AT&T to end email-to-text ×
TVogl
  • Posts
    6
Everything posted by TVogl
  1. TVogl
    Polyglot on new EISY
    And with this update I am done for the evening. The two node servers that did install, "holidays" and "Sun" look like they work about 75% of the way. Meaning PG3 installed them cleanly. They show as "connected", they generated nodes and populated them in PG3, but in the ISY the nodes appear, but there are no values. Let me close with this: I love UD - I have been an avid fan of the isy since I bought it in 2014. This eisy box is awesome (FAST!) and I understand it may take awhile to work thru early release issues. Thank you all at UD - I look forward to working through these bumps in the next few weeks and can't wait to retire my isy994i.
  2. TVogl
    So here is any update. I was able to install a few other PolyServers: "holidays" and "Sun & Moon" both installed first time without issue, but "MagicHome", "roku" and "NOAA" weather all refuse to install with the same error: "Node Server install of undefined failed with message: status is not defined".
  3. TVogl
    Were you getting this error when installing/reinstalling: "Node Server install of undefined failed with message: status is not defined" - or was it just not starting?
  4. TVogl
    Thanks but no dice. The "(re)install" for Roku says "Can't find puchase option for license record". and does nothing. And yes, "purchase" is spelled wrong in the message. The "(re)install" for MagicHome offers to let me reinstall in the same slot, but when I select it, I get: "Node Server install of undefined failed with message: status is not defined" Both are clearly in the purchased list (see attached screen shot) - even though they are the trial licenses. Also tried deleting and re-adding. Same results.
  5. I received my new EISY. I have not yet migrated my isy994i config, nor moved the Insteon PLM so this is a very clean installation. I was trying to play with PG3 and I tired to install the MagicHome Trial. It throws an error message during the install and then never runs. I see items like this in the general log. There is nothing in the MagicHome log and the service wont start at all. I am posting this problem here rather than in the Node Server site because I am having the same problem trying to install the ROKU polyserver also - so I suspect something with my EISY config rather than a Node Server specific issue. Any ideas what I am missing? 12/29/2022, 15:38:31 [pg3] info: [00:21:b9:02:5f:a5_2] :: Creating Node Server 'MagicHome' 12/29/2022, 15:38:31 [pg3] info: Adding customparams entries to custom database 12/29/2022, 15:38:31 [pg3] info: Adding nsdata, oauth entries to custom database 12/29/2022, 15:38:31 [pg3] info: [00:21:b9:02:5f:a5_2] Set nsdata 12/29/2022, 15:38:31 [pg3] info: [00:21:b9:02:5f:a5_2] Set oauth 12/29/2022, 15:38:31 [pg3] info: checkLicense:: Updaing MagicHome subscription expiration to 2023-01-29T19:22:03.000Z 12/29/2022, 15:38:31 [pg3] error: createNS: ReferenceError: status is not defined at checkLicense (/var/polyglot/node_modules/@universaldevices/pg3x/lib/services/node servers.js:710:95) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Object.createNs (/var/polyglot/node_modules/@universaldevices/pg3x/lib/services/node servers.js:433:5) 12/29/2022, 15:39:45 [pg3] info: [00:21:b9:02:5f:a5_2] Retrieved customparams 12/29/2022, 15:39:45 [pg3] info: [00:21:b9:02:5f:a5_2] Retrieved oauth 12/29/2022, 15:39:47 [pg3] info: startNs:: MagicHome 12/29/2022, 15:39:47 [pg3] info: startNs:: MagicHome is valid 12/29/2022, 15:39:47 [pg3] error: MQTT on Inbound processFunction: ReferenceError: status is not defined at checkLicense (/var/polyglot/node_modules/@universaldevices/pg3x/lib/services/node servers.js:710:95) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Object.startNs (/var/polyglot/node_modules/@universaldevices/pg3x/lib/services/node servers.js:915:20) 12/29/2022, 15:41:00 [pg3] info: [00:21:b9:02:5f:a5_1] Retrieved customparams 12/29/2022, 15:41:00 [pg3] info: [00:21:b9:02:5f:a5_1] Retrieved customtypeddata 12/29/2022, 15:41:00 [pg3] info: [00:21:b9:02:5f:a5_1] Retrieved oauth 12/29/2022, 15:41:01 [pg3] info: Starting log stream for pg3frontend_fOuoq :: /var/polyglot/pg3/ns/0021b9025fa5_1/logs/debug.log 12/29/2022, 15:41:01 [pg3] error: unhandledRejection REPORT THIS!: [object Promise], reason: Error: ENOENT: no such file or directory, access '/var/polyglot/pg3/ns/0021b9025fa5_1/logs/debug.log' 12/29/2022, 15:41:03 [pg3] error: downloadLog: Error: File not found: /var/polyglot/pg3/ns/0021b9025fa5_1/logs/debug.log at Object.addLocalFile (/var/polyglot/node_modules/adm-zip/adm-zip.js:258:23) at /var/polyglot/node_modules/@universaldevices/pg3x/lib/routes/log.js:133:16 at async /var/polyglot/node_modules/@universaldevices/pg3x/lib/services/https.js:48:9 12/29/2022, 15:41:49 [pg3] warn: verifyNodeServers (00:21:b9:02:5f:a5) :: ISY has no node serv
  6. Same problem here. If you use the CLOUD admin it will let you in, but the LAN admin portal shows this version error.
  • Create New...
