mdfled
Everything posted by mdfled
  1. Having been in the door hardware business, I would expect your experience differences between the Yale and the Kwikset locks. Yale is a quality product that is used in large institutions and commercial applications. On the other hand, Kwikset is viewed to be a residential grade lock, something below the quality of a Schlage, Yale, Best lockset and generally not acceptable for the commercial environment. The price you pay is commensurate with the performance you get. When it comes to radio waves instead of wires there are all sorts of things that can impact the performance of a device's communications. Yes better engineering of things like antennas or materials made to make the radio will make a difference and obviously if the manufacturer isn't implementing their system using industry standards you can have issues. In the OPs case it sounds like there is an RF issue as the model of locks they have, based on other user's experiences, seem to be reliable. One of the most difficult things about wireless based devices are the tools to monitor for interference or other errors with the signals can be quite expensive and require some knowledge to understand what you are looking at/for. There are a lot of considerations when it comes to intermittent unreliable signals and troubleshooting. First thing to do is to eliminate all RF producing devices and gradually add them back into the environment (I know not necessarily practical) to see if one of them is causing interference. Most electronic devices give off RF and if they happen to be out of spec or just plain, poorly made they can emit wide spectrum RF noise, which means turning off most everything in the house! For example I have a couple of small portable induction hot plates that when plugged in block my insteon signals. Second, as I suggested, make sure your network (in this case a mesh network) of antennas are robust enough and within the distance of the designed spec of the emitter for proper signal strength. Things like walls, cars, furniture can all block signal so the maximum distances between devices may need to be reduced; this is where adding lots of repeating devices to the network will help with strong signal performance from end to end. Also, as stated earlier you could have a failing repeater that is causing harm rather than helping, so again, eliminating devices and adding them back in will help you find your problem. Looking at error logs can also be helpful in understanding where you are having failures. The above is why whenever possible I use wired connections. Not only is a hardwired device more reliable it also doesn't add to the spectrum of signals in your home/environment.
  2. Hi Gweempose, I've been using the SchlageBE469ZP deadbolts without any hiccups. Part of the reason I selected this deadbolt is it matches the other locksets I have in the house. I'd have preferred a lock that would do reporting on who entered based on code entered and other statics that you get with the higher grade locks, but these work well enough. I've not had any problems with remote locking/unlocking or reporting. I'm using an eisy to control the lock through the Z-wave dongle. Since you've changed your configuration/location and you are having issues, I'm wondering if your Z-wave network is robust enough (has enough devices to be reliable)? You might try adding some Z-wave plug in devices that can help repeat the signal since the plug in devices are relatively cheap for testing? When I started using Z-wave I added several Third Reality plug in switches around the house to act as repeaters. You might have some interference or structure that is blocking some of the signal so try boosting the signal before you give up on the locks.
  3. mdfled posted a topic in IoX Support
    I was trying to add a 2447D Switchlinc to a scene that is already part of another scene and getting a message do I want to make it a Responder to the scene I'm trying to add it to. The Switchlinc is linked (via eisy/ISY) to two other Switchlincs. So, I'm trying to add "Stair Master Switch" to "Daily Lights" and it is already part of "Stair Lights" scene and is the controller for the Stair Lights scene. When I try to add it to Daily Lights I get the message Stair Master Lights is already a controller for Stair Lights, Would you like to make it a Responder? If I say yes the next popup asks me if I want to make it a Controller or a Responder for the scene Daily Lights. I'm curious as to the consequences if I make it a responder in the first popup and then make the controller or responder selection in the second popup? I'm asking because I've been having the dreaded All-On mystical different lights turning on and I'm trying to rewrite some of my programs to see if I'm getting the errors because of Scenes sending multiple commands to the same device at the same time as outlined in the manuals/wiki. I thought it was better to use scenes to control multiple switches but it seems I don't fully understand what the consequences are and when to use a scene versus when to use manual linking, or to use discrete device commands in my programs. IIRC a long time ago I was told not to do manual linking but to let ISY/eisy control things like linking. In this case, the linking was done within eisy between the stair master switchlinc and the other two associated switchlincs but, at least for me, it is confusing when the UI asks about responder vs controller. Is there a wiki link or something in the manual that better describes when to use which and has examples?
  4. mdfled replied to mdfled's topic in eisy
    Thanks all, I'll trust that the case is dissipating enough heat. I haven't had any problems to this point, but knowing the chassis is the heatsink, I might have a fan blow on it to help keep it cool since fans are cheap insurance.
