PGME2
Everything posted by PGME2
  1. Thank you for moving this to the right forum.
  2. The version is 6.0.3 As far as I can tell the old device is deleted (is there a way to search for the ID number?)
  3. History- I replaced a bad insteon switch that was blinking. The "replace" function in ISY failed to to work properly and I had to manually install the new device and add it to the scenes it was in previous. Issue- When the device was properly added to the scene as a responder, instead of working with the settings in the scene, the device simply goes to 100% every time a scene button is pressed at any of my devices with that scene. However, when the app it used, the device goes to the level set in the scene. What I have tried- -restoring the device -resetting the device entirely using the button on the front and restoring -restoring the PLM -changing the scene settings in various ways to hopefully get it to reprogram Any suggestions on a cause for this behavior or on what to try next to get the device to properly respond to scene button presses?
