replaced my PLM with a new one around 6-12 months ago. This is the second time where I found my keypad wasn't activating programs. I cycled power to the PLM and EISY with no change. I restored the PLM and that resolved it. The bigger issue is why is this happening?
  4. How well does this plugin work? I have several landscape lights and would like to create a cascading effect where each individual light turns on sequentially along a pathway through a program in the EISY.
  5. midrar replied to William Olsen's topic in ELK
    After unsuccessfully not being able to restore communications, I went to bed and woke up to communications restored.
  6. midrar replied to William Olsen's topic in ELK
    Yes I am. For the last week, I have lost the integration between the ELK and EISY. I don't see anything wrong and UD Mobile shows that ELK is connected. Did you get it to work and if so, how?
  7. What do you mean by the UD Mobile Command class? Is this an actual webinar that teaches to about the app or is this a command instruction you perform in the app?
  8. Great, thank you.
  9. Can you keep your smart wall controlled with motion and add a second simple push button like the one you linked for a total of 2? If that’s the case, that’s probably the best method to tie into an elk m1 instead of hacking a wireless remote in my situation.
  10. midrar replied to midrar's topic in Ring
    That worked. As soon as I went into program, I was able to see the option for Ding. Thanks for the help guys.
  11. midrar posted a topic in Ring
    I have a Ring elite doorbell and just installed the Ring nodeserver. I only see 2 nodes that were installed. One for battery health and the second for motion. What about actual press of the pushbotton on the doorbell? Shouldn't that be a ring or am I missing it?