  5. mdfled replied to mdfled's topic in eisy
    Thanks all, I had my eisy mounted on the wall with the brackets that came with it, but felt things were too hot so like I said, I have it propped up so it gets more air around it, but it is still hot. Compared to both Raspberry Pi's I run for my 3D printers, HA installation, and other small SBCs the eisy seems to run hot. I've got some large aluminum heat sinks that I think I'll try first and see if that cools things some. I've never been a fan (pun not intended) of the combination of heat and electronics; the TV above the fireplace design has always made me cringe whenever I see it.
  6. Has anyone added a fan or heatsink to their Eisy to reduce the temperature of the device. When my eisy has been running I can barely touch the case because it is so hot. I used to have it hang on the wall, but I've moved it and propped up one end of the case to get more airflow around the device. I can't imagine that the heat isn't shortening the life of the device. My ISY never ran this hot, are others finding their eisy extremely hot?
  7. GS are you getting an API error for each of the node servers that won't connect or show the nodes in the Admin Console? I just had a problem with the YoLink Node Server, and I was getting an error about the API. I had to delete and recreate the node server to get the nodes to show up in the Admin Console. So, check your error logs when a node starts and post the errors you get when the node doesn't start, and then someone should be able to tell you if you need to recreate the node server.
  8. Thanks gzahar, after trying other things, I did delete and recreate the NS plugin and it fixed most of the problem. I still had to go in and correct some of my IF statements related to the YoLink devices, but the deletion and recreation solved most of the issue. Thanks again!
  9. Thanks for the reply. I found an error that the API was broken (I'm paraphrasing) and searched the forums. I found one of your posts about a new API that was breaking Node Servers. You suggested if the error occurred the user should delete and recreate the NS. I did what you suggested in the other post and the NS started working and all the YoLink devices showed up in AC. I still had to fix some programs as I think they were broken with the broken NS, but the repair was fairly simple, I just had to make a couple of changes to the If line of my program. Thought I'd update you, in case you get other messages that a NS failed after the latest update.
  10. I opened a ticket on this error as my YoLink devices aren't working any longer after I did the latest updates. I've checked all the logs, and the error you posed above is the error I'm seeing in the YoLink node log when I restart the node server. Can you please tell me how to fix this?
  11. I"m having issues with the YoLink node server after the last update. AC will show the YoLinkSetup node as connected, and then drops the "Connected" status indicator after the node server is up and running for a few minutes. I've tried rebooting several times (both NS and eisy) with nothing changing after the reboots. Even though I didn't change anything, I've verified my user credentials in the NS and they are correct. I can see the Notification Controller NS and it is working, connected and functioning, it is only the YoLink NS that seems to be having trouble starting up. Running the error logging and restarting the NS I get the following error: yoLink_init_V3:__init__: Exception - init- MQTT: Unsupported callback API version: version 2.0 added a callback_api_version, see docs/migrations.rst for details The NS screen in the PG shows "connected" after the error posted to the log, so I'm guessing the error isn't the problem? I can upload error logs or logs if it will help. Any help would be appreciated!
  12. EJones, I have a couple of Tuya Human Presence Sensors (HPS) working through Home Assistant (HA). HA is able to trigger a program on my eisy when it receives a notification from Tuya's API. My HA installation runs on my local network, and it runs on a Raspberry PI. You have to use Tuya's SmartLife app so you will need a Tuya Zigbee hub to communicate with Tuya. You will also have to set up a Tuya account and go onto their website to configure your devices and to key in your authentication credentials. Tuya then sends info to HA through the API. There is pretty good documentation on HA's website that will walk you through most of the Tuya setup. Once you have HA recognizing your devices, you can set up an Action in HA triggered by the HPS sensor to run a program in eisy. Right now, I have my programs set up to increment or decrement a variable in eisy that I then use to turn on and to keep on the lights until I leave the room. Now for the bad news. I haven't had the sensors hooked up for more than a week, but so far my impression is, the marketing hype about being able to sense your breathing is a joke. I still find that if I don't move around some the lights start shutting off. I'm not perfectly still, ever, in the room in question, so I'm sure they aren't picking up my breathing when they aren't even sensing small movements. I'm going to add a couple more sensors for overlap and play with layout of the sensors to see if I can get them to perform better. I should also say, I didn't spend a lot on these sensors, maybe $20 per sensor, so there may be better quality sensors that can do the job better than what I've purchased.
