AT&T to end email-to-text ×
jerlands
  • Posts
    1663
About jerlands
  • Birthday 06/12/1956
Profile Information
  • Location
    Houston, TX
  • Occupation
    Merchant Seaman
Recent Profile Visitors
The recent visitors block is disabled and is not being shown to other users.
jerlands's Achievements
Advanced
Advanced (5/6)
83
Reputation
  1. There are many areas of the country which do not observe DST and I suspect eventually it'll go away all together. I believe this could be considered a bug report and I'm sure UDI will address it. Jon...
  2. You might try using java application (admin.jnlp, download from release thread for your firmware version.) The java applet (launches from browser) uses browser resources so to use it you may have to clear the browser cache to use it. Jon...
  3. You'd have to decide that. Alexa affords control of devices, programs and scenes via voice so can you make use of that feature? People use it in a variety of ways but just as HA isn't necessary either is Alexa. Jon...
  4. 49/180= 27% Here's Wiki instructions for setting up the portal and for setting up echo. Jon...
  5. jerlands
    IsY down ?
    What make and model of router do you have? Someone might be able to help in discovery. Jon...
  6. jerlands
    IsY down ?
    It's not possible for two devices to share the same IP. 00:21:B9 <<-- see Wiki Accessing the router's lan table should be your easiest and most reliable method for finding ISY and if it doesn't show there I don't think ISY then is communicating with it. Are you certain the ethernet cable connecting ISY and the router is good? Looking at where the cable connects to ISY and the router do you see green blinking LED lights? I might reseat each connection? Jon...
  7. That seems to be one of the quirky features... you have to tap for reply or they'll compile Jon...
  8. Thanks, Gen5 looks like a marked improvement. Z-Wave's growing like a monster Jon...
  9. I don't believe Gen5 is fully supported yet but seems like a good choice. Re: Gen5 - Is this going to require a firmware upgrade to the dongle? Jon...
  10. Use "Control" for battery operated devices Jon...
  11. jerlands
    IsY down ?
    You do want to download the correct UI version for the 994i however. Jon...
  12. There are various Z-Wave devices that monitor temp. Also an ongoing thread on the 2441ZTH Jon...
  13. jerlands
    IsY down ?
    It looks to me you have 8 devices connected MWareman is in IT so hopefully he'll chime in. Have you power cycled ISY (remove power for 30 sec. then plug in.) afterwards do the arp -a again You could also open a ticket with UDI Jon...
  14. jerlands
    IsY down ?
    From what I can tell ISY isn't seen on your network. You seem to have subnet address' of 224.0.0 (x) while your main network is 192.168.1.(x) I'm trying for understand what the other devices are that are connected to your network. No matter though.. either ISY isn't communicating on the network or it's behind one of the subnets. Jon...
  15. jerlands
    IsY down ?
    What I meant to say is.. How is your network setup? Jon...
  • Create New...
