AT&T to end email-to-text ×
denpri
  • Posts
    6
Everything posted by denpri
  1. Michel, Happy to try the 2.8 alpha since I'm just getting used to the ISY features, etc. I'll send the E-Mail. -Dennis-
  2. bachguy40, Since you experienced a virtually identical situation using firmware v.2.7.10 and we're now at v.2.7.15, I'm wondering if, per Michel's previous response to me, the "bug" he referenced still exists in the UI. It's also too bad the shell doesn't have an option to display memory stats. In any event, it's a relatively minor "nit" since I don't think I'll ever run low on memory (although you never know what UDI might offer as future enhancements!). -Dennis-
  3. Hi Michel, Performed your steps and everything is still the same (i.e., identical numbers). I even used a different PC with a slightly older Java version just to make sure it isn't OS (Win 7 vs. Win XP) or Java (latest on Win 7 machine vs v.6.17 on XP machine) specific. Any other suggestions? -Dennis-
  4. Michel, FYI - After posting the previous message, I again used telnet and issued both a "FS" and "FR" command. When I then issued a shell "Show Files/Directories" command, the various file folders had already been created AND, after a firmware reinstall, the "Used" amount shown via the GUI "File Status" remained 3MB without ANY configuration restore. Wondering whether it should be "0-Used" and, if Yes, whether the shell FS command is actually working. Also, the card in question is a SanDisk 8GB SDHC Class 4. -Dennis-
  5. Michel, Performed the steps you recommended and still have the same problem (and same result in terms of card capacity). Here's the "File Status" display (All in MB): 3633 - Total 363 - Reserved 3 - Used 0 - Bad 3266 - Free As I previously stated, I DID test/format the card in a PC before installing it and there's nothing wrong with the card. Do you think the UI bug still exists in v.2.7.15? Also, a minor "nit" but whenever I issue the FIRST "File Status" request, the response is "0 MB" for all items but the second (and all subsequent) requests during the same session show "acutal" data. -Dennis-
  6. I just purchased an ISY-99i/IR Pro unit and, before I started programming, configuring, etc. the device, I decided to purchase/install a larger SD Card. Your User Guide (Appendix C) indicates it will support up to an 8GB card. After testing a SanDisk 8GB card on my PC and reformatting (FAT-32), I installed it in the unit. Everything is working fine but, when I open the "File System Status" window, it only shows a "capacity" of approx. 3.5GB (compared to the approx. 7.4GB formatted capacity). Obviously, I doubt I'll ever use even a fraction of 3.5GB for programs, etc. but I was wondering whether (a) I need to do something else to make the full capacity "available", ( there's a bug in the v.2.7.15 firmware or © there's a hardware/software "limitation" (e.g., FAT-only format but this would limit it to 2GB?) on the max. capacity of the SD Card? Thanks for any replies. -Dennis-
  • Create New...
