nyrhody
Everything posted by nyrhody
  1. nyrhody posted a topic in ISY994
    Hi Guys, Every time I try to link my new 2411R IR linc devise using the "add new inseteon devise" option in my ISY99i, I get the following errors: Failed Writing Highwater Mark [-200000/-1] and Node Not Added - failed removing links [-200000/-9] Is my 2411R bad? Any ideas? BTW I have a pretty large Insteon Network, about 12 light controllers, motion detectors, etc so my network is robust.
  2. IRLinc..it just came yesterday after being backordered for 2 months.
  3. Hi All, I was just wondering if anybody can help me link a SmartHome Dual Band 2477D dimmer to a Harmony One Remote....
  4. Thanks Guys For all your posts! You Guys are the best. I can’t believe I did not discover this forum earlier. You all have been a very big help and it is greatly appreciated. I guess we are all the same on here, because yes, I have all the gadgets at home, 4 computers, home theatre and multiple TV’s and cable boxes. I guess all those devices are starting to have a cumulative effect. I just purchased an in line whole circuit noise filter for a 20 amp line: http://www.smarthome.com/4846/ACT-AF300 ... ter/p.aspx Once I install it I will update you guys. I also purchase a couple plug in noise filters for my desktop(s) and main home theatre circuits. My receiver and power conditioner must be adding considerable noise. Thanks Again!
  5. It was definatly the CFL's when I replaced them with incandescant lights the new dimmer worked perfectly. So now the question is will an in-line circuit noise filter solve the problem?
  6. Thanks Brian, I do not have inline filters on this circuit. The cable and TV are both attached to a monster power conditioner. IF an in line noise filter will solve the problem, can you recommend one?
  7. LeeG, Can you explain your post a little more? Why would the voltage be anything other than 120? Also, if it is how do I fix that? This is a rather larger circuit in which also has a 50†TV and cable box, as well as several other lights on it in addition to my Insteon Controlled Exterior lights and the new Insteon Dimmer that I just installed.
  8. TJF1960, The exterior lights are all compact florescent.
  9. I am having the EXACT same issue. I am set up for 4 separate notifications, they all seem never to work 100% of the time, you are right it is around 85%. Any ideas?
  10. I have had two insteon switchlinc non dimming relays on the same circuit that are scened to control my exterior lights. These worked flawlessly for 6 months. Today I added a new switchlinc dimming switch on the same circuit and the ISY-99 only communicates with the new devise if my exterior lights are off. Very weird. Everything still works, but I continuously get a device communication error with the new switch while my exterior lights are on, as soon as I turn them off the ISY-99 communicates no problem with my new switch. But like I said everything still works, just on/off status never changes on the new dimmer and I keep getting a communication ERROR. Please help!
