firstone
  1. firstone replied to Pop12's topic in HolidaysGoogle
    Yes, my authentication key only worked for 100 people. After that you need a complicated "review" process where you have to make a video, etc. The only way is to create your own api key which you can enter as a parameter.
  2. Put node server into debug mode, generate log package and PM to me. I'd like to see both, you changing source using remote, as well as trying to change it via AC. Please, write down the time for both. "Connect on demand" is a workaround where some models do not function with permanently opened telnet connection. So it's opened at the time node server reads or writes.
  3. I can comment on Alexa network connection. Perhaps you can try to work it out with Amazon support. But as far as interface - why do you even need to use it? I set up all voice commands via ISY portal. I don't think I ever needed to touch Alexa interface or app for that. Just set up devices and scenes. I can turn on (hue) bedroom lights (that will auto shut off in 30 min). I can open z-wave blinds. I can turn on some selected Insteon switches. Alexa doesn't like certain words but other than that, it mostly works fine for me. Home assistant does have "voice preview edition". People have various success with it, from what I've read. But I do believe it's local only and doesn't need cloud. So definitely a plus there. I, personally, use Alexas as speaker so that doesn't really work for me. But if Amazon further messes it up down the line, will definitely look into it.
  4. Same here. Did not upgrade Hue plug-in so definitely v6 related. Good thing is everything should work fine after few hours of recreating linking. 🤦‍♂️
  5. firstone posted a topic in eisy-ui
    I'm pretty new to this UI but have noticed that all "Nodes" are flat. While in AC I have everything organized in folders. For instance, First Floor -> Living Room -> Blind, Second Floor -> Master Bedroom -> Blind. So now in nodes I have have like 5 "Blind"s and don't know which one is which. How do I migrate this?
  6. firstone replied to xKing's topic in Hue
    This is awesome and hopefully you can work out all issues. I, personally, couldn't get V2 working reliably. I use Hyperion and every time I switch from V1 to V2, always stops working after a while - getting some "ssl timeouts". Developer blamed on "network latency being more strict in ssl" but my hub is hard wired and on the same switch. I don't think there could be any less latency. Could be I have one of the earliest 2nd gen hubs but the firmware is the latest.
  7. If you're capable of running ssh commands, PM me and we can try to figure out what have gone away. I can also probably tell you how to get it back temporarily.
  8. I haven’t upgraded to 6 yet. I will do it and will work with UDI to resolve this.
  9. I've fixed it. Prod was pointing to dev branch. The only changes are addition of new gen onkyo support. Those do volume in half db increments. There aren't any other changes.
  10. Antennas come with module. You don't have to buy them. You can try without them as well and see if they work. Old ISY had horrible range for zwave. But it if worked fine for you, possibly you don't need antannas. Also I think you can get any other USB z-wave adapter, like Zoos stick. Those don't have external antenna.
  11. I don't think z-wave will work without antenna. But you can use USB extension cable to physically move adapter away from eISY if it makes your life easier.
  12. firstone replied to firstone's topic in eisy-ui
    Upgraded and restarted. Still same error:
  13. Try setting "Host Name" to TV's IP. When properly connected, TV will prompt you to accept incoming connection. Also, note that only works with older generation of LG. Newer one had changed protocol and I don't have new model to get it working.
  14. firstone replied to firstone's topic in eisy-ui
    It show as running: eisyui is running as pid 6276. I've tried restart. Luckily fixed Portal connection but UI itself still shows same error. It was working when I've originally installed it.
  15. firstone posted a topic in eisy-ui
    I've noticed my Alexa stopped working and when I've check portal - it's disconnected. UI itself says "Error: Network Error". I could live with UI issues but losing Alexa functionality is very annoying. Tried restarting isy service but that did not fix it. Everything else seems to be working fine - AC, Polyglot. Anything I should try and/or check before I reboot eisy?
