bconen
Everything posted by bconen
  1. I just installed the Floodlight Cam Pro 4K. The plugin creates a node for motion and light control. The light control has buttons for on and off. The motion works and reports to the eisy but I cannot control the floodlight from the eisy.
  2. Iox 5.8.4 PGx 3.2.27 I deleted the audio player. Rebooted eisy and reinstalled. Still get the same error. Still shows missing module pyaudio.
  3. Here is the log file. AudioPlayer_8-5-2024_70056_PM.zip
  4. I have been using the professional version of the plugin for several months. At times it will show "playing" in UD Mobile and not work. I reboot the EISY and it works again. I downloaded the newest version and now it will not connect. I have rebooted the EISY. I have deleted the plugin and reinstalled. I reinstalled in a new slot. It just always shows "not connected" in the PG3 dashboard. No matter what I do it will not connect.
  5. Since the eisy can now control the Philips Hue light bulbs via zigbee, I am wanting to purchase two but had a couple of questions. 1. Since I will have two BR30 bulbs in the same room, can they be grouped together so that when one is adjusted they both adjust together? 2. Can the Philips bridge still be used with the eisy or does the eisy replace it? 3. If controlling the bulbs from a program in the eisy, what parameters can be adjusted in the program (i.e. on/off, brightness, color, etc.)?
  6. I installed version 1.3.0 this weekend. The first version I installed. I am having two issues same as previously posted. The preloaded mp3 files will play but my custom messages will not. I did the following as previously recommended: sudo chown -r admin:pg3ns /storage/sounds I get an error: -r is an illegal operation. I did sudo chmod -R 770 storage/sounds I get an error of "no such file or directory" Also, the sounds that do play always play at 100%. If you change to anything else, it always reverts back to 100%.
  7. bconen posted a topic in ISY994
    I have a 6 button KPL that has been working for several years. Just recently when I push the main "off" button the light on Button A goes off. Buttons A and B are set to non-toggle on and buttons C and D are set to non-toggle off. If I press button A again, the light comes on. The main button and button A are not connected in any scenes. Any ideas?
  8. I replaced my PLM and the I/O Linc added correctly. My old PLM was version 1.0. New PLM is version 1B.
  9. I will get a new PLM and try that. Thanks
  10. The device is not added. I have tried doing a factory reset. When I try linking using the set button, the linking screen closes. When I link by putting in the address it tells me it can not determine the insteon engine. Each time my PLM locks up and I must cycle power on it.
  11. Sat 11/23/2013 02:03:54 PM : [VAR 2 17 ] 1 Sat 11/23/2013 02:03:55 PM : [25 2c 11 ] Added to list of devices to link to ISY Sat 11/23/2013 02:03:55 PM : [iNST-TX-I1 ] 02 62 25 2C 11 0F 0D 00 Sat 11/23/2013 02:03:55 PM : [iNST-ACK ] 02 62 25.2C.11 0F 0D 00 06 (00) Sat 11/23/2013 02:03:55 PM : [iNST-SRX ] 02 50 25.2C.11 14.83.8B AB 0D FF (FF) Sat 11/23/2013 02:03:55 PM : [std-Direct Nack] 25.2C.11-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 11/23/2013 02:03:55 PM : [iNST-TX-I2CS] 02 62 25 2C 11 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Sat 11/23/2013 02:03:55 PM : [iNST-ACK ] 02 62 25.2C.11 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01) Sat 11/23/2013 02:03:56 PM : [iNST-SRX ] 02 50 25.2C.11 14.83.8B 2B 09 01 LNK-ON (01) Sat 11/23/2013 02:03:56 PM : [std-Direct Ack] 25.2C.11-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 11/23/2013 02:03:56 PM : [LNK-BGN ] 02 64 01 00 00 Sat 11/23/2013 02:03:56 PM : [25 2C 11 0 ] Failed to add device, reason 3 Sat 11/23/2013 02:03:56 PM : [All ] Writing 0 bytes to devices
  12. ISY994 Firmware 4.0.5
  13. I just bought an I/O Linc 2450. Whenever I try to add it, I also get "Can not determine Insteon Engine". Did you ever get yours to work?
  14. I upgraded to 3.3.2 and I am having the same issue as Teken when I access via HTTPS. I am running Windows XP and IE8. I have cleared the Java cache and created a new certificate. I still get the same error. I turned off Norton Firewall and it made no difference. I reinstalled 3.2.6 and I can now access via HTTPS. Any ideas?
  15. I did not receive an e-mail either. I called Smarthome and talked to a customer service rep. He said he would pass the information on to the person in charge of the swap out. Two days later I received an e-mail that they had shipped.
