CNelson03
Everything posted by CNelson03
  1. So far my attempts at using the 'Hue' plugin have caused more 'edge cases' than the Network Resources (quirky bugs especially when trying to control a 'group' of lights with individual light commands) and using a 'Wait' command slows things down too much due to the 1 second minimum wait time. Hopefully the new light grouping capability (in the Hue plugin or UD) will resolve. I'll plan on testing both when available.
  2. Thanks @Javi , I'll check out the grouping of lights when it is available. However, I'm not sure that it will address scene recall. Hue Gradient Lightstrips can display shifting color patterns (e.g., fade from one color to the next across the length of the strip). These light effects can be grouped across multiple lights and saved in the Hue Bridge. From there, a Hue API v2 'Recall' command can easily play the 'scene'. I currently have a Network Resource execute the scene Recall command and that works fine except you end up with quite a few Network Resources (using UD variables does help with things like setting different brightness levels). It sounds like the new Hue 1.1.1 plugin will also be able to execute these recalls providing an alternative method. But unless there are plans to phase out Network Resources (hopefully not), either method should work.
  3. I have a more complicated Hue implementation that I've used Network Resources to control, but the number of NRs is quite large and harder to manage in the new eisy-ui interface (but overall I like eisy-ui :- ). I tried the production 'Hue' Plugin, but it doesn't support (or seem to support) grouped_lights or scenes (plus exhibits some odd behavior from the lights at times). This new 1.1.1 version sounds like it may support grouped lights and Hue scene recall. I'm willing to test it out, but am not familiar with setting up a local node server (plugin), I've only installed existing plugins from the Store. I looked through the linked PG3 instructions but wondered if I should be installing directly in eisy-ui (vs PG3 and migrating). Perhaps @Javi could recommend an approach? New instructions for that? Any other tips on getting started? UPDATE: Digging a bit deeper into the 'forking' process, I think this might be a bit complicated for me at this point, but I would be willing to test a Store non-production plugin.
  4. I have 'TestFlight' on my iPhone and UD Mobile updates through that (this might give me advanced releases?) However, on my iPad, I see that UD Mobile version 1.3.4 downloaded from the App Store a few days ago.
  5. I had a similar sync issue (different message but app crashed when trying to sync. Javi recommended updating to a new UD Mobile version 1.3.4. I'm having some other issues with PG3, but upgrading to 1.3.4 fixed the sync issue on my iPhone and iPad.
  6. I'd put 'tab tiles' high on my wish list. If you're setting a system of multiple remotes (e.g. separate pages (folders) for the TV, the AVR, the CD player, etc., being able to call a common 'tab' from multiple pages would be very handy. As it stands now, you have to navigate up and down the sub-folder chains to get to the common 'shared' folder (or totally replicate the common folder in each hierarchy and that's a real pain to upkeep). If you need input on a use case or requirements, I'm happy to provide. The UD Mobile interface seems pretty capable once you figure it out (albeit I'm still learning :- ); having this link or tab capability will make it better, especially for creating a system of virtual remotes.
  7. @Javi Synchronizing did fix the 'spinning' tile issue. I then set the tile Display Node to the projector on/off program, the Display Status field to "Status", and the Mapping Values equal to "Idle False" or "Idle True" (instead of a variable = '0' and '1') produced the same end result -- a 'toggling' Command type tile with the changing colors and the "ON" and "OFF" text. I'm using the variable for some other logic so I'll stick with that approach, but good to know both ways work.
  8. I have a folder ('Favorites' page) that I would like to call from several other folders. Is there a way to create a favorite that links to the folder? As it appears now, you can create new sub-folders (pages of favorites) under the parent folders but you have to re-create all the favorites in these new sub-folders. It would be easier (and less maintenance) to just link instead of copying. Essentially this might be a Favorite Type of "Link", i.e., one that points to another existing folder. I don't see one of this type in the "Add Favorite" list but perhaps there's another way to do something similar?
