Shawn Aruch
  1. Create a (or a number of) programs. Lock (with if then's being lock/unlock) or Lock 1 Lock, Lock 1 Unlock (with the then action being lock and unlock respectively). You can then call it with Amazon turn on Lock (for lock) Turn off lock (for unlock) or Turn on Lock 1 lock (etc).
  2. This is great news. Can't wait to try this when I get home. Thanks!
  3. Is there a GET url that I can use with the portal to activate or deactivate devices or scenes remotely?
  4. Is there a portal url scheme to turn on or off a device with a get? Sent from my iPhone using Tapatalk
  5. It isn't a separate fan, but rather the blower on the central air / heat unit. This is what I came up with and seems to work ok. If Control '14.21.07 - Heat Control' is switched Off Or Control '14.21.07 - Cool Control' is switched Off Then Wait 1 minute Set '14.21.07 - Main' Fan On Send Notification to 'Default' content 'Fan On' Wait 15 minutes Set '14.21.07 - Main' Fan Auto Send Notification to 'Default' content 'Fan Off' Else - No Actions - (To add one, press 'Action') Looks to be working ok for now. Thanks, Shawn
  6. Hi, I have a Venstar thermostat with the Insteon module and a 99i. What I'd like to do is have a program that when the heat / cool of the thermostat goes off (temp has been reached) the fan then comes back on for 15 minutes to help even the temperature around my house. This will be my first program with the 99i, so I'm not sure where to start. Thanks in advance, Shawn
