ssingh1234
  1. Hi all. I am having some issues with this. Should I be installing the Homebridge ISY plugin or the Homebridge ISY Js plugin? Thank you!
  2. I would love for this to be possible to integrate the ISY with RedEye.
  3. Hi there, I was wondering how it's possible to get through either Mobilinc or another app a way to control my alarm system. I have got everything working through DSCLink and can send commands through my ISY99 to the Alarm system. Also, I have no idea how to create state variables to use the alarm features through the ISY but ideally if there is a way to link a keypad type app through the ipad or iphone that would be amazing. Is there such a beast? Thank you all for your help!
  4. Hi there, I have setup based on the instructions provided however I am getting a TCP client request failed [Net Module Rule 1:404] SSL Request not authenticated. Not sure what's happening. I have configured the authentication variable in the header section. Any chance you may know the issue? I have an IT100 connected to a LAVA link serial. I can see the SS is talking to the IT100. Thank you kindly!
  5. Would you have a tutorial on how you got the ISY-99I synced with iRule? Trying to do the same thing. Is it a network or http gateway that I need to create? Thank you!
  6. I didn't do anything today and just happened to try and re-link the morninglinc this morning before heading into work and it miraculously found it. Odd - thanks for all your help.
  7. Thanks Michel, yes I did follow the instructions. Although I have to say that I had the morninglinc detected when I first started with ISY and I did not select the 3rd option. Then I reset the ISY. After that I couldn't get it detected. Then, I tried a 2nd morninglinc (fresh new) and I couldn't get that detected. Any ideas?
  8. I'm having a similar issue. I had it detected in ISY-99ir no problem before but it wasn't working for me. Now the morninglinc module won't even get detected in ISY. I am using release 2.8.16. Should I be upgrading to a BETA release? The odd thing is that at least before the ISY was detecting the morninglinc but now it's not even seeing it. Even if I enter the info manually it won't find it. I've tried 2 morninglinc modules with the same result - doesn't show up in ISY. Any assistance would be greatly appreciated. Thank you! [update] - I just tried the latest firmware to no avail. I also factory reset the PLM as well as the ISY-99IR but for some reason none of my morninglincs are being found.