  9. It's on iOS (iPad). In the "My Programs" list, I picked the name of the program that does the toggling on/off as the Display Node and the Display Status field says "REQUIRED!". Opening that is a blank list so I cancelled, and pressed "SAVE" back on the Edit Favorite screen. It returns to my Favorite page (folder) but the 'Projector' favorite now has a spinning wheel over it (that just keeps spinning forever). It's not really a problem though, as I like my int variable approach, it's a nice way to create a toggle button that not only changes color, but change the Status value to be either 'ON' or 'OFF' based on the variable. So now the along with changing the icon color red or green, the favorite reads "Projector ON" or "Projector OFF" (depending on the variable value). I don't know if there's another way to change the favorite text, but this worked pretty well. Here's what the favorite looks like (these are two images of one favorite tile that flips back and forth depending on the projector status): This 'ON' button toggles to OFF when pressed Normally, the variable value would be where the "ON" and "OFF" text are, but by using the "Set Formatted Value to" in "Mapped Values", one can make this change between "ON" and "OFF". Maybe there's an easier way to do this, but seems to work well.
  10. Ah, that's why Advanced Config is visible in the menu sometimes, and not others. I've created a toggling routine with the Command type Favorite set to a run a 'Run if' program (if on, then turn off; else on). The object controlled is a projector turned on/off by Network Resources, so there isn't a more traditional display node (like an Insteon switch). I tried setting the display node as the program itself but it just spins until I remove the Display Node. However, it did work to set the Display Node to a variable that is set to '0' or '1' by the program turning the projector on/off. The icon color now changes based on the value of the variable (colors set in 'Mapped Values' screen). I also set the "Formatted Value" in Mapped Values to show "On" or "Off" (vs displaying a '0' or '1'). I'm also going to implement the icon color change with some of the favorites that are mapped to Insteon switches so, thanks, this will be a nice feature.
  11. Here is the link -- I'm trying to create a toggle button that changes color (Question 2 & 3 in the post) Per your updated instructions, is that: Click the tile's menu (three dots), then select "Edit Favorite" and then...? I don't see the "Advanced Config" option (but know I have before
  12. Trying to get into "Configure Advanced Status..." per this method posted by @Javi 'Place Favorites Screen in Edit mode, Click the Favorite Tile, Select "Configure Advanced Status Color/Value/Icon Configuration"'. However, when I do this, clicking the Favorite tile only executes it. The screen shows the blue "Disable Edit Mode" bar at the bottom so I believe I'm in Edit mode, and I've tried restarting the app. Clicking the 'three dots' on the tile to enter edit mode doesn't bring up the "Configure Advanced Status" option. I know I've seen this option before, what am I doing wrong?
  13. I tried the solution above (uninstall existing 'beta' version and reinstall from production store in the same slot). Overall, it worked (now on 2023.1.9 [Production]), although I had a bit of weird behavior (one parameter (device) not populating with their IR 'buttons' but 'borrowing' from other parameters). But I've seen this before and usually re-pasting, re-starting the IoX and UD Admin screen a few times gets everything in sync. Thanks.
  14. Your corrected database worked, I was now able to upgrade the iTach-IR server. However, it still shows as "Beta" but the version is 2023.1.9 (without zeros) Per the sending of Global Cache commands with some erroring out, it's a wired (not wireless) IP2IR, and I tried connecting to it via a web browser and it was very sluggish. A power off/on reboot seems to have fixed that, at least for now, and I am able to send IR commands through the UD Node Server to the target devices.
  15. When I press the described "Update" button under "Purchase" and "Available purchase/install options", nothing happens (no dropdown or action other than the button going inverse to show I clicked it. I tried this button when accessing it via menus: "Plugins Store" and "Purchases" as well as under the "Dashboard > iTach-IR(1) screen > Update button" -- always the same result, just an empty click. It says I'm on PG3x Version 3.2.20 and IoX version 5.8.0. Ideas?
  16. I'm starting to work with the iTach-IR Node Server again (after not using it for the last year) and am getting some inconsistent operation -- sometimes a Global Cache code is passed successfully and works, sometimes an "Unknown Error (see Logs)" appears (and don't see much explanation in the node server log). I noticed I am on version 2023.01.09 [Beta] and it says there is a new 2023.1.9 version. Not sure if the update will solve the problem, but clicking the "Update" button (on two different pages) does not seem to update the Node Server. How do I force the update?
  17. Thanks @Javi, I was able to connect with just a local connection and still use the iTach-IR Node Server I set up. I see the Portal license is reasonably priced so I might go ahead and get that as well.
  18. I'm receiving a "System Closed" error when I open up UDM and it suggests trying a reboot (did that) but still receive the message. The eisy box appears to be working normal and I can login and control lights from the Admin Console. I can still open the Favorites section and the devices/buttons appear but clicking one returns an "Access license is expired." I recently migrated from a ISY994 that I had for many years, and it mentioned "Portal licenses" and a 30-day trial. Is this something to pay for now? I've bought modules in the past (e.g. Network Resources). I looked in my profile under the portal but can't find anything like "Buy now" or details. Or is there possibly another problem with the system?
