ISYhbsh01
  1. ISYhbsh01 replied to SHM's topic in YoLink
    What about Thermostat 1, is that currently supported?
  2. There are two speaker hubs which are also offline. Thanks for your help.
  3. One such offline device showing as online is the "NOT Freezer - GE Newest Basem" sensor.
  4. Log sent via private message. Thanks.
  5. Hi, I am having some devices that show as being online and the online state shows as connected, while they are really offline, and show up as such in the app. The last device update in the Admin Console shows a date of more than a year ago. TIA.
  6. PM sent. If it's not currently possible to get the info automatically from the Yolink cloud, perhaps there could be an option to be able to input manually somewhere the remote name and button name for each corresponding digit. This would then show up as a list & sub-list in the Admin console/UDI Mobile app showing the remote name, button name, and the digit. I have no idea if it's possible, I am just throwing the idea out there. TIA.
  7. I indeed did the learning from the app, I am fine with that. For now I setup 5 buttons in the app, for two seperate Mini Split A/C remotes. At the time that I wrote my OP, the only thing that worked was when I pressed “Send code 0”, it sent the first button that I had setup. Entering any other digit did nothing. Now I tried it again, and using codes 0 thru 4 does seem to work. Problem is that I don’t see a way of knowing which digit to use for which button. Would you be able to have the EISY show the name of the button? P.S. After writing the above, I figured out a workaround for now, that by checking the history log in the app right after sending a digit from the EISY, I can figure out which button that digit corresponds to. But that’s obviuosly not the best solution. If possible, it would be best to have the ISY import a list of the names of the remotes, with a sub-list of each of its buttons names, and be able to select it from the ISY to press that button. TIA.
  8. Hi, First of all thank you very much for this plugin, its been incredibly useful. My question is, can you please give some instructions on how to use the plugin with the Smart IR Remote device? TIA
  9. My question is if it can be disabled via an ISY program.
  10. Thanks, this was very helpful. Do you know if you can disable/mute the built-in Alexa speaker on the Smart Thermostat Premium Plus via the ISY/Nodeserver?
  11. I read up a bit the help section on Ecobee's website to become familiar with the way it works and how "comfort settings" work. So my question is, can you select & change from the ISY which comfort setting should be in effect now? Thanks
  12. Thanks to everyone trying to help. I am including here a link to the Ecobee Nodeserver thread, where I posted the same question about the Ecobee thermostat, so we can keep the discussion in one place. Thanks. https://forum.universal-devices.com/topic/42308-ecobee-remote-sensor-capabilities/?do=findComment&comment=374547
  13. Thanks to everyone trying to help. So let me clarify what I am trying to accomplish. My wife and I are hot people, and we like our bedroom colder than the average person. We have a wall unit A/C in our bedroom in addition to the central A/C. Sometimes in the fall & spring weather, we might sometimes still use our wall unit A/C, or later in the winter open the window, when others might have put on the heat already. Our thermostat is located in the master bedroom. So what I want to do is to put a remote sensor in one of the other bedrooms, and then be able to use a program to tell the thermostat that if the wall A/C in the master bedroom is on (using an Insteon On/off module), or if the window is open (monitored via a contact sensor) then use the sensor in the other room. Otherwise, use the thermostat’s own sensor. In the past I have had many times that the A/C was causing the heat to go on, thus causing the A/C to work even longer, and then they were fighting each other while the rest of the bedrooms were boiling away. Thanks again.
