mfolan
Everything posted by mfolan
  1. Thanks Michel! I appreciate your follow up. - Mike
  2. Thanks for your reply Michel. I had been using http:///admin. I cleared my java cache, and switched to the URL you suggested, but the results were the same. No morningLincs in the drop down list for a status condition. In retrospect my use case probably isn't very sound, since the deadbolt does not have two way communication. But, I would like to know if it is possible. Thanks, Mike
  3. I would like to use the status of my morninglinc devices (locked/unlocked) in programs. However, when creating an if statement, I select 'status', my morninglincs are not listed in the device drop down list. Is it possible to execute a program based on the status of a morninglinc? Has anyone done this? (I am using firmware 3.1.5) In case anyone is curious, I love the MorningLincs, but the beeps they make keep freaking out my dogs. I want to send the lock command only when the door is unlocked so that the pups can relax Thanks in advance. Mike
  4. Final update from me.... I disabled the firewall, but the issue remained. I then uninstalled Java (6 update 17) and re-installed it with the latest version (6 Update 25). Everything is working as it should now. Mot sure if it was the re-install or the newer version, but I am happy that the issue is resolved. Thanks, Mike
  5. Hi Michel. I've tried two other machines now, and everything works just fine on those machines. So this does appear to be a problem with the environment of the machine I was using. I feel silly for not trying on other machines first, but the issue was so isolated and specific that it not occur to me that it could be an environmental issue. Thanks for taking the time to help me identify the issue. Now to figure out what is wrong with my main PC! - Mike
  6. Hi Michel, No problem. If you have anything you want me to try, or if there is any additional information that would be helpful, just let me know. Just a little more info: This is only happening with removing KeypadLinc buttons from scenes and only when they are the controller in the scene. I also confirmed that it is an issue with all three KeypadLincs I have installed, so I do not believe it is device specific. Since you have not been able to reproduce yet, I'm a bit concerned that there might be something flaky with my system. But besides the thermostat adapter issues, this is the only problem I have had (and it is not a major issue). To answer your question, besides the base Windows7 firewall, there are no 3rd party Firewalls installed. Thanks, Mike
  7. Hi Michel, I am left with green 0101 icons. I can temporarily allow you access to my system if it would be helpful. - Mike
  8. I didn't see this reported elsewhere, so I wanted to report it. This issue is fully reproducible in firmware 3.1.2 (at least on my ISY-99) 1. Create a scene 2. Add a switchlinc device as a responder to the scene 3. Add a KeypadLinc button as a controller to the scene (i.e. button A on a 6 button KPL) 4. right click on the KPL button in the scene and select the 'remove from scene' At this point you will the ISY start writing the links, but it will stop and display the 0101 next to all devices it is writing to. The admin console will not refresh from this point forward. The operation does complete successfully, and restarting the admin console will get things displaying fine again. Hope this helps, Mike