  19. Good to know on the Favorites, especially if I happen to notice a previous Favorite button missing. For the Sherwood receiver that I'm creating favorites, I have noticed that some (like Power On/Off) are working, while others (like Volume control/mute) are not. I figured this may have been because the "Sherwood" codes I downloaded from the GC Control Tower, were not for the same unit that I had (usually the vendor codes are common across a line, but I suppose not always). Maybe there was a bad code in there? I'll have to do more research as I do have the codes for my Sherwood recorded from a previous iLearn session that I did for my iRule controls. Thanks!
  20. UPDATE: I went into Polygon and found "sherwd" in a previous test node server "iTach-IR(4)". I deleted the "sherwd" line/node and nothing changed (message-wise) but when I deleted the whole "iTach-IR(4)" node and then synced, I received the message that I received yesterday about the values to be removed. So I assume the "iTach-IR(4)" node deletion triggered the 99 missing values this time (not sure what did yesterday) and the "sherwd-NAME" in iTach-IR(4) was part of the problem. After backup, I selected the "Remove Unused Values" and synced. There was still a sync error: "1. could not match ND paramName error" but there was another old/test Node Server in Polygon, "iTach-IR(3)", and after deleting that and syncing a couple times, all the errors had cleared. So it appears those messages are 'normal' if there are unused things, or something has been deleted and changed. Good housekeeping rewarded (hopefully).
  21. I'm working on building out a UDM-based interface on the iPhone and yesterday when I sync'ed UD Mobile (Settings>Systems>My Home), it downloaded many of the new Network Resources commands from eisy. At the end it said there were eight bad codes and did I want to remove these, so I said 'yes' (after the option to backup). At the end of the sync there was a screen similar to this: I selected 'Finish' and everything seemed to work fine except for the Sherwood receiver IR commands that are in the iTach-IR Node Server. One of the messages above mentions 'sherwd-NAME' so I'm guessing the errors are related to the iTach-IR NS. When I looked at the Admin Console, the entry for the Sherwood receiver was missing under the iTach-IR node. It was a bit late, so I left it and when I tried syncing again today, I received a similar message (the image shown above) but in looking at the iTach-IR Node in Admin Console, the node for the Sherwood was back again and the Sherwood commands are now working on the UD Mobile app. I noted the error message has a slightly different name than Admin Console ("rwood-receiver" vs "sherwd-NAME") but the Node Server node was created a couple times when I was trying to get it to work initially. So I'm not sure if that's part of the problem, but wondering why I'm getting the errors and the inconsistent operation. It was working fine before and I didn't change anything related to the Node Server (all the new adds were Network Resources.). @Javi Any ideas?
  22. I did some additional work on migrating from my iRule-based system to UD Mobile this weekend. In digging through some Global Cache documentation, it sounds like no matter what form you enter the commands (literal, hex, decimal, mixed), it must be converted to its "byte forms" before being passed to the serial port. So both iTest (the Global Cache test utility) and Network Resources must be converting the command string to machine readable form. I assuming the reason some things work in iTest, but not Network Resources, is the string to byte conversion the tools are doing. Here's a few observations: A format that works for one device (e.g. literal), may not for another -- it pays to test different approaches (especially 'binary' (decimal) for any string that has non-readable characters like STX \x02 in the projector, or BEL \x07 in your example); There is no command structure for serial data and the 'setstate' command is not needed for GC serial RS-232 ports unless maybe if you are doing something GC-specific like setting baud rates, etc. Some devices may just ignore these commands and work fine (e.g., Marantz), while others throw an error (e.g., Dayton Audio). The 'command' ports (IR and CC-relays) do require a leading GC command (e.g., sendir or setstate) in Network Resources (hence Javi building a command string in the iTach-IR Node Server). 'C-Escaped' in Network Resources means ending with a carriage return. A \r or \x0D is enough, you don't need to a line feed (\n) (although I think some things in iRule may have required this, at least per an old note I found). With the 'binary' mode, an ending CR (20) wasn't needed (but didn't seem to hurt at least in my case, but this may depend on the device.) With all of the above, a bit of trial and error may be needed to see what works for a specific target device. Per a possible IP2SL node server, this still would be nice for devices that have lots of commands (e.g., AVR or multi-zone audio). However, as I migrate from iRule to UD-Mobile, I decided not to try to recreate every button/macro from the physical remote (like I did in iRule), and just build a simple iPhone remote that would do the things that I did 90% of the time (volume, select source, etc.) A design choice? Yes. But so far it seems to be working, and in this case, just creating Network Resources for the things I need seems easy enough. Network Resources are also fine for the CC-relays as there's only two commands for each relay (ON and OFF). That said, for the whole house audio system with a dozen zones, each with a couple dozen commands, an iTach-SL Node Server would be much cleaner approach than hundreds of Network Resources. I'm also currently having trouble with my iTach-IR Node Server, but I'll put that in a separate post.
