DEGoodrich
Everything posted by DEGoodrich
  1. I have been using my ISY-26 since my 99 broke. But I really do miss all the special prograns/remote control/the modules/ and now some new features, that are not available on the 26. I did manage to upgrade the menory in the 26, So I was able to fit more programs. I finall figured out what happpened to it! I havw POE on my LAN for the IES TP (48VDC). I must have plugged the RJ-45's in the wrong ports. I did not figure that out until I took it appart and looked at it under a very powerful magnifier, There is a very tiny spot on one of the chips. (it must be a burn) Everything else looks perfect Can it be repaaired, ot is it possable to just purchace a new board? I can not afford a new unit at this time. Dennis http://cid-a45c7353fe6f4c5a.photos.live.com/play.aspx/ISY?ref=1
  2. All of the LED's are normal. I was running 2.7.6. Can I connect both ISY's at the same time, so you can take a look around?
  3. Yes I am. I am in the lengthy process of setting it up. Unfortuiantely, I have not saved any old backups from it.
  4. My PLM's are different versions. They all work with the ISY-26. I tried different cables. They are all fine. I was able to export/import some of my programs, but the devices are not there. Example: If From Sunset + 10 minutes To Sunrise - 10 minutes (next day) Then Set On Else Set Off I was able to manually add most of my devices by linking my keypads. Of course only the address not the name is added to my network. Also some scenes were added, but they are named "Scene 1â€,†Scene2â€.....â€Scene 39â€, etc. Luckily, I am able to use my topology report to help figure some of this out.
  5. My ISY-99 died! I have been trying to get my old ISY-26 to work until I can replace my ISY-99. Is there a way to import my links, scenes, and programs to the ISY-26 from a backup from the ISY-99. At one point I was able to import the programs, but the was way too many to fit in the memory. I deleted about 400 of them, since they were incompatible with the ISY-26 anyhow. I don't really know what killed my ISY-99. It happed after I added the weatherbug module and a beta version of iLink. Every time I tried to use my iPhone to access the ISY-99 it would lock-up, and I would have to reset the ISY after about 10 times, the thing just died. It showed all my devices and scenes, but would not show the status or have any control. The programs just disappeared. It also showed that there was no PLM connected. I have 4 PLMS. I tried all of them, but it would not communicate with any of them. I also tried to replace the memory card and reload the F/W.
  6. I had a similar problem. After the DST change, my clock did not update. Also all of my programs ceased to function. Lat run and next run were all blank. My IES TS ceased to function also. I reset the ISY-99 and the IES. All is fine now. I am running 2.7.1
  7. Thanks, it works. Is there a way to adjust the zoom. It zooms to much now.
  8. Is there a way to use the iPod touch or iPhone to interface with the ISY? I have tried, but the HTML screen is very tiny and unreadable. I also can not figure out if I can install java on it.
  9. DEGoodrich replied to C Martin's topic in ISY994
    Not related to these products, I saw a program on "Moder Marvels" that showed a new device that works with your irrigation system. It receives data from your local weather station, that includes forcasts, precip, temp, and humidity. The system decides when and how much water to give! Sounds pretty interesting!
