d2inco
  1. I have 3 Insteon Leak detectors that I had set up with my initial isy99i setup. I had the Wet & Try nodes show up in the device tree, and I figured all was fine until a friend asked what the Heartbeat node was on his. I don't show the heartbeat node here. I converted my entire configuration over to my new 994i when I got it several months ago. Was addition of monitoring Heartbeat a new 994i thing? or a newer firmware on the leak detector? Is there any way to get the node added without removing and adding the device? I don't want to have to go back and tune my programs that reference the leak detectors, if i can avoid it. Thanks!
  2. Great, look forward to that! Got some mismatches in my device namings right now! Sent from my Xoom using Tapatalk
  3. Michel, what about the default names? Sent from my Xoom using Tapatalk
  4. But the default name has a slash in it. If /'s are not allowed in device names, should the default be changed, then? Sent from my iPhone using Tapatalk
  5. In trying to change just the prefix. It's all one field, it still complains that there is a "/" in there.
  6. I'm adding in 3 new 2420M motion/occupancy sensors. It adds each device, and the associated two "Dusk/Dawn" and "Low Bat" entries fine. When I go to rename the prefix on the Dusk/Dawn device, it complains about the "/" in the name. Is this a change from previous versions? ie, I'm trying to rename "Sensor3-Sensor" to "Upstairs-Sensor" (this succeeds) but "Sensor3-Dusk/Dawn" to "Upstairs-Dusk/Dawn" fails with the "Invalid File/Folder name: / - Upstairs-Dusk/Dawn" Do I have to come up with a new naming scheme for the Dusk/Dawn element, or was this fixed in 3.1.14? Thanks!
  7. Brad; Sorry for the delay. I checked this from three machines, both the .JNLP icon on the desktop, and and by navigating to the /admin URL. On the 3rd machine, there were no java-cache issues, since I had never been to the ISY from that browser before. I see the same issue on the other boxes still, so I don't believe it is a cache issue. Let me give more detail on the simplest of the setups: My Breakfast room has one light, on a SwitchLinc. It is also controllable thru Button #2 on the KPL8 in the Kitchen [Name], and that 'control' is managed/linked through a scene [break Rm Scene]. If I go into the Program Details for a program that I have to set the on-levels, you'll see in the Actions area that I can only select the primary load, "Breakfast Rm Light" there .... and the 2ndary controller, the KPL's button #2, shows up outside of the Breakfast Rm Scene, in the "In Scene" drop-down, not within the "Scenes/Kitchen Scene" scene . To me, it would make more sense being within the scene, since it is actually attached to the scene..... Hopefully I am relaying my confusion well enough? Thanks, David (if you want to HTTPS into the GUI, PM me, and I can set up that forwarding really quick)
  8. I am trying to accomplish the same thing here, but in my Program, I only have the choice to select the light/load, and not my RemoteLinc button or buttons on other KeypadLincs to make the adjustments. Any chance this is a problem in the 2.8.10 GUI?
