OmegaQuest
  1. Yep. See this all the time. Not sure why, but been seeing it for quite a few versions. Personally, I chalk it up to Java. I hate it, I really do... Ive been having this issue for a few versions as well. That and the status of anything dosent report anything (status is blank) until I log off and back on a couple times.
  2. Same thing. Once I get into the admin section about 10-20 seconds later it asks me for my username/password for the second time while in the admin section
  3. No firewall on computer and ISY IP is still the same (Static). Thanks
  4. Ever since I upgraded from 3.1.17 to 3.2.6 (Lastnight) I get this strange authentication problem. When I login to the Admin GUI, everything appears fine, the Current states show up fine and then about 20 seconds later, another prompt appears asking me to login with my username/password again even though I am in. If I click cancel, I get logged off the Admin gui. If I click my username/password and click OK, I do not get the prompt again untill next time I reopen the Admin gui...
  5. ok, so put a 1N4002 on the end of the input positive wire and hook the other end of the 1N4002 to the doorbell transformer correct?
  6. That worked Great! I had an old Stereo female jack so I just cut that and wired it to the IOLinc terminals (red to S, white to +5, copper to Ground)! Thanks!
  7. Interesting. Maybe I should try the same (swap the wires) because sending it back takes so much time to ever get a refund and the only other alternative is a $46 Elk ELK-930 detector...
  8. But the Probe never changes the Sensor on the IOLinc to turn to the On state (even for a split second), so the ISY would never know it.
  9. Arrrrrg, thanks for testing. Guess I will have to return my probe for the second time....
  10. @Hoopty I got this to work for my "2" Thermostat setup without a problem.
  11. The manual at: http://www.smarthome.com/manuals/8015_web.pdf is the same manual that came with my Probe.
  12. If I change from 5 seconds to the following: Wait 3 seconds Repeat Every 6 seconds $Cool_Cycle_Time_Daily_6Sec += 1 Would I need to change the other values such as /= 12, /= 720 and the *=60 referances in the program?
  13. I just think its strange that they sell this probe with the IOLinc and say it is for 3-24volt (AC or DC right on the probe itself) yet the sensor or relay never get triggered.
  14. I did try that when I tested the 18v and the 1.5v DC Batterys. Still the same problem.