  10. I have Over 60 scenes. Most all of the are actually just "groups" that are strictly used for my 600+ programs. There is only about 8 "scenes" that I directly control. Mostly I use the TS and Remote to control lights individually. I have set up a few "scenes" for the remote ony. For example: I have a scenes for "snack, doorbell, telephone, bathroom. When I press the associated button on the remote, it pauses the DVD or Live TV, turns on the lights for the task. Then when I return, Press the return button, and the lights go off and the TV resumes. The Ultimate couch potato remote! Read my post on how I am using the remote. http://forum.universal-devices.com/viewtopic.php?t=997 I have fixed the problen by adding seperate scenes for on and off, like you suggested. On for the rates that I wish, and off to return the rates to 2sec. Thnaks, Dennis
  11. I noticed something very interesting today! I have been having problems with ramp rates when controlling lights from the remote control. I have had this problem ever since I upgraded to the /IR. Now I have the touchscreen and it does the same thing. The ramp problem is only on certain lights, but not all the time. It appears that the ramp rates are changed by the "Scenes" (on and off). And stay the same unless it is changed back by another scene. When controlling localy is is not a problem. This is not really a bug, just writting the programs and scenes correctly. I have a timmer program tat turns on a scene at 6am and off at 7am. It turns on all the lights I need to get ready for work. This scene has a ramp rate of 5min. The glitch in my programming is, that I have the scene turn off at 7am. So my "wake-up" scene turns on and sets the ram rate to 5min. Then I leave the house for work (about 6:45), and I press the "all off" button on the keypad, which turns off another scene, and sets the ramp rates back to 2 sec. Then at 7 the "wake-up" scene turns off and sets the ramp rate to 5min again. So, I just changed my program to only turn on the lights. Then when I press the "all off" button, it puts the ramp rates back to normal. Strange it took me this long to figure that out! Like Mr. Slowsky (the Comcast turtle) says "Yes, and/or DUUUHHH. Sorry, and/or my bad"
  12. Thanks. I forgot to ask, I have my own domain. Is there a way I can use it, instead of that? I think it does, because when I installed the router, my Guide Data would not update. So I had to open the ports. If I change the ports on the ISY, what number do I use? It did not help.
  13. I have finally set up internet access in my ISY yesterday. I love it! Perfect timming! I left work early today, so I went in and set my A/C don from work. It was ready forme when I got home! I have a few questions about this: I spent alot of time trying to figure it out and read everything on it. #1 The address I put in in just a regular IP https://xxx.xxx.xxx.xxx/ (not the format I have read it should be) http://your.isps.address:your.isys.port/0/x Is this a security problen? #2 I have configured the Ports and Port forwarding I see that the ISY uses 80 & 443 Media Center also uses the same ports for Guide Data. Will this cause a problem? #3 I have done the Self Signed Certificate, but I still get the warnings. What did I do wrong?
  14. DEGoodrich replied to aLf's topic in ISY994
    OMG That just blew me away, so early in the morning.... I just thought i might see if anyone else has noticed the strange thing I have discovered? : I have noticed that the order of several grouped "and" conditions and also several "or" conditions grouped together makes a difference on the outcome of the program becomeing "true" or "false"! Is this by design? If so I would love to know exactly how the programs are "scanned". Maybe it is just a timing thing and my brain is going faster than the CPU in that "Black Box" thing. Does it scan the programs in a specific order, does it finish one before starting another? It seems to me that it is processing the programs as if they were all one.
  15. OK, I am done with IR stuff for now! Now I am working on Voice Commands!!
  16. I have discovered a fast way to "Batch" generate theese programs! Export the tree, use an XML editor, use "Find & Replace", save as the new tree, then import. Over 500 and counting! I hope this thing does not BLOW UP
  17. Here is a sample program tree to control 1 light. Each light consists of 15 programs. START SEQUENCE (Allows selection of multiple lights before sending command.) If IR '[12]' is Pressed Then Wait 30 seconds Run Program 'IR Bed Left Start' (Else Path) Else - No Actions - (To add one, press 'Action') STOP SEQUENCE If ( IR '[0]' is Released Or IR '[10]' is Released Or IR '[50]' is Pressed ) And Program 'IR Bed Left Start' is True Then Set 'Bedroom Left' Fade Stop Run Program 'IR Bed Left Start' (Else Path) Else - No Actions - (To add one, press 'Action') LIGHT ON If ( Program 'IR Bed Left Start' is True And IR '[10]' is Pressed ) Or ( IR '[12]' is Held And Program 'IR Bed Left Start' is False And Status 'Bedroom Left' is Off ) Then Set 'Bedroom Left' On Run Program 'IR Bed Left Start' (Else Path) Else - No Actions - (To add one, press 'Action') LIGHT OFF If ( Program 'IR Bed Left Start' is True And IR '[0]' is Pressed ) Or ( IR '[12]' is Held And Program 'IR Bed Left Start' is False And Status 'Bedroom Left' is not Off ) Then Set 'Bedroom Left' Off Run Program 'IR Bed Left Start' (Else Path) Else - No Actions - (To add one, press 'Action') LIGHT BRIGHT If Program 'IR Bed Left Start' is True And IR '[10]' is Held Then Set 'Bedroom Left' Fade Up Else - No Actions - (To add one, press 'Action') LIGHT DIM If Program 'IR Bed Left Start' is True And IR '[0]' is Held Then Set 'Bedroom Left' Fade Down Else - No Actions - (To add one, press 'Action') LIGHT SET LEVEL (Repeat 8x (1-9)) If Program 'IR Bed Left Start' is True And IR '[1]' is Pressed Then Set 'Bedroom Left' 10% Run Program 'IR Bed Left Start' (Else Path) Else - No Actions - (To add one, press 'Action')
