EW1
  1. I added some devices to my daughter’s apartment in NY (keypads, switches, etc). However, I was surprised to find no ground wires. All the boxes are metal and the wire is in metal conduit. Are the boxes and conduit the ground? Should I be tapping into that? Nothing preexisting seems to be wired to the boxes or conduit.
  2. Actually, adding the wait 1 hour is a mistake. Although the sunset time is showing an hour early, the next scheduled run time is correct (i.e. one hour later than what is showing as sunset time).
  3. On 5.7.0_5 also, and same issue. For now, I just added a Wait 1 hour to my sunset programs.
  4. Same issue with all programs disabled and sunrise/sunset an hour early. I'm on 5.7.0 Has anyone opened a ticket?
  5. Started today for me. In the App, under notifications/settings, you can scroll down to groups and customize which users get which notifications. I just turned off System Notifications for everyone. This isn't really a fix, but at least stopped all of the notifications. This is a useful feature though - my wife only needs the Push notifications, not System, UD or PG3.
  6. EW1 posted a topic in eisy
    When migrating from ISY to EISY, does anyone know if the node numbers assigned to scenes will be the same? I use the REST API for my iOS apps and they are all hardcoded (e.g., /rest/nodes/27302/cmd/DON/).
  7. EW1 replied to macjeff's topic in Ring
    Thanks for posting. I've been using an Insteon Hidden Door Sensor, but I'm not 100% happy with it, so nice to know there are other options.
  8. I don't have any yolink devices either. However, I do use a standard doorbell button to trigger the chime, video call to house phones and push notification to an app for camera/speaker/microphone/access control. I found that lighted doorbell buttons had issues being sensed when not pushed long enough. I switched to a non-lighted button and it has worked flawlessly since.
  9. The serial PLM should come with the RJ45 to DB9 cable, so should only need the DB9 to USB cable (at least they used to come with it).
  10. Thanks for the help. Just knowing that it was possible got me on the right track. Sonos has pretty good documentation of their API and there is a DesiredVolume control. Pasted below in case any others are using the old school network resources instead of a node server. <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetVolume xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1"><InstanceID>0</InstanceID><Channel>Master</Channel><DesiredVolume>20</DesiredVolume></u:SetVolume></s:Body></s:Envelope>
  11. I have an ISY994 and Sonos 2.0.8 running on a rpi. I haven't actually used the node server yet - my programs are old and done with network resources. An example is below. I'm only seeing volume up/down options with the node server I have. I suppose I could send enough volume down commands that even from 100% it would go to zero, and then send a few volume up commands to get to desired volume, but this doesn't seem very elegant. Also, I don't think I can wire shark the set volume to desired percentage given the app doesn't seem to have this option either, just up/down. POST /MediaRenderer/AVTransport/Control HTTP/1.1 Host: 192.168.0.252:1400 Connection: Close Content-Type: text/xml; charset="utf-8" Content-Length: 267 SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Play" <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:Play xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><InstanceID>0</InstanceID><Speed>1</Speed></u:Play></s:Body></s:Envelope>
  12. EW1 joined the community
  13. I have a couple rooms with a single keypad button used to set sones to a preselected favorite for the room and play or pause. I also have a couple rooms where the primary light switch fast on and fast off triggers sonos to play/pause a favorite channel. This generally works well, except when the last person to use sonos in the room has adjusted the volume very high or low using the app. Is there a way to send a fixed volume percentage command vs just volume up/down commands?
