jammer369
  1. Thanks for the info! I went ahead and purchased one T1800 and one T1700. The weird thing is that the T1700 reports back a humidity level to the ISY (~75%) and the T-1800 reports 0% which is correct since I do not have the humidity module in it. Any ideas?
  2. Getting ready to order a thermostat from SH and wondering if there is any reason to get the 7 day programmable version (T1800) over the 1 day version (T1700). Without having either, I was just figuring I would let the ISY control it and thus wouldn't have any use of the 7 day version. Am I flawed in my thinking? Troy
  3. I am trying to decide between the two and would like others opinions on what they like and why. They both seem to be similar from the screen shots on iTunes and both developers seem to be very responsive to my email questions. So which one do you prefer? Thanks in advance! Troy
  4. I am a newbie and have successfully installed the ISY and have it controlling all of my insteon switches. My question is this: was I supposed to press the set button on the PLM during the add insteon sequence or does the isy just know its there because it is connected to it. The PLM does not show up in "My Lighting" tree. Troy
  5. Keypadlinc v.33 I am not quite sure how the LED brightness levels work. I upgraded from version 2.7.6 where the LED brightness allowed me to set it up to a maximum of 63. That is where I had it set. I just tried to set it using 2.7.14. I set the On level to the maximum of 15 and the brightness on the KPL seemed to be cut in half of what it was previously. I then experimented and set the Off level to the maximum of 7 and the brightness went even brighter than it was in 2.7.6. How are the LED levels supposed to work? Also, the contextual menu (right click) in the admin console does not persist unless I hold down the right mouse button. Troy
  6. Keypadlinc v.33 I am not quite sure how the LED brightness levels work. I upgraded from version 2.7.6 where the LED brightness allowed me to set it up to a maximum of 63. That is where I had it set. I just tried to set it using 2.7.14. I set the On level to the maximum of 15 and the brightness on the KPL seemed to be cut in half of what it was previously. I then experimented and set the Off level to the maximum of 7 and the brightness went even brighter than it was in 2.7.6. How are the LED levels supposed to work? Also, the contextual menu (right click) in the admin console does not persist unless I hold down the right mouse button. Troy