  13. Any Zigbee human presence sensor, preferably Tuya device as there a lots of them available! I've got a HAOZEE Sensor from Ali Express https://www.aliexpress.us/item/3256805765649725.html?spm=a2g0o.order_list.order_list_main.23.19fd1802hrsD37&gatewayAdapt=glo2usa Loginovo sensor https://www.aliexpress.us/item/3256805291297545.html?pdp_npi=4%40pre!!US %2428.74!US %2413.22!US %2413.22!!207.96!102.02!%40210313e916994709671554017e092d!12000033255721585!sh!US!4313580587!&spm=a2g0o.store_pc_aeChoiceSimplified.allitems_choice_2005294756320.0&gatewayAdapt=glo2usa Wenzhi sensor https://www.aliexpress.us/item/3256804518651916.html?spm=a2g0o.order_list.order_list_main.11.19fd1802hrsD37&gatewayAdapt=glo2usa I think a lot of these you can find on Amazon as well. These are available in both wireless and Zigbee. I'd be ok with another brand as long as it is Zigbee and a human presence sensor. I'd like for the Zmatter dongle act as the hub so I can eliminate the cloud connection and another hub running in my house!
  14. If Michel is right and you are having DNS issues, it could be your ISP's DNS server. A long time ago I learned that most ISPs do a pitiful job at name resolution servers. I switched to Open DNS's DNS servers and a lot of sluggish and non-responsive queries went away. You could also try one of the evil empire's (Google's) DNS servers as well. 208.67.222.222 and 208.67.220.220 are the DNS servers for Open DNS. Open DNS has guides on their web site if you are unfamiliar with how to configure your router for using an external DNS server. I hope this helps!
  15. I can get a Aqara motion sensor detected by IoX but all IoX gives me in the Admin Console is "Unavailable". My eisy is running eisy (5226) with IoX running 5.6.4. When I try and run (from the Admin Console) "Identify" nothing happens, and when I try and Query, I get an error message. The log shows an error for the ZB 8385.1 entry which I'm guessing is when I did the initial Interview with the device, but no greater detail. This is a MS-S02 model (from the label on the bottom of the sensor). The box it came in states that a Aqara hub is needed. I'll probably send these back to Amazon if a hub is required which is a bummer as I like the ~ 2 year battery life and the size of them is very small. I was hoping to use these under my soffits outdoors so the 2 year battery is a real plus since I need a ladder to change batteries. Some of the other suggested MSs don't offer the same battery life or the small size.
  16. Kevin, I have a personal weather station running Weewx on a raspberry pi. The program is uploading my weather data to WeatherUnderground. I was wondering if you've played with Weewx at all? Have you spent any time looking to see if you could receive the data from Weewx instead of using one of the commercial weather data streams. There is a program within Weewx using a SDR receiver to pick up the transmitted data stream from a weather station so you may be able to pick up a neighbor's data stream if you don't have your own weatherstation. It would address some of the issues as to how often you can get updates from the weather services. https://github.com/matthewwall/weewx-sdr https://github.com/weewx/weewx
  17. Thanks Kevin, I've been working on getting my weather station interface, ntp server, and a couple of other items I want for the consoles, so I haven't had the chance to do much configuration of the SoftConsole yet. I'll update my SoftConsole and install it on another machine probably later this week. I'll let you know if I find any issues.
  18. Thanks again Kevin, I got the console up finally. I built another pi and it seemed to have trouble logging into the ISY, so I went back to the original SD card and edited the .Screentype file. I also put back in the original Config.txt file since you were seeing something corrupt (I'm in the habit of saving files with a new name if I make a change so that I can always revert to the original version). Everything is up and working, now I need to configure things. I'll do a little more testing to see if I have to have files in the two folders I created on the ISY. I also need to figure out why the other build wouldn't connect. I could see in the ISY error file that there was an authentication error. The console log file wasn't even getting as far as the folder error I originally started out with, I suspect something is funny with the build. I checked the Auth file and it looks like my credentials are correct. I might send you my log files if I can't figure it out. I'm assuming that I can have multiple softconsoles log into the ISY, but I guessed I needed to use a different device name so I called my second build SoftConsole2. I'm assuming each one should have a unique name.... This has inspired me; One project I was working on was the raspberry pi garage door controller. I lost interest since as it is configured, messages would be pushed to my smartphone. I don't normally carry my smartphone around the house; and at night I don't bring it into the bedroom; with SoftConsole I should be able to glance at the screen and make sure the garage doors are down and all our exterior doors are closed. I think the SoftConsole opens up more functionality, thanks for all your work on this.