  18. I would like to posy my ISY-99i sample program here. Each light has 15 seperate programs. How do I do this
  19. I don't think he ever sleeps! I only wish others would give 1% of that. Thanks
  20. Nice Job! Great reference!
  21. Installed today. Works fine! Shows as "ApplianceLink"
  22. Thanks for the tips! As far as the fraction/secconds, I will try to make this breif, but.... I have EZIO8SA that will not work for what I want them for. The inputs are useless, but the outputs work just fine. I have 4 ceiling fans with lights. I have not been able to find an X-10 or Insteon fan speed control. So I have to make use with the RF remote/module with the EZIO8SA and the ISY. What I have done is I took 1 of the remotes appart and soldered wires to the PCB: 1-Common 2-Light 3-Low 4-Med 5-Hi 6-Off 7-Address DIP SW 1 8-Address DIP SW 2 (00=1, 01=2, 10=3, 11=4) Then I connected to the relay outputs. My program first set and holds the fan address, then pulses for 1 second the selected fan speed, then releases the address. This works perfect for the fan, but the light is a little more tricky. If the output is pulses for less than 1 sec, the light turns off or on. If the output is held for more tan a seccond the light brightens. Also I would like to install a KeypadLink in the wall for each fan. But I am not sure yet if you can use then just to interface with the ISY and not connect the load wire. I would use the large buttons for the light and the other 4 for the speed. This is a much too expensive and complicated work-around. I wish they would make a Insteon Dimmer type controller. I did try to use 2 in-line dimmers. It worked fine for the lights, but not the motors. They just vibrated and buzzed. Then I tried an in-line relay for the fan. It was like having a huricane in the house. We get enough of those here as it is!
  23. Thanks for the reply. I have ordered it. I will post my findings. If it does not link, I can use it in X-10 mode until it is supported.
  24. As mentioned before I am an advanced PLC programmer. Sometimes I can't help trying to emulate a PLC instruction. I usually figure out a work-around. Sometimes when trying to emulate a simple PLC instruction, it turns out to be a very lengthy and complex program. I have a couple of requests for future updates. Maybe "AD8BC" could try to better explain what I am trying to acomplish. #1) Being able to "nest " within prograns. #2) Ability to "force" a program to be true or false. So when a program is no longer running or stopped, it would be false. 3) Ability to use "program running" in an "if" argument. 4) This one I will definately need help explaining. ability to use the "wait" instruction status. (like PLC timmers) "/EN" enabled, "/TT" counting, "/DN" done. Aslo the timer progress, like "/ACC" accumilated. so if a timmer it set for 60sec, and it is enabled and counting, you could make a trigger like: if timer is enabled, counting, and greater than 30sec then .... 5) is it possible to use fractions of seconds? I know, I know, I am getting a little carried away with this. Good thing I live alone, any one would go crazy trying to figure out all of the scenes and button/paddle tap sequences. I would have to write a manual for all this. My neigbhor has already asked me "what are you doing in that house in the middle of the night", "I see lights going off and on all over the place", "I know you can't be running around the house turnning light off and on that fast" I explaind it to him. His question was "WHY?" and "You need to get a life!"
  25. DEGoodrich replied to a post in a topic in ISY994
    I do not know if this will help, but I had the same problem. For some reason I had no problems with X-10 on/off commands. The X-10 dim/bright commands did not seem to be getting through. I moved my X-10 controller to the same outlet as the ISY, then it started working. I still have problems if I hold the bright/dim buttons down though. It seem the the commands are sent too fast for the ISY to process. If I hold the button down the ISY gets very busy and sends nothing. when I release the button the commands are sent out. I am hoping to eliminate this problem with the new ISY. Then I can finally eliminate all of my X-10 stuff.