  23. UPDATE: Using an online ASCII Conversion Table, I was able to convert the Panasonic projector command in the previous post, \x02PON\x03\x0d into the binary 'decimal' format that it was looking for: 2;80;79;78;3;20 Entering the binary string into the Network Resource (with Mode=binary) recognized it as a PON (power on) and the command did work to turn on the projector: A similar POF (power OFF) command (2;80;79;70;3;20) did work as well. So it appears that sending IR2SL RS232 commands using Network Resources (or a Node Server if that is developed) for different devices requires flexibility in command structure, inclusion/exclusion of "setstate,x:y,", the selected mode, and port (for GS-100-12 it could be 4998, 4999, or 5000). A Node Server could make this easier, but probably will be a challenge to write without some programming skill and at least more documentation on how it all works. Handling the return codes (for things like getting the current volume level) could be an additional challenge (but really cool Next up: tackling IP controlled devices...
  24. Thanks, removing the 'setstate,1:1," did indeed work. Interesting as the 'setstate' works with the Marantz AVR that I have connected to another iTach IP2SL. It is required when setting the contact relays on/off (on a GC-100-12 or (I assume) an iTach IP2CC). I believe it was working with the isy994 as well, but as noted previously, I primarily used the iRule device/gateway method to pass the codes so it might have been it didn't work on the isy994. Either way, working now for the Dayton amp, so thanks. I did also try the other ideas you suggested: Swap <cr> for \r\n: That didn't work, at least with this device in my system. The Resource Response pop-up just returned the whole command string (including the <cr>) Use Raw Text instead of C-Escaped: I tried this with both the <cr> instead of \r\n and with the suggested method (no "setstate,1:1") and neither worked. I also did some additional testing with other devices in my system: The Marantz AVR works with either "setstate,1:1,@PWR:2\r\n" or just "@PWR:2\r\n" in the Network Resource body. Raw Text didn't work for me. I have an Oppo DVD player that uses similar commands to the Marantz (e.g. #PON to power on) and that also will work with, and without, the "setstate,1:1" statement included (C-Escaped method). Last, I have a Panasonic projector, it uses a different command structure with not just literal characters but mixed hex and literal characters. The basic command structure is STX|command|:<optional parameter>|ETX (where STX is hex \x02 and ETX is hex \x03). This command string in iTest works to turn on the projector: "setstate,1:1,\x02PON\x03\x0d" (where x0d is Carriage Return and you select 'Mixed' command type in iTest). However, the same string called from a Network Resource, with or without the 'setstate', returns a pop-up window error containing the message: "TCP client read response failed [Net Module Rule: 62]" (same message for Raw Text, C-Escaped or URL). And unlike with the Dayton amp, no additional error message or ASCII Response shows up in iTest. I didn't try creating a binary string in the Network Resource as I'm not sure my coding skills are quite that good but I did try with/without and ending carriage return. Ideas on this one?
  25. While somethings are working fine, I'm having a couple problems with the eisy to IP2SL232 setup. Here's one of the problems: I have a Dayton Audion DAX66 Distributed Audio System (multi-zone whole house audio controller). The serial command to mute zone 16 is "<16mu01" (zone 16 mute on). It works through the Global Cache iTest utility: I've setup Network Resources in eisy with the same command to mute the volume but receive an error: (Note the \r\n is a Carriage Return/Line feed and should be converted to an invisible character in the "Actual" box above) After running the Network Resource, and looking at the iTest tool, I see that the command from Network Resources went through, but this time returned an error (and the additional 'setstate' command text was visible. I have other IP2SL commands that are working through a Global Cache GC-100-12 and I believe these were working for the Dayton in the ISY994 box (my primary method was from iRule and that's no longer available). Can't help but think I'm missing something obvious, any ideas?