  19. Kevin, We've made some progress, the cursor now changes about 30 seconds into the blank screen; since making sure I have both types of variables defined. I made sure there are at least 2 variables of each type; just in case the system wants more than one variable much like it's need for more than one folder. Attached are the last couple of log files. I think the current console log file is the last reboot which has the ISY back to no files; which I do so I can easily get back to the desktop to transfer the log files, so the console.log file may be irrelevant. Console.log.3 Console.log Console.log.1 Console.log.2
  20. Thanks Kevin, I'll take a look at this tomorrow. I can't recall what variables I have defined on my ISY. I'll recreate the folders in ISY and make sure I have both types of variables defined. This reminds me of systems I used to work with; every customer wanted their own custom solution; which meant every time there was an upgrade; at least 1/2 the systems would crash because of all the different "customizations" which couldn't be tested.
  21. Ok I added a second folder. Now the raspberry pi goes through a cycle where I have just a cursor in the upper left, and there is no response from the mouse, keyboard, or the touchscreen. The program seems to get caught by a watchdog timer as the desktop will reappear if I leave it sitting. After a minute or two the console will try and start again and the screen goes back to no response with just the cursor in the upper left corner. I've added devices to both folders and I'm still getting the same cycle on the ras pi. I've also moved all my devices to the two folders and I still am getting the cycle. So console.log.1 is with no devices in the two folders, console.log.2 is with all the devices in two folders (SoftConsole1, and SoftConsole2). I also included 3, 4, and 5 which should be logs of the pi cycling through the process. Just out of curiosity (and to make it easy to break out of the loop) I removed the folders in ISY and the pi went back to the original error looking for a folder that didn't exist in ISY, and the pi did the short run and threw the original error. Console.log.1 Console.log.2 Console.log.3 Console.log.4 Console.log.5
  22. Thanks Kevin, Here is the struct.dmp file and the xml.dmp file. Interesting I had to reboot the pi a couple of times to get it to come all the way up this time. Looking at the struct.dmp file, I'm guessing, I have some devices that are structured oddly in the ISY??? struct.dmp xml.dmp
  23. Thanks Kevin, So I added a folder in ISY called SoftConsole and tried to run SoftConsole and it failed. I also tried to move a couple of devices into the folder as I was seeing an error that the values weren't integer values (progress?). It still failed. Attached is the console.log for your reference. I really appreciate all the work that you have done and this looks very promising, the little bit of work I've had to do is nothing compared to what you've done, so no need to apologize. I'm looking forward to the added functionality your project will add to my Insteon network! Console.log
  24. Kevin,I am really interested in getting SoftConsole working, I think this is some fantastic work. I have everything loaded and ran into an error seen in the console.log file snip below. I loaded the mini-test version of the install. Here is the error. 01-08-21 14:50:06 Sev: 3 SysParam: DimIdleListNames: ['MyClock'] 01-08-21 14:50:06 Sev: 3 SysParam: DimIdleListTimes: ['20'] 01-08-21 14:50:06 Sev: 3 SysParam: ErrLogReconnects: True 01-08-21 14:50:06 Sev: 3 Create ISY hub version 0 as My Lighting 01-08-21 14:50:06 Sev: 3 My Lighting: Create Structure for ISY hub at http://192.168.1.10 for user Mark 01-08-21 14:50:25 Sev: 3 My Lighting: Successful node read: 200 01-08-21 14:50:25 Sev: 5 Fatal console error - fix config file: 'folder' 01-08-21 14:50:25 Sev: 3 Traceback (most recent call last): 01-08-21 14:50:25 Sev: 3 File "console.py", line 455, in <module> 01-08-21 14:50:25 Sev: 3 hubs.hubs.Hubs[i] = pkg(i, v.get('address', ''), v.get('user', ''), v.get('password', ''), hubvers) 01-08-21 14:50:25 Sev: 3 File "/home/pi/consolestable/hubs/isy/isy.py", line 312, in __init__ 01-08-21 14:50:26 Sev: 3 for folder in configdict['folder']: 01-08-21 14:50:26 Sev: 3 KeyError: 'folder' 01-08-21 14:50:26 Sev: 3 Console was up: 00mn 24sec 01-08-21 14:50:26 Sev: 3 Console Exiting - Ecode: 13 01-08-21 14:50:26 Sev: 3 Immediate Exit: 13 01-08-21 14:50:32 Sev: 3 End Log I'm guessing the software didn't find the correct folder to read for the password for the ISY???? I checked the Auth.cfg file and it has the password to the ISY correctly listed along with the correct IP address and everything else looks correct. Any idea of where the problem is? One thing I'd like to change is my ISY is listed on the network as ISY99 and not my lighting, but I have left things for now as I'd like to get things working before I start making changes. I am starting with the 7" display and an ADA fruit case but I have a couple of 3.5" screens in the wings waiting to get the bugs worked out.
