divineliving
Everything posted by divineliving
  1. Thank you... I actually made these changes.. Pool Off: If From 1:15:00PM To 5:55:00AM (same day) Then Set 'Pool Pump' Off Else Run Program 'Pool Pump Timer' (If) Pool Pump Timer If From 6:00:00AM To 1:00:00PM (same day) And Program 'Pool off' is False Then Set 'Pool Pump' On Wait 7 hours Set 'Pool Pump' Off Else Run Program 'Pool off' (If) Pool Fast On ( using the trigger fast on to kick the pool back to timer) If Control 'Pool Pump' is switched Fast On Then Run Program 'Pool off' (If) Else - No Actions - (To add one, press 'Action') Is that correct? I will turn the pump off via the flotation scene that turns off the pool and the refrigerator at the same time. I never know how long I will be floating - it could be 45 min or 3 hours... and I don't want to limit my stay in the tank based on a timer... But I would like to turn the pool back on via my Iphone /flotation scene and have the pool timer go back to its scheduled on/off There is a green arrow on the Pool Fast on... what is that? I also created a program to turn on the 'flotation pump' after I float and maybe use that to trigger the pool pump on (and right back off if not on its scheduled time) as well as the refrigerator.. I tried a simple test of a 'timer' with a 'fast on' and it did not work... what did I do wrong? Here it is: Flotation 7 min timer ( I made the then a 1 minute for testing purposes only .. it did not turn off) If Control 'Timer - Floation Room' is switched Fast On Then Wait 1 minute Set 'Timer - Floation Room' Off Else - No Actions - (To add one, press 'Action') Thanks Alberto
  2. I have a pool pump that I have on a timer... If Time 6:00AM Then Set 'Pool pump' on Wait 7 hours Set 'Pool pump' off That I think is fine although questioning if the 'from/to may make more sense... based on the scenario bellow. Scenario: During those 7 hours, I may want to to turn off the pool pump because I don't want any noise... I have an 'isolation/flotation' tank where i turn off the refrigerator, pool pump and everything else for quietness sake... ( the reason I got into this ISY-99i by the way... So, when I get into the tank I can manually turn off the pump, but after I am done 'floating' I want to turn on the pool pump again and turn off automatically within the 7 hours originally programmed... how can I do this? The other option is to have the from to... but then again, if I manually turn it off, and then after the float turn it back on... will it turn off at the predetermed time set above? Thanks![/code]
