Backup Procedure
Today I tried to create a backup before things got messed up. I selected Backup and the EISY presented me with a folder list and a Move button. I was happy to use the directory that it presented but I didn’t know how to go the next step. i was expecting an “Execute” button or something similar. What did i miss? I was using Safari, would the screen have been any different with Chrome? just learned that the issue was my browser. Backup successfully created.
Can’t edit schedule
I’ll try but as you say, probably best to get onsite. ok so that plan makes sense. Now why did the programs stop running? Any thoughts? Can I do anything remotely to get them going again?
Can’t edit schedule
Just thinking about your response…. This will give me the login screen. Are you thinking that I’ve already reset the password and I just need to login? any ideas why my programs have stopped working or that my Notification Controller is disconnected?
Can’t edit schedule
Do I have to be local or can I do it remotely?
Can’t edit schedule
Sorry… bounced the ISY is saying that I’ve done a power cycle. Nothing changed. regarding the factory reset, the instructions say to press the button on the front 3 times but nothing seems to change. I’ve tried to press the buttons slow, regular and fast but nothing seems to work. But as I said, in doing this, I’ve disabled my programs.
Can’t edit schedule
So I tried to get into the Admin Console but my Admin password does not work. Then when I tried to press the button on the front to reset the admin password, I get nothing. Is there a trick to resetting that password? Remember, I have an UDI-EISY so the old method does not work. My whole world with this job is threatening to crumble. Looking at the unit remotely, it says that the Notification Controller is Disconnected and none of my programs are running. It is almost as if I have broken the programs somehow. Individual buttons on the keypads work but no programs. anyone have any thoughts?
Can’t edit schedule
I have schedules on my Eisy that I cannot edit. When I try, I get a message saying that I need to synchronize but even after I synchronize, the message is the same. im also not getting consistent results from my programs. Sometimes they work perfectly, other times some of the lights turn on but not all. does anyone have any suggestions? I have bounced the ISY several times but no changes.
Scheduled Program not found
I have 2 Scheduled programs that eisy says are not found. It suggests that I should synchronize but even after that, the programs are still not found. The cursor is empty. can someone tell me how to delete these zombies from the listing? I have tried a long press but nothing seems to work. thank you
Bathroom Fan Delay
Merci Guy Changing to Control vs Status did the trick.
Bathroom Fan Delay
I apologize for the redundance but I inadvertently put this post in the eisy thread which I realized after is really more hardware related. My question is strictly software. I am trying to figure out how to automatically turn off the bathroom fan after a 15 minute delay. So the scenario is that the customer turns on the fan and then leaves the room. 15 minutes later, the fan automatically turns itself off. I tried to create a schedule that says Wait 15 minutes and then switch fan OFF but the only trigger that I can find is based on the current time not on the change of state when the bathroom fan turned on. Does anyone have any ideas ? I have created a program (see attachments) but it does not fire. If I start the fan and then run the THEN clause, it works as I expected. Thank you Brian
Bathroom Fan Delay
Thank you for your suggestion. That is similar to what I was thinking. So I created a program (see attachments) but when I turn on the bathroom fan, the program does not trigger. The fan stays on. Is there something that I have missed?
Bathroom Fan Delay
Hi I am trying to figure out how to automatically turn off the bathroom fan after a 15 minute delay. So the scenario is that the customer turns on the fan and then leaves the room. 15 minutes later, the fan automatically turns itself off. I tried to create a schedule that says Wait 15 minutes and then switch fan OFF but the only trigger that I can find is based on the current time not on the change of state when the bathroom fan turned on. I am perplexed that the Schedule is only time base and does not give me any more flexibility. What am I missing??? Does anyone have any ideas ? I thought about baking it into a scene but the scene will only let me do immediate actions not delayed actions. Thank you Brian
Multiple Scenes
So you are thinking that there is a link buried in the keypad that is confusing me?
Multiple Scenes
Thank you again for everyone who has helped me figure out how to setup this EISY unit. Today, I figured out how to create scenes and things seem to be working as in would expect. The client has multiple Insteon keypads. I have created three scenes that correspond to three buttons (B, C, and D) which turn on three lights in the Dining room. Client is asking that Button E will automatically trigger the three scenes that are attached to Button B, C, and D. So bottom line is that the client wants the flexibility to turn on or turn off a single light by pressing a single button plus they want the ability to trigger all three scenes by pressing Button E. scene B - Button B is the Controller and Light 1 is the responder scene C - Button C is the Controller and Light 2 is the responder scene D - Button D is the Controller and Light 3 is the responder scene E - Button E is the Controller and Button B, C, D are responders what is happening is that Button E turns on the three lights but if I press Button C, Button E also turns on. I also tried to change the scene so that Button E is the Controller but Light 1, 2, and 3 are the responders does anyone have an idea about what I’m doing wrong or a suggestion about how to get the behaviour that the client wants?
Account Recovery
Problem solved. I found some documentation online. Multi Function Button (#top) eisy's power button acts as a multifunction button Update and Upgrade All the Packages Click the button one (1) time. Please consult support before updating this route. Recommended route for updating is through Admin Console -> Configuration Tab -> "Upgrade Packages" button. NOTE: There is not a speaker on the eisy so there will not be any beeps on reboot. Go to WIFI Setup or Leave WIFI Setup mode Click the button two (2) times. Reset Credentials Click the button three (3) times This action resets the following passwords to the default (admin/admin😞 SSH ISY on eisy(IoX) Be sure to change the passwords for these access methods after you log-in again. Reset Networking Click the button four (4) times Reboot Click the button five (5) times Shutdown Click the button six (6) times Factory Reset Click the button ten (10) times Please wait 5-10 minutes after factory reset before attempting to reconnect to system. If System is not found by finder after the wait period please reboot system by clicking the button five (5) times and waiting two minutes for system to come online.
BRMeeke
Joined
Last visited
